Question about Canon imageRUNNER 2200
Canon ImageRunner 2200 with Error code E000003-0000
Need to know what is the problem. What parts may be out. Would I be able to buy the parts? I have a repairman but he is not a Canon dealer nor Canon trained but may be able to help me if I can't do it myself.
  • alanm187 May 05, 2010
    There is no heat coming from the fuser. Would that narrow this down?
  • 1,284 Answers
Hi, this is a Heater temperature error, caused by an abnormal drop, or low temperature detection.
It is most likely a blown heater element.
The main thermistor reading is lower than 140°C when paper is moved.
Main cause can be the fixing film unit is faulty (i.e., the main thermistor (TH1) has poor contact or has an open circuit; or, the fixing heater is faulty). or,
The main power supply PCB is faulty. or,
The DC controller PCB is faulty.
Caution: The following steps should only be carried out by qualified people...
To clear the error, execute the following in service mode:
COPIER>FUNCTION>CLEAR>ERR.
CAUTION
Do not clear the error until the fault is repaired. If you clear the error, and there is still an electrical fault it may result in a fire!
Turn on the power switch, and clear E003. (Service mode) Thereafter, turn off and then on the power switch. Does the fixing heater operate?
No? Try checking...
2. Wiring
Is the wiring from the DC controller PCB to the fixing film unit normal?
NO: Correct the wiring.
3. Fixing film unit, DC controller PCB
Try replacing the fixing film unit. Is the problem corrected?
YES: End.
NO: Replace the DC controller PCB.
Take care
Posted on May 05, 2010
  • 4,472 Answers
This is a HeaterCanon ImageRunner 2200 with Error code E000003-000 - 2_bing.gif temperature error, caused by an abnormal drop, or low temperature detection.
CAUTION
No? Try checking...
2. Wiring
YES: End.
Hope this helps.
Thank you and have a great day,
Lee
Solution to erro e000007 on ir 2420 copier
What is remedy error code E000007-0000 for canon ... - Fixya
www.fixya.com/.../t14373194-remedy_error_code_e000007_0000_can...
Oct 12, 2007 - ... is remedy error code E000007-0000 for canon imageRUNNER2422/2420 ... Copier canon ir 5065 prolems with eror code e 000808-0002.
Imagerunner 2200 error E000007-0000 - CopyTechNet.com
www.copytechnet.com > ... > Copier Technical Discussion > Canon
Mar 15, 2007 - 4 posts - ‎4 authors canon ir 2200. hi, this machine do not have fixing roller. machine have fixing film assembly. this code is for damaged fixing film, on the end you ... Error Code Canon 3025 E000007-0000
Jan 30, 2013
Error Code The dreaded e000007-0001 error code!
Sep 5, 2011
Error Code Color ImageRUNNER 4060i has code ...
Jun 30, 2011
More results from www.copytechnet.com
Nov 05, 2015 | Office Equipment & Supplies
How to solve canon ir 3300 error code e0000190000
Neele, Error code E000019-0000 is a waste toner full , to get rid of this error, remove the waste toner bottle located left rear side of the machine,dispose of waste toner and clean the neck of the bottle because waste toner could obstruct the toner sensor beam. Switch off then on, OK to use.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Thread Canon IR 2200 Error E000019 0000
Canon ERROR 19 Waste Toner Tank
Jun 13, 2014 | Canon (6981A002AA) for imagerunner 2200,...
Error code e000007 0000
this looks good
...to code error E000007-0000 http://www.copytechnet.com/forums/canon/2954-imagerunner-2200-error-e000007-0000-a.html canon 3320irE000007-0000 how to solve my problem error e000007-0000 error
Jun 17, 2013 | Canon imageRUNNER 3300 All-In-One Laser...
CAnnon Imagerunner 2800 Error code: E000002 0000
SIR MY XEROX MACHINE IS PROBLEM ERROR CODE : E000002-0000
MACHINE MODEL : CANNON IMAGERUNNER 2200
Jan 18, 2011 | Canon (6981A002AA) for imagerunner 2200,...
E000007-0000 error in diplay
The Canon imageRUNNER 3300 System error e007 code means that the fusing film is out of Home Position or the film is ripped. You will need to most likely have the fixing film replaced. You are probably going to have to get a service to repair it.
fixya.com/support/t6195187-cannon_ir2018_system_error_e007
November 7, 2002 Product : IR 2200 / 2800 / 3300 Title : E007 code for the IR 2200 / 2800 / 3300 Problem :
E007 code is occurring for the IR 2200 / 2800 / 3300
Solution :
In Service mode / Copier / Function / Part Check, energize M4 (the Fixing Drive motor). If the Fixing Drive motor does not come on, replace M4 (part number FH6-1848-000). Canon USA, Inc. Systems & Technical Support Division
you access service mode by pressing ADDITIONAL FUNCTIONS-2-8-ADDITIONAL FUNCTIONS...
Nov 02, 2010 | Office Equipment & Supplies
Error Code #E000602-003
0003 A sector fault is detected on the HDD.
You need to replace HDD, upload system, language,...
Call service, beacause all of above is done over service support tool.
Jun 30, 2010 | Canon (6981A002AA) for imagerunner 2200,...
My imagerunner 2200 has the following error message E000007-0000
The error code means the fuser film is not in the correct postion. Odds are the fuser film is wripped or torn. It is going to have to be replaced before the code can be cleared.
May 07, 2010 | Canon imageRUNNER 2200
Canon imagerunner 2200 error code E000602-0003
This is hard drive failure. If you another code other than 003 you may have gotten away with a scan disk, but not always. in your case the hard drive has died. a Canon Technician will need to replace it and re-install the machine's system software
Mar 13, 2008 | Canon imageRUNNER 2200
Canon imageRUNNER 2200 Logo
75 people viewed this question
old marine
old marine
