Question about Sharp BD-HP21U Blu-Ray Player
BD-HP21 cannot find update on my flash drive. Formatted the flash drive twice (FAT32 & NTFS) extracted the zip file on to the hard drive and copied the update file to the flash drive. Help!
  • Sharp Master
  • 736 Answers
Let's start from the beginning again. Go ahead and reformat your usb device to fat 32 wiping everything. Next go to www.sharp.ca
Click on Service Support on the left and next click on downloads. Select Bluray, next and then your model number, done.
Then save the firmware directly to your usb device.
If the usb device is larger than 4GB it might not work.
If the download still does not work try formatting the usb device again this time to fat and then dowloading again.
You may need to reset the bluray player. Hold down the power button on the front of the unit until it says reset. Then put the usb device into the player before turning it back on. Press setup-->settings--->software update.
Posted on May 05, 2010
Why won't it recognise external hard drive?
Your external hard drive is probably formatted in Microsoft's NTFS format. Older TVs do not recognize this file system.
Try to connect to the TV a Hard Drive formatted in the FAT32 file system. It is possible to convert NTFS drives to FAT32, using a computer.
Note: Even if the TV will recognize the Hard Drive, it may or may not play the files (videos, movies, music) stored on the drive. Check the TV's manual for the supported files.
Dec 23, 2015 | Panasonic VIERA Televison & Video
Tip
How to Convert NTFS External Hard Drive to FAT32?
My friend Michael bought an external hard drive last month, yesterday he ran to me and ask how to convert external hard drive from NTFS to FAT32 safely and easily? I was so curious about why does he want to convert NTFS to FAT32; he said NTFS partition can't be read by DOS system. Since protecting data and files, I recommend him to convert external hard drive from NTFS to FAT32 with a third-party software-AOMEI Partition Assistant, which can convert hard drive from NTFS to FAT32 without data loss.
To computer users, NTFS and FAT32 are not strange. But seldom of them can tell what the difference between them. NTFS and FAT32 to partition are what DOC and TXT to text. In text, the file with DOC format can't be read by TXT application. Similarly, in some condition, not all files in different formatted partition can be read by same application. First, you'd better know some knowledge about NTFS and FAT32.
A Brief introduction of NTFS and FAT32
About FAT32
FAT 32 is one of partition format in windows system. It has 32bit file table, which strengthen FAT32's management to partition, and break through the limitation of 2GB space in every partition. Since the production cost of hard drive decreasing, the volume capacity is increasing. After applying FAT32 partition format, a big volume hard drive can be definite as a partition but not be divided into multiple partitions. It is good for management to hard drive. Now, FAT32 is replaced by NTFS.
About NTFS
NTFS is standard file system after Windows NT, 2000, XP, server 2003, server 2008, Vista, and 7. It replaces FAT to offer file system for Microsoft. NTFS make advanced on FAT and HPFS, such as to support metadata.
The difference between NTFS and FAT
As mentioned above, NTFS and FAT both are file system. However, NTFS is produced late than FAT32, but NTFS is more advanced in technology. In summary, the specific distinction are following below:
NTFS can support up to 64GB single file and 2048GB partition. FAT32 supports up to single file with 4GB and partition with 32G.
NTFS does not need Defragment your hard disk.
NTFS support to compress partition, folders and files.
NTFS takes a little cluster, which can help to manage space of hard drive effectively, and avoid wasting space of hard drive at the most extent.
In NTFS partition, you can share sources, folders and set access permissions on files. It is more secured than FAT32 partition.
How to know which partition format is suitable for you
As mentioned above, NTFS and FAT32 have its own advantages. When we choose which file system, you should consider the factors below:
Computer is installed with single system, or multiple systems.
The number and capacity of local installed hard disk.
Whether has consideration about security or not.
If computer is installed single system, and there is security to consider, you can select FAT32. Or NTFS is not bad choice absolutely.
Why need to convert NTFS External Hard Drive to FAT32?
NTFS and FAT32 are two different types of file systems, and both of them are commonly used and contain different characters. You may make conversions between the two types, and here we got several cases that you need to convert external hard drive to FAT32:
If your external hard drive is formatted in NTFS, you would not be able to access some files from DOS mode or Windows 9X, then you need to covert external hard drive to FAT or FAT32.
NTFS can't be recognized by many devices, such as Xbox 360, PS3, etc. in that case, you have to convert the external hard drive to FAT32 so that it can work with your devices.
