Question about Pioneer DEH-P2900MP CD Receiver /AM/FM/MP3/ CD Player
Red,yellow and blue with stripe hooks to what into harness
I understand what they are but sometimes i see stereos have to have 3 wires connected i am wondering if this is my case and if so what colors need to be hooked up the wiring harness has more unused wires than the stereo does what is unused on the stereo is blue with stripe,yellow,red. the wiring harness is 2 orange(neg. dimmer,illumination) yellow,red and blue there is another blue but it is for remote for amps i know i dont need that
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Pioneer Master
  • 2,226 Answers
Some decks have a solid blue for power antenna and blue with white stripe for amp turn on. if you have neither a power antenna or amplifier, i would not worry about connecting those two wires. do makes sure they are capped off and have no bare wires showing, as they are hot when the stereo is turned on.
Posted on May 05, 2010
Does anyone know which colour does what for a madza demio stereo wiring harness
It sounds like the the ones with red and black stripes are possitive and negatives for your speakers then the others are positives also you would need a 12v test light to see witch wires have power to them and go from there
Sep 06, 2014 | Cars & Trucks
Installing Jvc KD-R610 into 02 Nissan Frontier, where I have removed older JVC. Using old harness, but blue wire labels do not match... One says "amp power" and other says "power...
well it sound like your ground wire is not connected the properly way this wire is black make sure
the other 3 are connect right are Yellow is constant power ,Red is acc.ingnition,Blue is the remote.
that would complite your conection done.
Dec 27, 2010 | JVC AM FM CD DET FACE CAR STEREO
I have an after market pioneer car stereo and not sure how to hook the red,yellow and blue with the stripe, to the wire harness with orange lummination and orange dimmer negative,yellow batt. and blue i...
red is usually ignition switched power from the fuse box and the yellow is continuous power to the deck. blue with the stripe is usually a voltage output from the deck to control the on/off of an external amplifier. If you hook the deck up and the memory stations do not save after vehicle on/off cycle of the ignition swap the yellow and the red wire and they should work. One is power all the time to allow the deck to store memory and the other is the main power to the unit.
May 05, 2010 | Pioneer DEH-P2900MP CD Receiver...
The brake light on the dash wont go off brakes are good rotors are good not the emergency brake. i have a 98 durango
check the brake fluid level and check the park brake switch it may be stuck on or out of adjustment
Apr 16, 2010 | 1998 Dodge Durango
I have a 1996 dodge grand caravan with 8 speakers. Im hooking up a kenwood stereo but I can only get 4 speakers to turn on. How do I get the other 4 to turn on?
here is the wire digram hope it helps
Factory in-dash wire harness (this vehicle has a 2 pc harness)
that snaps into the factory radio
Black Plug
Gray Plug
Radio Wire & Color Code Information Page 2 of 2
Typical Dodge/Chrysler Typical New Radio
Pin What It Is In Dash Wire Color Equivalent Wire Color
A Right Rear Spkr (-) Blue w/ White Stripe Purple w/ Black Stripe
B Left Rear Spkr (-) Brown w/ Yellow Stripe Green w/ Black Stripe
C Right Front Spkr (+) Purple Gray
D Left Front Spkr (+) Dark Green White
E Right Rear Spkr (+) Blue w/ Orange Stripe Purple
F Left Rear Spkr (+) Brown w/ Blue Stripe Green
G Power Antenna/Amp White (use for Infinity Radio) Blue
H +12 Volt Battery Wire Pink or Pink w/ White Stripe Yellow
I +12 Volt Ignition Wire Red w/ White Strip Red
J Radio Dimmer Wire Do Not Use
K Headlight Dimmer Wire Do Not Use
L Right Front Spkr (-) Blue w/ Red Stripe Gray w/ Black Stripe
M Left Front Spkr (-) Brown w/ Red Stripe White w/ Black Stripe
N No Wire
Metal Braid Or Plastic Connector Attached To Back Of Radio Is The Ground Wire
Feb 22, 2010 | Kenwood KDC-MP242
Wire diagram for the mazda protege stereo what
Sometimes if its the factory harness, you can see fine print on the wires telling what each wire is for. If not, remember, red is hot,black is ground, and your smaller wires all colored purple,brown, gray, green, orange, blue..there will be two of each color, one with a black stripe, that is your ground for the speaker hook up..There also might be a yellow or light blue wire, test that wire for power when the key is off, that is your memory power supply.good luck.
