Question about E-Machines (308714) Motherboard
Won't come on
I have an e-machines and it won't come on. Could it be the motherboard. can hear the fan run that's all
    Guru:
  • 1,481 Answers
The fan could be of the power unit...
so the MB might be out...
Posted on May 05, 2010
Ac fan not running, but compressor runs on and off
switch/ fuse possible if it has one, if not one of the wire going to the motor was severed, or the start up capacitor of the motor if it also has one.
Jun 04, 2013 | Frigidaire FAX054P7A Wall/Window Air...
Cdc-m computer will not come on the on light works case fans comes on but that is all
Do you mean that your computer does not turn on just casing light lit on and Fan runs only? What means new, memory and case?
If just lights on, fan runs but no image on monitor or blank screen, you should hear some kind of sound form inside of the CPU casing. This is called beep code. If you hear continuous beep or 3 same beep with same length, it means your motherboard is missing RAM, just connect it properly. If does not work or stop try a good RAM installing to see the result and plug your this RAM to a working machine that have the same kind of RAM.
If you hear one long beep with two short beep After PC switching on, or Two long beep with one short beep following - that means your Graphics card is not connected properly, or damaged or miss matching. If you do not have any beep code after switching on the machine, your motherboard may not have build in emergency speaker. Try to clear this things first. Please mention details of your computer with model number of your motherboard. Let me know updates.
Jun 25, 2012 | Computers & Internet
Subzero 501R fan won't shut down when door closes
HI, I'll be able to help you out but I want to go over some stuff that way you'll have a better understanding of your machine so if I have a question it will easier for you to answer. Lets start out with the fan. The fan your hearing inside the machine is called an evaporator fan. Its located at the top of the machine directly over the evaporator coils, which are behind the back wall, that freon goes through in its gas state to cool the machine. The evaporator coild get cold and the fans job is to pull air from the bottom of the machine, across the coils and intio the refrigerator itself and therefor cooling the whole thing. The fan does not extract air out at all. The suction sound you hear is caused from the machine design and the differential in temperature in and out of the machine. The fan will runs non-stop with only 2 exceptions. First being the door getting opened, which opens the switch, I think on that model is located naer the bottom next to the light switch. If the fan is running after you open the door your door switch is stuck or broken and needs to be fixed, but that wouldnt' tmake the temp raise. The second is when the thermostat registers that its cold enough it shuts the fan off. From the age and what your saying is going on I would first check the condersor coils, located behind the removable grate and see if they are really dirty. That would cause the temp to raise airfloe is blocked and the compressor gets too hot. While down there check the fan to see if its running as that too will cause the machine to get hot if not. Ihe coils are clean and the fan is running call a tech because you probably have a freon leak, which is the likely candidate.
May 03, 2012 | Refrigerators
Dell 370 fan runs loud and won't start
If the fan is failing the most times the computer will not start because it will overheat. There are two fans inside the system, one inside the Power Supply and one that sits on the motherboard.
Remove the Power Cord, Open the case, Remove the cover and with a can of compressed air blow out the dust inside the computer. Clean the dust away from the Fans, Vents, CPU and Heat Sink are that sits under the Fan on the motherboard.
Apr 23, 2012 | Dell Precision 370 (370TREC) PC Desktop
Compaq CQ4010F Desktop PC won't turn on after a power surge
You probably and lets hope so, have an Electro Static Charge Buildup on your desktop. Remove the Power Cord and Press and Hold the Power Button for 30 seconds. After 30 Seconds plug the Power Cord back in the hit the Power Button. If it boots then you had an Static Charge Buildup. If it does not boot and you say it happened after a power surge then either your Power Supply or Motherboard is possibly damaged. Do you hear fans, hear the disk drive running, see lights, hear the CD Rom click once and see the light on the CD Rom drive com on briefly after you hit the Power Button. If so it would seem that your power supply is ok.
Mar 18, 2012 | Compaq CQ4010F Desktop PC (NY650AAABA)
Presario won't power up
If you see no lights, hear no fans running, no disk drives running then the problem is probably a bad power supply or motherboard. Get a quote from your local computer shop then try the guys at: http://www.generalsystemsconsulting.com
They will fix it and ship it back by Fedex or UPS. They are very economical and good.
Mar 10, 2012 | Compaq Hewlett Packard Presario SR5152NX ...
My computer won't boot up and the orange light just stays on. The moniter is working, the fans in the power supply is working
Could be your motherboard. Does anything come up on the screen at all when you boot up? Do you hear a beep at startup? Also check to make sure your hard drive is spinning just to be sure.
Dec 09, 2011 | E-Machines Computers & Internet
I am not hearing the fans on this computer and i notice it heats up very quickly
With the computer turned off unseat and reseat the fan connectors back to the motherboard. If the fans are still not turning on then try some other new fans. If new ones won't turn on then you know for sure at that point the motherboard is going bad because its not putting out a high enough voltage to turn the fans on.
May 21, 2011 | E-Machines eMachines Desktop PC
Nx5000: Won't power up. symptoms:battery does not start(believed to be dead). Mains power,starts up and shuts down on a continuous 3-5 second cycle, from the time you switch mains on at wall. The...
Hi whisky_zulu,
I see that you have basically done everything possible on the machine still to no avail.
Basing from what you've done still the issue is the same it shows that the motherboard on the machine needs to be replaced.
no beep codes as you mentioned indicates that the motherboard does not respond at all there maybe power but you also mentioned that it also shuts down once turned on for a couple of seconds.
replacing the systems motherboard will be the only solution to this issue.
I hope that this makes it clear regarding your query.
Have a nice day,
mvincentc
May 07, 2011 | HP Compaq nx5000 Notebook
Hp won't turn on. When hit power, hear fan, HD run, few secs it turn off, try to to anything from hp list what to to, won' work.
Motherboard is defective & needs to be replaced with a new one.
You can find a replacement motherboard by searching on e-bay.com with the motherboard's model number. This could be found under the RAM.
Sep 21, 2010 | HP Pavilion dv6000z Notebook
E-Machines (308714) Motherboard Logo
115 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
