Question about HP Pavilion s7600n PC Desktop
Computer power shuts down when I try to turn it on.
I have installed a 1 GB memory card in my computer. When I go to turn it back on, the power shuts down.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 163 Answers
It all depends on determining the configuration details of *********** board. A DDR2 (If the slot is) would have capacities like dual side memmory and one sided memmory that could be fixed on to the slots provided on the motherboard. I would suggest you to check with the motherboard specification which is available for all brands on the net. This is for sure an issue which is pertaining of the non matching memmory on slots. Good Luck.
Posted on May 05, 2010
    Scholar:
  • 91 Answers
Depending on what you did when you installed the 1gb stick it could be a matter of incompatibility or now your powersupply is bad.
When i bought my first customized PC this happend to me, it would boot up get to the OS i'd be installing new software then it would shut down immediately. The techs later told me that my power supply had been defective and they just replaced it and shipped it back. The next instance my RAM was bad and that caused a similar problem. And THEN the HDD had an issue too. So I've never bought anything from them again but thats not the point...
Point is that you may want to do a little testing if possible or try to remove the 1gb stick of RAM and see what happens. But like I said if it's just turning off and not giving you an error or a screen then I'd repalce your power supply with the same amound of power or more.
    President:
  • 803 Answers
Make sure the memory is seated right and not out or loose make sure all the cables are secure and connected
Video Card
Wow, I think/know you went down the wrong path would you like to try troubleshooting with me?
Mar 19, 2014 | Acer Computers & Internet
I have a Dell GX620 that I rescycled.It wouldn't power up so I put in a different power source and put in 1 - 512 stick of memory. It then started up and I reformatted the hard drive and re-installed...
just leave in one of the new 1gb stick of memory
if stable memory was the issue so add the back one at a time each time shut down install turn on test
if still unstable coould be the hard drive
May 29, 2011 | Dell OptiPlex GX620 PC Desktop
My computer has been working fine. I powered it on today and I had no signal on my Sceptre monitor and the tower was runnning. I unpluged all cables on the monitor for 30 sec. Plugged them back and...
shut your computer down for 1 minutes with the power unplugged, and try it again.
depending on if your savvy with computers or not depends on how indepth you want to be.
You need to determine if your video card has gone bad or not. try to remove everything attached to your motherboard, memory, hard drives, any cables, and see if your screen turns on. Take out any network cards, video cards, modems etc, that is inside your comptuer. So you need to have your motherboard, cpu and fan+ power supply connected, and try to turn it on. If the screen comes up,l something you removed is bad. If it does not, and your computer is running, bad video card.
Most computers today come with an integrated video card, meaning everything is 1 piece. You might be able to bypass your motherboards video card port, by installing a separate card. You can get these at any computer store.
Hope this helps!
May 02, 2011 | Computers & Internet
I have a Dell Dimension E510 and was told the Radeon 4670 would work in it. I installed the card but the computer just goes on and off and on and off. Is the card too powerful for my computer? Or do...
You do need to install the drivers before using your new card, but that would only effect the display if you didn't. If the computer is actually shutting down, then I think your power supply might be the problem. Check your card's manual to see what the minimum power input is. Then compare that to what your current power supply's output is. These new cards draw a lot of power and if your power supply can't handle it, the computer will shut down. If it does turn out you need a more powerful power supply, you can find them online. It's a fairly easy change to make. Hope this helps!
Apr 19, 2011 | ATI RADEON Hd 4670, (1 GB) PCI Express...
Where is the sound card located in a dell dimension 1100?
The sound is integrated onto the motherboard in this model, it isn't a separate card.
Jan 01, 2011 | Dell Dimension 1100 PC Desktop
Computer wont turn on with video card
Hi, the problem may lie in the temperatures of the card and power supply. If the system exceeds a certain temperature the system will shut down, this is easily achievable if you are over clocking your cards or CPU. You might find that installing extra cooling power with for example, a water cooled unit, fixes the problem but it is an expensive way of finding out there may be another underlying problem. Just a thought, maybe you could get one, try it, if that doesn't solve the problem, send it back? Hope this helps in some way, happy gaming ;)
Mar 26, 2010 | Gateway DX4200-UB001A Desktop Computer
I installed a 1g memory card in my gateway mx7118 and when I turn my computer back on I get a message to Press F11 to start system recovery 2, but nothing happens when I do that. If I remove the new card...
there might be any problem in tat card...or u have not fixed it correctly......check it properly for silly mistakes............or change ur memory card
Oct 31, 2009 | Gateway MX7118 Notebook
My Dell Dimension 4600 will not turn on. Steady Amber Light
Disconnect the Power cable / A/c adapter/Battery from computer.
Disconnect External peripherials.
Hold down the power button on the computer for 10 seconds.
Reconnect the power cable or A/c adapter and battery or the computer
Try to turn on the computer
check for Led's on the computer
If still no display ,shut down the computer,disconnect power cable.
Open the computer tower,remove memory modules,reconnect power cable and turn on the computer.If you get a beeping sound after turning on you should be getting beeping sound suggesting the mother board is not bad.Turn on the computer and disconnect power cable from computer.
Reseat 1 memory at a time if you have 2 memory module or if single memory module reseat in different memory slot,swap memory module.
Reconnect the power cable and turn on the computer if it boots to desktop possible issue with 1 of the memory module.
Disconnect the harddrive ide cable from the harddrive .Turn on the computer.
If still unable to power on .Shutdown the computer and disconnect power cable.Remove video card,sound card ,modem card if any .Connect just the vga cable from monitor to the integrated video port.
Connect power cable and turn on the computer.
If computer turns on possible issue with one of PCI or PCI express card.
If still unable to power on.Disconnect the power connector pin from the motherboard and reconnect it back.Turn on the computer check power power led on motherboard,also check if the processor fan is spinning. if no go then issue with motherboard.
Sep 03, 2009 | Dell Dimension 4600 PC Desktop
WHEN I PRESS POWER BUTTON NOTHING HAPPENS
If still unable to power on.Disconnect the power connector pin from the motherboard and reconnect it back.Turn on the computer check power power led on motherboard,also check if the processor fan is spinning. if no go then issue with motherboard. GOOD Luck.!!
Aug 27, 2009 | Insignia D400a PC Desktop
No powering on
Resolution:
Aug 24, 2009 | Dell Computers & Internet
HP Pavilion s7600n  PC Desktop Logo
37 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
