Question about HP LaserJet 3052 All-In-One Printer
Can you upgrade the processor or add memory so it prints faster?
  • 3,083 Answers
I couldn't find anything on a memory upgrade, unfortunately. Printer boards are usually fixed boards- that is to say, there are no sockets for memory chips or ungradeable cpu chips. Thus, the reason for so many different models, with different options, and faster printing. On some machines you can adjust the quality print output to achieve a slightly higher printing speed, but that is all I can suggest. Good luck, and hope this helps.
Posted on May 05, 2010
If a install faster processor in my emachines t2954 would my desktop work faster
Max out the memory and upgrade the processor....
Sure.....but that is only a job for an experienced PC tech.
The worst part is after spending all that money for upgrades, you could have purchased a new PC with a warranty.
It's your choice.
Feb 16, 2013 | E-Machines eMachines Desktop PC
How do i upgrade processor
upgrading the processor on laptop usually not recommended since you won't get too much performance boots from doing that. Adding more memory or larger/faster hard drive would be a better solution. Anyway, to upgrade the processor on laptops normally require you to remove the motherboard to access the CPU.
May 11, 2012 | Computers & Internet
Need to upgrade processor, need to know most recent and best available for this mobo
Here's the table of supported processors from the manual for your board:
If you need a copy of the manual, you can download it here.
There's really very little to be gained by upgrading the processor on this board, unless it's the bottom-rated Celeron. Here's one source for the Pentium 4 at the top of the table. There are others, I just picked this one because it was first. This is a discontinued, fairly old board with a socket 478 design. This limits the processors it will support, and also the availability of parts. Simply sticking in a little faster processor won't make a big difference in performance.
What will help, if you haven't already done so, is to add memory. Putting in the maximum the board can support (or is supported by the operating system, if it's a lower amount) and using RAM matched to the processor speed will let was you have already work its best. And upgrading your video card may also be helpful for many applications.
Jan 01, 2011 | Intel D865PERL Motherboard
I have a acer 210t laptop with a 700 processor. can I upgrade to a faster processor and if so which one and how fast. Thank you.
Some laptops have "mobile" CPUs (physically smaller, and consuming less power) than the typical "desktop" CPUs.
So, if you know "how" to disassemble your computer, you may be able to remove the heat-sink & fans on top of the CPU, remove the CPU, and install a faster one.
However, if your current CPU is of the "Pentium III" series (which ranged from 500 Mhz to about 1400 Mhz), you may not be able to find a CPU that will be significantly faster than your current 1.26 Ghz CPU.
Instead, I would check the disk-drive -- if it is 4200 RPM or 5400 RPM, I would replace it with a 7200 RPM disk-drive, for better I/O speeds, and thus help your computer go "faster".
Also, I would add more RAM, again to make your computer go "faster".
Jun 09, 2010 | Acer Pentium III , 1.26 GHz Processor...
Its processor is only 800 mhz, can i upgrade it into a more higher mhz?
insteading of changing the motherbard for making it fast try upgrading the memory cards it add extra memory stcks in the computer to make it faster...
Apr 25, 2009 | Computers & Internet
Evo d3d upgrade!?
In the older days it was easier to tell you right away which processor would fit as there was not much variance in slot configuration. The Pentium 4 was released in several slot (sometimes called socket or pin-array configurations)configurations. The easiest way to tell is to remove your processor. Where it plugs into the slot (socket) you will see marked on the slot holder the configuration (Should say something like Socket 775 or Socket 478). Once you know what will fit in there you can go about ordering your upgraded processor. I would do some more information digging to see if your motherboard can handle the upgrade and how much memory it can handle. Have you already upgraded the memory? Sometimes more memory can make your computer faster. Also do you want it to be faster because it has gotten slower or because you want to run better games? If it has just gotten slower then go to CNET's download.com and download some Malware removal tools to help get your system cleaned up.
Let me know if this helps. This is a starting point.
Mar 25, 2009 | Compaq Evo D300 PC Desktop
Toshiba satellite
#1 answer; add RAM. What's your system specs?
Feb 26, 2009 | Toshiba Satellite 1805-S274 Notebook
Want to upgrade my proccesor
OMG!! doogie812, quit giving people bad advice. From what you have suggested, you know nothing about computer hardware. You can upgrade the processor in this system and it will not effect the OS one bit, except make it process the data a little quicker. With this system, if you had done any research at all, it only comes with 1GB of memory, you should of suggested to this person to add more memory.
Jan 11, 2009 | Acer Aspire AM1640-U1401A Desktop PC
Armada 1700 upgrade
hello
No you cant upgrade your processor.
also to change processor is very complicated in a old compaq.
and if you should manage to find a faster processor to your old compaq it not gonna make your laptop faster. the mother board and ram memory are still to old.
Dell-Net
Oct 15, 2008 | Computers & Internet
System upgrade
You would need to provide the laptop family, ie Inspiron, Latitude, Precision, and the model #, D600, M60 , etc
Apr 08, 2008 | Dell 2.8 GHz Second Processor for...
HP LaserJet 3052 All-In-One Printer Logo
65 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
