Question about Kenmore 62602 Electric Dryer
Not heating/drying....I am sure the heating element probably needs to be replaced...which I can do myself if I can get the part and figure out where it is....400series
    Genius:
  • 1,122 Answers
Remove the back and check the heating element inside the heater box and the heater box fuse on the left side top of heater box
Posted on May 07, 2010
Dishes are not dry anymore after cycle?
Hello there:
If` you ahve already checked all of the filters and they are ok than your drying cycle has problems to check these check these: Heating element Drying fan Thermostat Heating element Your dishwasher has an electrical heating element that helps to dry the dishes. If the element is burned out, the dishes won't dry properly, and you need to replace the element. Drying fan Many high-priced dishwashers have a small fan that blows air or heated air into the dishwasher to speed up the drying process. If the fan is defective, you need to replace it. Thermostat Some dishwashers have a thermostat that monitors the drying temperature. If the thermostat is defective, the heating element may not cycle on or off properly. If that's the problem, you need to replace the thermostat. there:
Normally if you have just started to have this problem and you have checked all of the filters and are sure they are ok than
Jul 06, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Heating element going bad. Even with setting on high and small loads the clothes take forever to dry. Can I replace the heating element myself?
yes but make sure to unplug before you start but make sure lint is not the cause ck dryer hose cabinet motor blower wheel and discharge tube is lint free the element doesnt sound like the problem they just go inop may be it is limit switch short cycling but also make sure element housing is clear of lint
Jan 26, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
My dryer doesn't heat anymore, the drum rotates when you push the on button, and my switch box is fine , none of the switches have tripped. Usually the dryer sensor signals when the clothes are dry and the...
Heating element thermal cut-off (thermal fuse) 360 degrees and high-limit thermostat 250 degrees. Its about $20.00 ,test for continuity with a multimeter,if bad unit will not heat,i have had to replace mine twice already,also make sure your vent is not kinked or blocked,this part is located on the side of the heating element housing!
Dec 31, 2009 | Dryers
Will not get hot when drying
There are a few possibilities- I'll take you through them:
1) Most probable: your heating element has gone bad- actually they usually break when they go bad/burn out. This will likely require some skill and some instructions for you to repair- plan on replacing the heating coil and the door seal for good measure, especially if the unit is more than 10 years old.
2) Less probable but possible: are you sure your drum is tumbling? if not, your clothes won't dry and you'll lose the element in short order.
3) yes less probable but still possible- the contacts on the switch dedicated to heat settings or the thermostat have gone bad, denying current to the heating element.
Good luck!!
Dec 14, 2009 | Dryers
Whirlpool model LER7648PQ1 won't heat up
1) Most probable: your heating element has gone bad- actually they usually break when they go bad/burn out. This will likely require some skill and some instructions for you to repair- plan on replacing the heating coil and the door seal for good measure, especially if the unit is more than 5 years old.
Good luck!!
TUMBLES, MAKES ALL THE RIGHT NOISES BUT THERE IS NO HEAT.
Good luck!!
Dryer won't heat
Good luck!!
Dec 11, 2009 | Frigidaire Dryers
Kenmore Dryer, Model # 11063102100, does not dry.
Does the drum still turn. If so probably just needs a new heating element. VERY easy to replace. Usually instructions to replace on or in new element box or just google instructions.
New heating element would be my first move to repair dryer.
Also, if you use softeners or dryer sheets, Wash lint screen with dawn and soft scrub brush to remove oils and residue (even if it dont look like there is none there there is) to extend your heating element use.
Sep 26, 2009 | Dryers
No heat will come from the dryer
Check the dryer breaker pair in the house electrical box. Push off, then on. If the breakers trip immediately, then you have a direct short circuit in the dryer, usually the heating element which involves removing the drum to get at the element(s). If the breakers hold, then try the dryer. If you get heat--ok. If drum turns, but no heat--check with a voltmeter across the two slanted slots in the power socket. You should read ~220 volts AC. If near zero, then one of the breakers is probably bad. Get an electrician to replace the breaker pair.
Aug 17, 2009 | Dryers
Kenmore 62602 Electric Dryer Logo
218 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
