Question about Maximatic EPM450 Popcorn Maker
Burned up heating element
We have a one year old popcorn popper and the heating element is not heating any more. Looking for a tech support URL for Maximatic or Elite 450 4oz popcorn popper.
Help
  • 9 Answers
SOURCE: popcorn popper
I am also looking for replacement parts for my ccp-509, specifically the kettle plug connector (female)
Posted on Feb 04, 2008
SOURCE: Salton Popcorn popper Model# PCST22Y
I owned one of these and it worked for 2 whole months.
It's a popcorn machine, how hard could it be? Make sure the stirring bar it tight on it's shaft, make sure the plastic bolt is tight. Add about 2 tablespoons of vegetable oil, and 1/4 to 1/3 cup popcorn kernels. Turn the machine on. Turn the machine off when the popcorn stops popping, or you might scorch the popcorn.
Posted on Sep 01, 2008
  • 4 Answers
SOURCE: 6 cup stir crazy popcorn popper lid
You can get parts to your Stir Crazy via focuselectrics.com that bought out West Bend. Just click on West Bend at the website.
Posted on Dec 27, 2008
SOURCE: Elite Cuisine EPM 400 popcorn machine
Maximatic Deluxe Popcorn Trolley Elite Cuisine EPM 400 popcorn machine burner is burnt out. where can i find a replacement pot?
Posted on Jun 13, 2010
fossilruins
  • 114 Answers
SOURCE: Salton PCST22 Popcorn Popper Measurement
This is the typical measurements for salton poppers
for 3 quarts/litres of popcorn:
1 tbsp. (15 ml) of oil
1/3 cup (85 ml) of popcorn kernels
1 (15 ml)* of butter margerine
Posted on Oct 19, 2010
Cornditioner heating element burns out within 2 weeks. New element has burned spot in less than 3 minutes.
Make sure the voltage is correct and matches the power source.It is possible the blower is not turning to keep air blowing across it? There also should be a theremostat that shuts it off if its getting too hot. Any one of these could cause that to happen.
Aug 11, 2015 | Cretors Merchant 16 oz. Counter Popper w/...
Heating element not working in old time Movietime popcorn maker
There are no replacement parts for Nostalgia Electrics equipment.
Double check that the kettle is plugged in, that the switch has power. If inclined open kettle and inspect wire connections and continuity, beyond that the popper is not fixable.
Nov 25, 2013 | Nostalgia Electrics CCP-509 Popcorn Maker
I have Presto 04830 PowerPop Microwave Multi-Popper. I over heats and burns the pop corn. My previous one worked fined. This one is impossible to use in its present state. MY microwave has not changed in...
Try new popcorn, popcorn dries out and does not pop well after being opened.
If the popcorn does not pop, and just turns black then it is too cold. If it pops very rapidly and then burns it is too hot. It is almost never too hot if you shut it off fast enough.
Aug 22, 2013 | Kitchen Appliances - Others
Model 39A gets too hot too fast
That model has a thermostat (also called a high limit) that is set at 450F. it should produce a popping cycle of 3 mins, and yes will burn popcorn if you don't dump it fairly quickly.
The speed it heats cannot be too fast, there is only so many watts in the heat element. it may go to hot, but never to fast.
The best way to test temp is time the 2nd popping cycle with a stop watch. the second batch should be 3 mins +/- 30 seconds. if it is 4 mins it is too cold. a 2 min popping cycle is to hot.
A popper that is too cold is also popping poor quality popcorn, higher amount of unpopped kernels, and small chewy popcorn.
Measure carfully when doing time test popping. That model is 2oz oil, 6oz popcorn, and 1 tsp salt. Start timing when you put ingredients in, and stop when you dump it. The kettle must be hot, that is why you time the 2nd batch.
May 20, 2013 | Star 39 JetStar Popcorn Maker
Is there a thermostat with this popcorn popper that prevents the popcorn from burning? Earlier models had one.
Yes, there is a thermostat inside that prevents the popper from overheating. I know because one is sitting on the desk in front of me. My popper pooped last night and popped only a quarter of the kernels, after several years of faithful service. So I took it apart today. Everything else checks out so I'm thinking the thermostat failed and isn't letting the popper get hot enough to work properly. Now I'm looking for a replacement thermostat.
Jan 05, 2011 | West Bend 82306 Stir Crazy® Popcorn...
Echols 490 heating element ??????
call janet at Echols parts 573-734-2210
Jan 27, 2010 | Cretors Goldrush Popcorn Maker
Popcorn popper not getting to proper temp.
Could be a bad element.
Try calling their tech support at: 773-433-7450 or Try finding a local dealer at: http://www.cretors.com/dealers.asp. Have your serial number ready.
May 26, 2009 | Cretors Kitchen Appliances - Others
My popcorn machine wont heat up
First, if you have another cord like this one (for example, a coffee pot cord) plug it into the popper and see if it works.
If it's not the cord, it's probably a blown thermal fuse inside the unit. Could be a heating element broken as well. If you don't have appliance repair experience, I would take it to a repair shop.
May 03, 2009 | Cretors Goldrush Popcorn Maker
New Cuisinart Party Popper not heating
Align the tabs on the plate with the rectangular indentations on the base.
Squeeze tabs, set plate on base and release. This should lock the two pieces together.
Mar 29, 2009 | Cuisinart PartyPop Maker Popcorn Maker
Popcorn popper
Sep 28, 2007 | Kitchen Appliances - Others
Maximatic EPM450 Popcorn Maker Logo
85 people viewed this question
Top Maximatic Kitchen Appliances - Others Experts
raysaw
Irene Tulloch
ELECTRICKS
ELECTRICKS
Are you a Maximatic Kitchen Appliances - Other Expert? Answer questions, earn points and help others