There are more situations in which you need to convert external hard drive to FAT32, and there are different ways which you may realize the goal.
Methods to convert NTFS External hard drive to FAT32
At present, there are two main ways that you may convert external hard drive to FAT32, one is to convert to FAT32 with Windows built-in Disk Management, and another one is to convert to FAT32 with third-party software like AOMEI Partition Assistant. Let's see the details:
Method1: Convert an External Hard Drive by reformatting
1. Open the Disk Management in Windows.
2. Right click on the external hard drive and select "Format..." in the drop-down menu.
3. Select "FAT32" in the "File system" line and then choose "Quick format".
4. Finally click "Start" to format, and this process may cost you minutes.
Note: If the drive is larger than 32GB, the "FAT 32" option would be invalid and once format, the information or data in the external hard drive will disappear. So, backup the data or partition if necessary and you need to know how to convert hard drive larger than 32GB into FAT32.
Method2: Convert an External Hard Drive without formatting
You can download the third-party software to convert external hard drive from NTFS to FAT32, what is the most advantage is that convert NTFS to FAT32 without data loss. Comparing with disk management in computer, the third-party software will save your time and money. You don't need to buy other external hard drive to store data, just for converting partition format. Of the third-party software, AOMEI Partition Assistant is good choice. The specific introduction of how to convert NTFS external hard drive to FAT32.
As a kind of advanced partition software, AOMEI Partition Assistant can easily convert an external hard drive to FAT32, and you can also convert an external hard drive larger than 32GB into FAT32. This software is running well with Windows platform including Windows 2000, XP, Vista, Windows 7 and Windows 8. Both 32-bit and 64-bit Windows editions are supported. With its help, you need no to format your external hard drive and thus you can convert NFTS to FAT32 without data loss. Now, you may download AOMEI Partition Assistant Pro Edition and have a try.
source from
on Dec 29, 2017 | Computers & Internet
How to remove write protection from sony hd-e1
PC & MAC use different file systems.
It sounds like your hard disk is formatted as NTFS. NTFS will allow a MAC to read from the disk, but not write to it. You need to re-format it using FAT32 (if your MAC is older) or exFAT(if your MAC is fairly new)..
FAT32 will allow a maximum partition size of 2TB(when formatted from a MAC) and a maximum single file size of 4GB.
exFAT will allow pretty much any file size.
NB:Formatting a hard drive DELETES ALL FILES on the hard drive, so backup whatever is important before you re-format it.
1. Open Applications > Utilities
2. Choose you hard drive from the list on the left
3. Choose the "Erase" tab and choose your desired format (FAT32/exFAT)
4. Type in a new name..Click "Erase"
Apr 10, 2014 | Sony HD-E1 1 TB 2.5" External Hard Drive -...
We are converting from a PC to an iMac. We backed up all files to the flash drive which is a NTFS format. I soon discovered the MAC is not compatible with it and I cannot transfer my files. It seems...
The MAC can read PC formatted USB flash drives BUT the USB flash drive MUST be formatted in FAT32 not NTFS.
I have a MAC and I also transfer photos from my PC to my daughter's MAC notebook.
You can also transfer files from the MAC to the PC using these FAT32 formatted USB flash drives.
Mar 13, 2011 | Western Digital Passport 320GB External...
If you are running your computer under ntfs should your external harddrive be formatted the same instead of fats32. If it does can I move my back up from the external hard drive and move it back after...
The external hard drive can remain formatted as FAT32. NTFS and FAT32 are the file systems used by the individual disk drives, and do not effect the data being read or written (i.e., you can transfer data between the two with no worries about compatibility). There ARE differences, however, and many would suggest using NTFS to avoid some limitations with FAT32. For example, FAT32 drives have problems with individual files over 4GB. Formatting in NTFS is definitely recommended for people storing large files like video and other media files.
Yes, you can move any data you have off of your external hard drive (to your system hard drive or another external you use temporarily), format your external hard drive with NTFS, and then transfer your backups and other data back to your newly formatted external drive.
You can also convert the drive to NTFS; but I recommend backing up the data first anyway in case of (rare) problem during conversion. Here is a link that has directions for both scenarios (scroll down for conversion info) for Windows XP. http://www.microsoft.com/windowsxp/using/setup/tips/advanced/ntfs.mspx
The process to convert is similar for Vista and 7; here are the instructions from MS: http://windows.microsoft.com/en-US/windows-vista/Convert-a-hard-disk-or-partition-to-NTFS-format
Feb 02, 2011 | Western Digital My Book Essential Edition...
