Question about Burton GRIP FIT CAP STRAPS FOR SNOWBOARD BINDINGS
Top strap won't tighten
The top ******** one of my bindings won't tighten. It is always really lose and I think it might be a broken spring but I don't know where to buy a replacement or how to fix it.
  • 66 Answers
The springs can die in buckles after a while and all that you can do is replace it with a new one. Try your local snow store and see what they have in their parts kit.
Posted on Jun 08, 2010
Testimonial: "thanks I'll try that"
Machine goes out of balance & vibrates on spin cycle
Some models of top-load washers use tub dampening straps to cushion the movement of the tub during the spin cycle. There are four straps attached to the top of the tub and to each corner of the cabinet
Also There are four suspension rods that suspend the tub and allow the tub to free float. If the suspension rods are noisy, there will be a squeaking noise during wash. You can fix this by putting bearing (lithium base) grease in the cup that each rod rests in. If it continues to squeal replace all four rods the cups come with the rods, replace them as well.
If your washer has a loud banging noise during spin the balance weight may be loose. This weight is to counter act the weight of the motor so you will find the weight directly behind the motor. Sometimes simply tightening the bolts will fix your issue but if the bolts are stripped out get some bolts slightly longer than the original bolt to allow you to put a locking nut on the bottom side of the mounting plate. If the weight is broken replace it.
Lastly Washer vibration can be caused by a broken counter balance spring. Ur washer may be equipped with one or more counter balance springs which help to absorb the natural movement of the spinning tub. If a counter balance spring fails the tub might lean in one direction more than another and it will shake and cause vibration.
Mar 19, 2015 | Washing Machines
Broken esp youth suprahero strap
Broken esp youth suprahero strap - Fixya
www.fixya.com/support/t15750244-broken_esp_youth_suprahero_strap
Jan 8, 2013 - broken esp youth suprahero strap - Emsco ESP Youth Suprahero Snowboard question.
Where to order replacement strap for Emsco ESP Youth ...
www.fixya.com/.../t22712551-order_replacement_strap_emsco_esp_you...
Jan 6, 2014 - Where to order replacement strap for Emsco ESP Youth Suprahero ... The red foot strap broke - Emsco ESP Youth Suprahero Snowboard ...
ESP Youth Suprahero Snowboard ' DICK'S Sporting Goods
www.dickssportinggoods.com/product/index.jsp?...
Dick's Sporting Goods
Rating: 3.1 - ‎31 reviews - ‎$24.99 - ‎In stock
Shop ESP Youth Suprahero Snowboard at DICK'S Sporting Goods. Find more ... It has adjustable plastic straps that easily fix over your child's snow boots. .... Nice board for a kid to use on sled hills but binding broke after minimal use. Value.
Burton 07 Custom S Bindings Snowboard Binding Small ...
Jan 08, 2013 | Emsco ESP Youth Suprahero Snowboard
Pfaff 1371 pressure foot won't come down on it's own
I just addressed this issue with my 6110. There is a spring in the shaft for the pressure foot. Over time the white grease that lubricates the spring and the plastic piston at the top dried up, gumming up the works. I took it all apart, cleaned out the bad (now hard grease), re-greased and put it all back together. Works like new. I used a lithium grease as it is easy on plastic parts.
Sep 04, 2012 | PfaFF Sewing Machines
Shifter lever won't return to the " center " position always. The problem is intermittent and seems to occur more in the heat. I've heard there may be something binding the mechanism....
Follow the shifter reach rod that runs from the shift lever back to a short lever on the transmission. Take the nut off and take the rod loose from this short lever. Then, move the forward like you are going to shift into low gear but don't actually shift the transmission into gear. Feel for the spring tension. Then, move the lever backwards and feel for the spring tension there. Check the shift lever and the reach rod for binding. If you don't feel the spring tension trying to return the lever back to the center, it's likely that the shifter pawl return spring is broken. This spring is what returns the shifter lever back to 'center". But,the temperature of the transmission will not change this. If the spring is broken, it's broken cold or hot. If the spring is good and there is not bind in the linkage, the problem may be in the shifter cam mechanism inside the transmission. Either way, this is an internal issue in the transmission.
Good Luck
steve
Aug 20, 2011 | 2006 Harley Davidson FLSTNI Softail Deluxe
K2 Cinch loop leash on top of highback tore. What is the best way to fix it? Glue, saw on, both or order a replacement part. Or leave it alone since it does nothing after adjustment.
