Question about Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Memory stick will not load and show up on any computer i have use it on today and i need my a-level work of it, there was no back up on any computer and no copies of my work help
    Scholar:
  • 91 Answers
A simple test would be to try it in another USB port and make sure its all the way in.
You could have a bad USB port or two on your PC/laptop if neither work and that would require that they be replaced or resodered.
or
Check if you see it in Disk Management (Control Panel - Administrative Tools - Computer Management - Disk Management) . Sometimes the partition letters get changed, and it won't show up on My Computer until you re-assign a not-conflicting drive letter.
OR
About the only thing you can try is applying pressure to the stick or slightly twisting it to see if its minor break inside the device and if the computer will recognize it just long enough to get the data off.
check out my site!! http://ctrlr4repair.webs.com
Posted on May 05, 2010
My monitor turns on with a green light and then immediately changes to a yellow light
Sounds like you have no video output from the motherboard. Unplug your desktop computer from the wall so no power is going thru it. Take out all the memory sticks from the slots. Then go ahead and reseat one of them in any slot. Then with the Monitor hooked up turn on the computer. If you still don't get video then repeat the steps and try the memory in each other slot.
If you have more then one memory stick try each one in each slot. If you still have no video after trying all the slots with each different memory stick then that means the motherboard is bad.
If you have a external video card that was installed then take that out and use the internal one that your motherboard came with and swap out the memory using that.
Basically your turning off the computer swapping memory out in each slot and turning the computer back on to see if you get video to come back on.
Feb 05, 2012 | IBM Aptiva E 500 (2158500) PC Desktop
My computer won't recognise my sandisk card reader D33D21? Are drivers available for this on windows 7?
You should not need drivers. Chances are that the drive died. I would try putting this device in another computer first. see the results. The wear leveling mechanism on most of these drives is limited; and it will start "not working" when it's reached the end of life. A professional data recovery company can get it back usually. http://techrxgb.com
Jul 23, 2010 | SanDisk 2GB Memory Stick Micro M2 Memory...
Memory stick pro duo
LLFTOOL is a utility for low-level disk drive formatting,
also supports formatting of FLASH cards using a card-reader.
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format stick pro duo
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Jan 28, 2010 | Sony 1GB Memory Stick PRO Duo Memory Card
How do I read a memory stick in my Dell latitude
hi, just put the memory stick into your card/stick reader port on your laptop then wait a minute or two and if nothing appears on the screen just go into my computer and then you should see the stick listed under my computer, if not then you need to check if your laptop can read that sort of stick.
The kind of memory computers have problem with is like nokia memory cards but all memory sticks should work, if its a usb type stick then this will show up under my computer, it should load up on its own but if not look under my computer.
Let me know how you get on or if you need further assistance ok
Jan 20, 2010 | Dell Latitude D600 Notebook
Memory sticks "MEMORY STICK ERROR" for SONY DSC-S30/S50
this camera doesnt take mem stick pro. has to be the original lavender sticks.msh-ms128 is the model # only goes up to 128 mb. only stick that will work with that cam.
Jun 01, 2009 | Sony Cyber-Shot DSC-S30 Digital Camera
Memory stick does not work
Connect the memory stick to your PC and format there. If it still fails, it's highly likely that your memory stick needs replacement
May 17, 2009 | Sony PlayStation Portable (PSP) Slim...
Memory added to two computers
Usually this means that the memory is not compatible with the computer you installed it on. Try taking the memory you installed out and put the old memory back in there. Then turn on the computer just to verify that it will load. After it loads successfully (hopefully), Shut down the computer and add one stick of memory to the computer. Turn it on, if it doesn't load then the memory is not compatible and if you have more memory then just keep following the steps above till you've tested all of the memory sticks.
Feb 13, 2009 | HP Photosmart M415 Digital Camera
Reinsert the memory stick...
you will need to re formatt the card and this problem should be solved
Jun 16, 2008 | Sony Cyber-shot DSC-W80 Digital Camera
Memory stick
go to setings and go to system setings then go to format memory stick then clik yes. then it will work.
Jun 09, 2008 | Sony PlayStation Portable (PSP) Console
Drivers for sony cybershot for windows vista
There are no drivers for Windows Vista for this camera, nor are there drivers for anything past Windows 98.
If you have a new computer with Vista loaded into it there is a slot for the memory stick in the front. Regardless of the computer the slot should read MS/PRO/DUO. Slip your memory stick in and a screen will pop up showing DRIVE H Memory stick and download from there.
If you have an older computer and upgraded to Windows Vistat there is an adapter you can buy that your memory stick slips into and then plug it in your USB slot. Software needs to be downloaded first from the site prescribed on the package.
I spent over 3 hours today trying to find drivers like you did until I got online and did a chat with a Tech from Sony. Its so simple its silly stupid. Had the slot right in front on my Dell Inspiron PC DUH !!! Good luck Same for Windows 2000 XP, with service pack 3 or 2 or anything past Windows 98 Hope this helps, it worked in a flash once I found out what to do.
Sep 11, 2007 | Microsoft Windows XP Professional With...
Kingston (DTIU3/2GB) 2 GB USB Hard Drive Logo
61 people viewed this question
Top Kingston Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