I have a my book essential 1 tb and i want to view my content on my ps3 but my ps3 does not recognize that i have the my book essential hooked up to it.
First, make sure that your PS3's firmware is up to date. You can do this by connecting it to the internet and setting it to update. Otherwise you will have to download the update, burn it to CD and then run the CD when powering on your PS3. Some updates can & will completely wipe-out\erase you saves, settings, downloads, & etc. Check out this web-page by Sony: ps3.com. Is your external hard drive formatted in FAT32? That is the only file format that the PS3 will recognize. Most likely, your hard drive is formatted in NTFS; which better supports large storage devices and you can use longer file names with it. I believe it is possible to format your hard drive in FAT32 (when attached to a computer), but the cluster size has to be set to a certain setting. I would suggest partitioning your hard drive into several partitions or drives, and then format those partitions in FAT32. Or just format part of it in FAT32 and the rest of it in NTFS. The PS3 should then recognize the partitions that are in FAT32. Please give feedback as to if this was helpful or not and choose a rating on how helpful you believe this information was.
May 28, 2010 | Western Digital My Book Essential 1TB...
Uploading to kingston data traveller 64GB corrupts my files
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW.EXE
2. Format
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Dec 27, 2009 | Kingston Technologies 512MB DataTraveler I...
My computer does not recognize my simple drive when I plug it into computer
Please note that: a drive formatted with FAT32 file system will not see NTFS formatted file system, whereas, a drive formatted with NTFS file system will definitely see FAT32.
To make it clearer, this means that, if on your system, your hard drive which is having the operating system installed on it, is formatted with FAT32 file system, and you bring an external drive, or even a backup drive which is formatted with NTFS file system, and you plug it to your system, the system will detect it but it wont be able to access the full drive capacity, you will just see it in the device manager page that it is connected.
But If it is Vice-Versa, the NTFS formatted drive will detect the FAT32 drive.
Now in your own case, if your system is formatted in NTFS file system and you plug in your external drive which is NTFS formatted also, then it means that you have some hidden partitions on your external drive, so when you plug it, try and do this:
Right-Click on my computer icon, select manage, then go to Disk Management Option.
On the Disk management option Page you should see ALL the drives installed on your system, including the hidden ones, so what you will just do is, try and locate the one representing your external drive, and right click on it. then select "Change Drive letter and Paths", and give the drive any new, unique letter (i.e alphabet) different from the ones already on your system, and click on OK.
If you see any other hidden drives there, do the same thing to it.
This should make your External Drive to be detected automatically.
Also Make sure that the USB port that you are using is a USB 2.0 port, and not USB 1.0 port, you can just try the other ports there, to be sure.
Hope this helps you out.
Nov 17, 2009 | SimpleTech SimpleDrive Portable USB 2.0...
My new 500 G external hard drive seems to limit the file size under 5 G. Is there somewhere I can reset this to larger file size?
A disk may be formatted using different file systems. The ones used by Windows PCs are FAT32 (an extension of the old MS-DOS FAT) and the newer NTFS.
If the drive is formatted as FAT32, the maximum file size is 4.294 million bytes (some systems report this as 4.294 GB; it is actually 4 GB minus one byte).
If this is the case (Start -> Run Command -> DISKMGMT.MSC and look for your external drive, it will say something like 489 GB NTFS or 489 GB FAT32), my suggestion is to back it up somewhere else and reformat it as NTFS. There also are utilities to convert FAT32 into NTFS, but if anything goes wrong during the conversion, you can say goodbye to all your data.
Note that you won't be able to access a NTFS formatted external drive except from Windows PCs (and most Linux, usually read only), while FAT32 disks are readable from Mac OS X too.
Nov 03, 2009 | Acomdata HybridDrive E5 Hard Drive
Reformat my external drive to NTFS
The only risk associated with file formats is that a drive formatted with FAT32 file system will not see NTFS formatted file system, whereas, a drive formatted with NTFS file system will definitely see FAT32.
Now in your own case, if your system is formatted in NTFS file system and you plug in your external drive which is NTFS formatted also, from what you have said, I suspect that you have some hidden partitions on your harddrive (the 250GB), so when you plug it, try and do this, Right-Click on my computer icon, select manage, then go to Disk Management Option.
Jul 15, 2009 | Western Digital My Book Essential Edition...
Sharp BD-HP21U Blu-Ray Player Logo
941 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