The K2 website has a binding technical manual, link was found at the bottom of the K2 home page (see link below). The manual provides NO part numbers and NO repair procedures, but the repair is fairly easy.
http://assets.k2sports.com/k2snow/ftpk2snow/2017/catalogs/k2snowboarding_binding_tech_manual.pdf
The back straps on the K2 Cinch are called "grab loops" as shown in photo below.
If both “grab loops” are broken, take a few photos first so you can recall the routing for installation of the new “grab loops”.
These "grab loops" are held in by two silver coloured roll pins which can easily be tapped out with a small nail & hammer. If the pin doesn't come out easy, tap from the other side of the pin. The pin has a head on one side.
You may need to use pliers to remove the broken piece of strap from the top lever.
Take the broken strap pieces to your K2 retailer ( snowboard shop) and ask them to order a new strap. K2 info suggests you can’t order parts online direct from K2, so you have to order through a K2 retailer.
Use your other binding with the good strap to copy the routing of the new strap. You might want to order two new grab loop straps and change them both while you are at it. ??
Apr 14, 2010 | K2 Cinch CTC Snowboard Binding
Replacing plastic strap that hold the toe cap.
You just need to remove the binding form the board and look underneath the binding. If it doesn't drop out by itself just lever the broken piece out with a flat head screw driver. Once this is done you can insert the new part screw on the cap strap
Mar 04, 2010 | Burton 07 Custom S Bindings Snowboard...
The mixer binds in 3rd. gear on my hobart model 120 counter top mixer. how can i fix it.
It sounds like either your main shaft nuts are loose in which case you can tighten them up. Tighten the bottom planetary nut first then draw up the main shaft with top side nut but not to much. Its possible to overtighten this. You tighten the top until you feel it getting tight then back it off a little. Otherwise you can pinch the gears and everything tight to the shaft by over tightening and your shifter speeds wont work right.
Or If thats not it, Has the transmission been apart recently? Its possible to put that top gear in upside down which will lock it up when turned on. and break additional parts. I'm talking about that two part gear assembly that has the spring loaded diving key in it. Match up the wear points. you should be able to tell which way is up by the wear on top or bottom of that gear.
Hope that helps!
Dec 20, 2009 | Hobart H600 Stand Mixer
My GE wjrr417og2ww the tub seems lose and with heavy loads the washer is making noise. Has a strut or spring come off?
make sure basket is tight to tub/ transmission (hub nut is not loose). remove front cover (two clips between front and top), use putty knife to release, pull forward at top then lift out. check mouting of hangers, also look at rubber straps between tub and frame at top (4). the straps limit tubs travel from hitting sides
Jul 05, 2009 | Washing Machines
Gilera dna 50cc
check fluid level ,if low top up and try bleeding the pipe to expel air,
Mar 14, 2009 | 2002 Gilera Coguar
Snowboard bindings types
"Strap Bindings Highback Bindings The Strap Bindings is the original and still the most popular Binding System in Snowboarding. This is because Strap Bindings are not only adjustable and very secure, they are also comfortable. Nowadays, this Type of Bindings is designed to be lighter and stronger. Strap Bindings consists of a contoured baseplate where a rider can place his Soft Boots upon. At the back of the baseplate is a vertical plate (the highback) that rises behind your ankles and lower calves. The highbacks on Snowboard Bindings secure the heel of your feet and the backside of your lower legs. It also helps you to force the heel side edge of the board into the Snow Surface and brings the toe side of the board up. At the front of the binding are two or three adjustable straps which can be used to secure the front side of your feet and ankles to the Snowboard. Initially, you may have to sit down to strap in, but with a bit of practice, it'll be easier to strap in while standing. Strap Bindings can differ in the number of straps, the shape of the base, and highback plate. Alpine riders who need to perform high speed turns will prefer taller and stiffer highbacks for greater control and improved edge control. On the other hand, Freestylers will want a shorter backplate for more flexibility and turning power. Most people go for these kinds of bindings as they are more common, offer excellent control, and offer more options when it comes to boots-bindings combinations. The combination of the highback plate and the front side straps gives great control. This Type of Bindings is used in combination with Soft Boots. As the Binding gives all the support needed, the Snowboard Boots can remain soft and comfortable. Keep in mind that the Best Strap Bindings have ample amounts of wide padding at the toe and ankle straps. Step-In Bindings Step In Bindings It is quite hard to get into Strap Bindings since you need to loosen and tighten the straps every time you get into and out of your bindings. This is why Step-in