Question about Craftsman Garden
Will not start. What is the first thing to look for?
    Sniper:
  • 52 Answers
The first thing to look for is to make sure it is getting spark. You can buy a tester and attach it to the spark plug wire or you can take the plug out attach the plug wire back on, ground the plug against the engine and pull the rope. You should see a spark. If there's good spark the second thing may be your carburetor may need rebuilt. They have a diaphragm in them and after awhile they wear out. It's pretty simple to install, just pay attention as you take it apart. Make sure you draw a sketch of where the fuel lines are hooked up to.
Posted on May 05, 2010
My 2000 mercury mountaineer wont start. When I try to start it every thing goes blank. I twist the battery cables and everything pops back on .
First does the battery have good charge (12v). Does the wire running into the battery terminals have complete contact with the terminals? Sometimes the wiring into the terminals fray and or slide out away from the terminal housing. It could be a few things but try those first
Nov 02, 2016 | Mercury Cars & Trucks
Can water make 2007 volvo xc90 not starting
About a dozen things will make your Volvo not start, but they all point to one of three things that ALL must be there to get the engine to start:
a) fuel
b) air
c) spark
Based on your question, "water" can be involved in any of these three things and stop the process of internal combustion.
Would recommend to check that all of these three things are occurring and that water has not degraded or eliminated any of them. If you just washed your engine bay and now find that the motor will not start - wait and let it dry out. See if you can start it later/then.
Sep 08, 2014 | 2007 Volvo XC90 V8 AWD Sport
Poulan chain saw wild thing will not start
simple things first
right fuel /oil ratio in tank ?
aircleaner not blocked off with sawdust?
stop switch set to correct "run" position , switch not broken damaged ? chain brake set ?
choke set correct to start ?
primer bulb working correctly , fuel is visible inside bulb
Apr 30, 2014 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Car will not start.
Is the security light flashing ? Will it crank in neutral ?
Jan 29, 2014 | 2002 Chevrolet Impala
Computer starts to click and everything slows down
some thing is useing up your system resources . go to start then run / search type msconfig . then click the start up tab and unselect things you dont want to start when the pc starts . make some room on your hard drive get rid of things you dont need . deframent the pc . disk clean up helps to . check windows update make sure your up to date
Aug 04, 2013 | Dell Inspiron 530 Desktop Computer
1985 Chevy El Camino 305ci. Turned over good but wouldn't fire. Replaced contrrol module and it started fine for about 2 months, then did the same thing. Replaced dist cap, rotor & coil. Start
Had an 84 silverado 305 that did the same thing. Try giving it a full tune up. Plugs, wires... Mine turned out to be fouled plugs. I didn't find that out till after i tore it down & put a timing set in it. Wasn't getting good enough spark.
Feb 16, 2013 | Cars & Trucks
Vitara 1.6 16v 96' wont start
There are multiple reasons. Need to start the process of elimination. First things first, the cheapest thing to check is the battery. I've had several vehicles which displayed the same thing: ran one day, wouldn't start the next. Fortunately, they just needed a battery.
After that, could be other issues: alternator, starter, possible timing component issues, fuel pump.
I know this is vague, but, the it is sort of a loaded question.
Dec 18, 2011 | Suzuki Vitara Cars & Trucks
Name some of the things that can stop a 2002 mitsubishi cedia from start
Here are some things thats could cause a no start, a bad fuel pump, a bad crank sensor or a can sensor, these are the most common, the coil would be the first thing to check. check and see if you have any spark at the plugs. if your engine doesnt even crank over when you try to start it then i would look at the batttery and then the starter but if the engine is cranking over good and just not starting then check the first things i listed like coil, crank and fuelpump, good day.
Sep 04, 2011 | 2002 Mitsubishi Lancer
Hard start first thing in morning
This could be a number of things, I would recommend that you start with the simplest things first, like changing the fuel filter, spark plugs, and the air cleaner.
Mar 23, 2011 | 2003 Chrysler Town & Country
NOKIA 3315 display not showing any thing
nokia 3315 display not showing anything its ok
Apr 13, 2009 | Nokia 3315 Cellular Phone
Garden Logo
27 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
