Question about HP LaserJet 2840 Printer
Scanning on glass only scans 1 page, does not scan 2nd page
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Scholar:
  • 53 Answers
On the scanner glass it will scan only one page. If you want to do multiple pages. you need to use the ADF
Automatic document feeder.
Posted on May 05, 2010
Why are pages scanning with lines running through them, but printing perfectly fine?
Try cleaning the rollers. Usually you have to remove the cartridge to get to the rollers that moves the paper.
May 02, 2014 | HP Officejet Pro 8500 Wireless All-In-One...
Mx727 scanner has lines on scan using docment feeder
Hi. In the scanning section there is a small glass ( 1 inch wide ) be sure that glass is completely clean. If there is a dot of dirt a line will appear in the copies/ scan .
Feb 19, 2018 | Canon Office Equipment & Supplies
I have a Epson cx11 and get a black vertical line down the middle of scans and copies
Check your flat bed and Document feeder scanning glass need to be clean, if any dot or dust in scanning glass of document feeder it will appear a line, check this points first
1- Check printouts from computer or FAX if it is clean problem in scanning section
2- Check using Copying a blank paper using only Flatbed if it prints without any line its problem from document feeder Scanning glass
So solution is clean the Document feeder scanning glass using wet cloth, note careful about wet cloth switch off the machine and clean it
Feb 04, 2013 | Epson AcuLaser CX11NF Printer
Fujitsu fi5120c scanning every other page
hi, it sounds like the scanner is multifeeding, and as you have it set to A4 once that length is scanned, its just getting rid of the rest and starting the new page. Try cleaning or replacing the separation pad, or to prove the fault, hold the 2nd sheet until the 1st is scanned and its trying to pick thyen 2nd.
hope that helps, let me know how you get on.
Jan 18, 2012 | Fujitsu fi-5120C
When I scan to printer the page comes out with short lines down 1 side
If your printer has both an automatic document feeder and a flat glass portion for scanning, try scanning from both. If you only get the lines on one of the scans then that is where your problem is. Most common issue on scanners is a liquid paper, bit of paper, glue, etc on the Automatic document feeder glass. Clean the glass and you should be fine.
Apr 02, 2011 | HP Office Equipment & Supplies
How do I scane on my mx310
You will need to plug the printer andcomputer together with a USB cable in order to use the printer's scanningcapabilities. The scanning unit on theMX310 features an automatic document feeder on top of the printer, which willscan multiple pages itself. You can also choose to load documents on thescanning glass, which is covered by the scanner's lid. This is how to do it. 1. Turn on the printer by pressingthe "Power" button until it illuminates and turn on the attachedcomputer. Wait for the printer to finish its initialization process beforecontinuing. 2. Place the document face up inthe automatic document feeder if the document's papers are uniform in andfit in the feed tray. Adjust the paper-width guide to the of thedocument's papers. 3. Place the first page of thedocument face down on the scanning glass after you have lifted the scanningunit's cover, if you choose to not use the automatic document feeder. Close thecover again slowly so the document does not shift on the glass. 4. Press the "Scan"button on the printer's control panel, then press either "Black" or"Color," depending on the type of scan you would like to perform. 5. Retrieve the scanned documentfrom the automatic document feeder's output tray once the scan job is over.Otherwise, click on the "Yes" button on the computer's screen,indicating you would like to scan another page. 6. Lift the scanning unit's cover,remove the document from the scanning glass and place the next page of thedocument face down on the glass. Close the scanner's cover and click on the"OK" button on the screen to scan the next page. Repeat this processuntil all of the document's pages have been scanned.
Jan 13, 2011 | Canon PIXMA MX310 All-In-One Printer
Line all the way down the page when scanning on hp 3050
You have to clean the scanning glass. lift up the scanner cover and you will see a piece of glass 1/2 inch wide 8 inches long. Thats the glass to clean. look very close and you will see something like white out on it. Thank you, Steven 805-520-3003
Jul 07, 2010 | HP LaserJet 3050 All-In-One Printer
When scanning several pages of a document some pages scan fine, some you'll hear a draggin noise and there are smudge lines thru the document (putting thru feeder). Other times when you place 1 copy to be...
Well, if both feeder and pattern glass also having line on print, suspect hardwares problem...
U can check below items:
1. drum
2. laser unit
3. fuser unit
Mar 03, 2009 | Office Equipment & Supplies
Scanning multiple pages
hi,
For you to be able to scan multiple pages using the .pdf and save it in one file, here are the steps that i want you to follow.
SOLUTION I.
1. Open the Solution Center.
2. Click on Settings, then go to scan settings.
3. Click on Scan preferences.
4. Make sure that the "Prompt for additional scans from glass/TMA has a checkmark. then click OKAY.
SOLUTION II.
1. Solution Center is open, click on Scan documents.
2. Scan document settings is open, choose SCAN TO: .pdf and file type is .pdf
3. Click on SCAN below. It will start scanning, and just click on ACCEPT everytime it gives preview on each document.
Thank you.
adonscott
Jul 01, 2008 | HP Photosmart C3180 All-In-One InkJet...
HP LaserJet 2840 Printer Logo
180 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