Bindings were developed. This Type of Snowboard Bindings allow you to simply step down and click into it, thus making it easier for you to get on and off your snowboard. With this feature, Step-in Binding Systems have become quite popular with rental shops because they often give the beginners fewer Snowboard Equipment to fuss with. Still, while Step-In Bindings give you additional speed and can save you from a load of hassle, you pay for these conveniences when it comes to snowboard control. Step-in Bindings don't have any straps to give additional support, making the Snowboard Boot less flexible, and thus, harder to do Snowboarding Tricks. So make sure you get a good fit if you're planning to buy this. Step-in Bindings usually work in combination with soft boots which are somewhat stiffer than those used with highback bindings. When you opt for Step-in Bindings, you narrow your selection in choosing Snowboard Boots and Bindings since they both have to be ""step-ins"". However, there are some higher and more advanced Step-in Bindings out on the market that provide the best of both worlds. Step-ins can be used for either Freeride or Freestyle riders. Cross-over skiers will often feel comfortable with Step-in Bindings and boots since they are used to stepping in and to harder boots and just turning a switch or a latch whenever they want to get out. Flow-In Bindings Flow In Bindings Flow-In Bindings is quite new and is a hybrid of the step-in and strap systems. This Type of Snowboard Bindings tries to combine the control of Strap Bindings with the ease of Step-in Bindings. Flow-In Bindings look rather similar to Strap Bindings and also allow you to use soft boots. The notable difference is that, unlike the two or three straps that cover the top of your feet in Strap Bindings, the Flow-in Bindings have only one large tongue that covers a large part of the top of your Snowboard Boot. Getting into and out of your Bindings is a matter of flipping the highback backwards and entering or exiting your boot. Flow-in Bindings are becoming more popular as the choices and Techniques of Snowboarding improve. People love the Flow-in System as it combines all the advantages of the Strap Bindings with the ease of Step-ins. One disadvantage however is that Flow-in Bindings are more difficult to adjust than strap-ons. Plate Bindings Plate Bindings Plate Bindings, also known as Hard-Boot Bindings, consist of a hard baseplate, steel bails, and a heel or toe lever. This Type of Bindings is used in combination with Hard Boots that can be inserted into the bails. By flipping the lever, the boots are strapped firmly into the Bindings. The features of the Plate Bindings are the closest to a traditional Ski Binding and their rigid responsiveness provides maximum leverage and power for high-speed carving and riding on hard snow. Plate Bindings and hard boots are mostly preferred by Alpine Racers who need the extra edge control that they get from this combination. Baseless Bindings This Type of Bindings was introduced in the mid 1990's by several companies. In Baseless Bindings, the sole of the Snowboard Boot is placed in direct contact with the Snowboard deck by removing the Binding's baseplate. With this, the sole height is lowered by up to 1/8 of an inch. Theoretically, using the Baseless Bindings enhances the ""feel"" of your Snowboard's flex. However, this Type of Snowboard Bindings aggravates ""toe drag"" problems for people with large feet. Also, most Baseless Bindings are far more difficult to adjust (stance angle/width) than traditional ""4x4"" designs. Still, Halfpipe and park riders prefer Baseless Bindings because it provides them with a quicker edge response. The choice of what Type of Snowboard Bindings to use usually comes down to personal preference and finding the right Snowboard Boot first. If you feel that the convenience of stepping in outweighs the additional control you can gain, then it is best to go for that particular Style of Binding. Regardless of which Type of Binding System you wind up with, don't head for the slopes until you know exactly how to get in and out of them. With or Without Highbacks? The large curved piece of plastic screwed to the base of the binding is the Highback. Its main function is to give riders some control over their Snowboard's Heel Edge. These can be found on all Bindings or are built into the boot with some Step-in Systems. Alpine riders who need to perform high speed turns will prefer taller and stiffer Highbacks for greater control and improved edge control. On the other hand, Freestylers will want a shorter backplate for more flexibility and turning power. Snowboard Boots and Bindings form a combination wherein not all Kinds of Bindings are suited for each type of Snowboard Boot. It is often best to buy them together. In here, knowing your intended Snowboarding Style is crucial before buying a combination of boots and bindings. "
Dec 01, 2008 | Flow M9 Snowboard Binding
Burton GRIP FIT CAP STRAPS FOR SNOWBOARD BINDINGS Logo
376 people viewed this question
Top Burton Winter Sports Experts
Arnie Burke
Arnie Burke
vtrktrmn
Are you a Burton Winter Sport Expert? Answer questions, earn points and help others
