Question about Kenmore 20.3 cu. ft. / 575 liter Upright Freezer 23024
Kenmore 20.3cu. ft. freezer runs but will not kept anything cold. Was keeping everything at 10F, at any setting.
  • 523 Answers
Check to see if cold control is bad or unit may have a leak
Posted on May 05, 2010
Energy saver keeps going off and on with beeping sound. Everything else seems to be working OK.
Check your manual but you settings could be to cold for it to run in energy saver mode so it keeps catching up then slacking off.
Nov 01, 2013 | GE Profile : PFSF6PKXWW 25.5 cu.ft. Bottom...
The freezer won't keep normal -10F temperature, but stays at -35F to -40F at all times
Thermostat or start relay is defective and causing the compressor and fans to run all the time. Here is a manual for all models=> HERE
Sea Breerze
Feb 10, 2013 | True 49 cu. ft. / 1388 liter Commercial...
Freezer runs but won't keep most foods frozen even on coldest setting
Check condenser clean and fan working. Check it's not frozen solid because you've been running it full pelt; if it is, fully defrost it then set it at a mid range setting.
May 13, 2012 | Kenmore Freezer 20.6 cu. ft. Frost Free...
I live in Winnipeg, Manitoba. I have an old Kenmore upright freezer. I would like to leave it in my unheated patio over the winter. Should I leave it plugged in, or can I unplug it and just watch the...
Leave it plugged in. It won't over freeze. If the outside air is cold then it won't need to run as much to bring down the temp-nature is doing that. So when the weather gets warm it will run to keep everything frozen. Hope this helps. Google burdfrenzy
Nov 25, 2010 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Can anyone tell me what My Kenmore upright freezer 20cu ft should be at? temperature I mean?
Freezer temps can very, but as we know freezer temps can run from +32F to -40 or more on commercial boxes with the different freons. But back to you, I would say from my charts on low, med., temp refrigerators, you should be around +8F to -5F. When I mentioned +32, we know that's when water starts to freeze, so you want the freezer to be much colder then that.In order to keep ice-cream frozen, you must cycle around -5f to -10f.I sincerely hopes this has helped you out, as you will I am sure get many different opinions, but +8 to-5 is excellent for this box.
Sincerely,
Shastalaker7
Nov 16, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
What temp should freezer be set on in a hot garage?
commercial refrigerators are required to be set to 23 % a home unti shold not be less than 27% and thats for food being frozen to last 6 months.
Jun 28, 2009 | Kenmore 20.3 cu. ft. / 575 liter Upright...
reason is that the evaporator is blocked with ice and hence no air circulation.
either
switch off for 24 hours with doors open
or
remove back panel inside freezer and melt ice off with a hairdryer
Oct 16, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
1)forget about the key you'll be disposing of this unit anyway
2)the alarm is to tell you that the unit is above ideal temp.
3)the unit isn't making temp due to refrigeration issue. if it isn't cold enough on 3 then 1 won't do it either.
Apr 09, 2008 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Kenmore freezer not cold at all!
We had a Kenmore upright which worked fine but then suddenly was not keeping food frozen. Long story short, do not store anything on top of the freezer unit. It will insulate the coils that run across the top of the unit, and cause your compressor to work harder than it needs to, and eventually overheat and become ineffective. Says nothing about it in the user manual. We learned the hard way by losing food.
Jul 30, 2007 | Kenmore 20.6 cu. ft. Upright Freezer 24092
Kenmore 20.3 cu. ft. / 575 liter Upright Freezer 23024 Logo
120 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
christian nielsen
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
