Question about JVC AV-48WP30 48" Rear Projection Television
Red is tearing at the right side - JVC AV-48WP30 48" Rear Projection Television
  • JVC Master
  • 8,617 Answers
The AV48WP30 convergence repair kit available from www.tvrepairworld.com should solve that issue the kit also contains the instructions on cd.
Posted on May 08, 2010
My Hotpoint freezer FZ150 red light keeps flashing. I turn freezer off then on again and its ok for a bit, then it flashes red again,
the flashing maybe door is not sealing check gaskets on door for folds or tears or door not aligned right
Feb 26, 2017 | Hotpoint Freezers
XHDR6435 radio was working fine yesterday, now it will not turn on. the red led behind the faceplate flashed when i turn on the car, and cds will load and eject but the radio will not power up. i habe...
I just Spoke to tech support. This is what they said:
1. Key in the on position and the red power button lit, remove the face plate.
2. On the left bottom side press and hold the reset button, with a pen, for 10 seconds and let go. The red led on the right should flash.
3. Reinstall the face plate.
4. Push power. The unit should come back on.
Mine worked, and i was about to tear it out and return it. So try this first or even call tech support for Dual 1-866-382-5476.
Jun 14, 2011 | Dual Electronics XHDR6435
I have a Swisher 2460 ZTR. When the dirve belt is attached the starter cannot turn the motor shaft enough to start the machine. I saw an earlier post where you instructed the person to check the bearings...
If the left side pulley is free of any belts, it should move as freely as the right side pulley. You will need to replace the bearings in the left pulley and all should be well.
May 18, 2011 | Swisher 60" 26 Hp Zero Turn Radius Riding...
Red blinking light
Hi, this is not a cartridge related problem. As you have written, it is related to the paper misfeed. When removing any future paper misfeeds, always take extra caution as not to destroy the paper sensor. If it jammed near the paper tray area, first open the right cover to see the paper, the try to pull it slowly till it comes out. Never try to force it out as you may tear a small piece which will show you that a misfeed is still on. If it does tear, carefully remove it until its out. If it jams on the fusing unit, release the side levers on the copier or turn the green rotating lever on the front which appears when front cover is open until it ejects it out.
If you are sure there is no jammed paper, make sure the spring on right side of fusing unit, where there is a sensor is retracted to its position. Good luck pal.
Jun 05, 2010 | Sharp AL 1631 Copier
Dead battery and can't open the bonnet. Tried charging it through the fuse panel, but it won't take a charge enough to activate the switch.
Connect a jump pack to the RED pull out lug and connect the neg black jump pack lead and connect to the door striker. Then re-attempt to operate switch for bonnet on sill panel OR press bonnet button on the key remote. Failing this attempt, you can attempt to locate the emergency bonnet release stainless cord. This is hidden behind the front bumper bar and inner wheel arch liner on the right side of the car. Sometimes it is taped up under the right side headlight, and if you are lucky, you might see it if you pull out the side indicator lamp which is located by a spring clip at one end. Note that you need to give the cable a hard pull, so be careful to not tear the top of your finger off trying to pull the cable....use pliers.
Feb 27, 2010 | 1999 Porsche Boxster
Wiring diagram s3755 hoover
Today I shortened my hose by 4" to get around a tear problem. You can use an Ohm meter to find the right 4 wires. When looking from the top of the canister with the hose heading to your left, the wires should be:
White (furthest connector away from you)
Black - to the switch
Red
Blue
With the Red and Blue going to the speed con trol curcuit board.
Aug 05, 2009 | Hoover S3755 WindTunnel Bagless Canister...
How to set half half size paper
Look for a latch on the right side tractor drive. This will unlock it so you can slide it sideways on its rail. Set it approximately where it should be, load the paper, then adjust it so you have a slight amount of tension across the paper. I think the rest is software.
Jun 25, 2009 | Epson LX-300+ II Matrix Printer
Cabe hook up tore out
Most cable boxes have outputs for audio and video. Yellow is the video, red is the audio out for the right side and white is the audio for the left.
Take a set of RCA jacks and hook it up to the back of the set on input one.
Yellow to Yellow
Red to Red
White to White.
You need further instruction, respond to this post and I will reply.
Dec 17, 2007 | Akai PT5492S 54" Rear Projection...
JVC AV-48WP30 48" Rear Projection Television Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