Jun 24, 2009 | 1999 Mazda Protege
Purchased a Thor Alarm with door locks and autostart and trunk release I believe model CF425 and was curious if anyone had a wiring diagram not sure what each wire is. One harness has 12 wires the other...
I have this alarm / remote start / keyless entry system and I have the poorly translated installation manual. Everything in mine installed fine in my 2005 suzuki aerio (except the power locks as the manual is worthless in that area) but I have heard nothing but horror stories from others online since I installed it.
I don't recommend you install it but if you really are determined, here is what the manual says (or tried to say and I spent 4 hrs interpretting / correcting it:
8 wire harness:
-- The 4 wire connector connects to the 4 wires harness part of the 3 relays
-- The yellow connects to the yellow of the breaker relay yellow
-- yellow w/black stripe connects to the oil sensor on the motor (look for single wire connected to sensor and generally a heat shield wrap/weave, mine was blue)
-- orange connects to the brake switch on the brake pedal
-- the blue connects to the door switch /dome light trigger
12 wire harness:
-- 6 central locking wires orange, yellow, and white plus the same 3 with black stripe.. Unfortunately the manual is not clear as to where they connect. The next page of the manual shows diagrams but they mysteriously add a white stripe to all the colors and the white wires apparently become green. I suspect that orange is not likely used in most installations and for positive door lock types (the most popular), yellow goes to unlock and yellow w/ black stripe goes to lock signal and the 2 whites go to 12v+. This is only a guess so don't hold me to it.
-- black is grounded to frame
-- Red is 12v+
-- red w/ black stripe goes to power trunk release (if equipped)
-- The 2 browns go to the left and right turn signals
-- The pink goes to the alarm
Ignition switch connections
The breaker relay:
-- blue goes to the ACC ON wire
-- Cut the ignition wire and connect the 2 greens to each end
-- Yellow connects to the yellow of the 8 wire harness
The 3 relays:
-- 4 wire harness connects to the 4 wire connector of the 8 wire harness
-- the 3 reds connects to the 12v+ red of the ignition switch (or thru the firewall to the battery)
-- black connects to the ignition on the downstream side of the 2 greens of the breaker relay
-- white connects to ACC ON
-- blue connects to the starter
Apr 25, 2009 | Vehicle Parts & Accessories
I have a honda civic 1992 and i buy a sony car stero i have problem with de wiring like red goes with red black goes with black but de others color from my honda civic are difent can i have an ide
Battery
White/Yellow Stripe
or White/Blue Stripe
Accessory Yellow/Red Stripe Ground Black Illumination Red Dimmer Red/Black Stripe Power Antenna Yellow/White Stripe Left Front Speaker (+) Blue/Green Stripe Left Front Speaker (-) Gray/Black Stripe Right Front Speaker (+) Red/Green Stripe Right Front Speaker (-) Brown/Black Stripe Left Rear Speaker (+) Blue/Yellow Stripe Left Rear Speaker (-) Gray/White Stripe Right Rear Speaker (+) Red/Yellow Stripe Right Rear Speaker (-) Brown/White Stripe
Oct 19, 2008 | Pie Hon03 F/Mm Car Stereo Wiring Harness...
Stereo wiring chart
If you go to anyplace that installs car stereos you can purchase an installation harness that will connect directly to your factory harness in your car. That way you would only need to wire your Kenwood harness to the instllation harness and that is just a matter of matching colors from the Kenwood harness to the installation harness. All you need to do after that is plug it in.
The wiring on the Kenwood harness is as follows:
yellow = constant 12 volts
red = ingnition (12 volts when key is turned on)
black = ground
white = front left speaker positive
white w/black stripe = front left speaker negative
grey = front right speaker positive
grey w/black stripe = front right speaker negative
green = rear left speaker positive
green w/black stripe = rear left speaker negative
purple = rear right speaker positive
purple w/blackk stripe = rear right speaker negative
blue = power antenna
blue w/white stripe = remote amp turn on
brown = phone
orange w/white stripe = illumination
Jun 18, 2008 | Car Audio & Video
Pioneer DEH-P2900MP CD Receiver /AM/FM/MP3/ CD Player Logo
218 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
