I'm trying to connect it to the computer in order to project the computer image onto the screen. It used to work the way it's connected. Now it doesn't.
  • 144 Answers
Check signal cable!
Posted on May 08, 2010
  • zaine khan May 08, 2010
    go to your display option which can be found in ur control panel. click on settings. and check to make sure you have dual display set to on. and that should solve ur problem.
Hi i have just connected up panasonic home cinema system via my projector and the titles etc are back to front any ideas ?? Regards
Trying to understand your problem. Sounds like an orientation problem with your projector. Check your manual to get image orientation setup correctly for your projector. Look for projecting image onto the front of screen instead of projecting image thru the back of screen. Some times the application calls for projecting from behind screen just like a projection TV.
Feb 14, 2015 | Panasonic 5.1 DVD Home Cinema System 1000W...
Infocus lp425z projector pushes latop display to left quarter of output image
Usually this is a hardware acceleration setting problem on the 'advanced' properties setting in your 'screen resolution' properties on your computer. Re-set the hardware acceleration to the 2nd setting and this should fix your issue. We have this regularly when we project on a double projector system and the one projector keeps shifting everything left until we adjust the hardware acceleration settings on the computer. No more issue.
Mar 11, 2013 | InFocus SOFTCASE, LP425Z Multimedia...
I purchased a GigaWare USB-A to Serical Cable at Radio Shack to connect my laptop to my hitachi tv, everything shows to be installed correctly on my computer though there is no signs of the connection...
A USB is to transfer information such as Service codes or commands. Is this what you are trying to accomplish with your laptop or are you trying to display an image from your laptop onto your Projection TV.
To this you would need a 15 pin VGA extension cable and a VGA input connection on your Projection TV.
Blessings always,
A/V Media Tech Guy
Nov 30, 2009 | Televison & Video
Epson Powerlite 710 viewing issue
the fn + f8 should tally between the 2 or 3 different connections for it
If you need further help, reach me via phone at https://www.6ya.com/expert/david_eb7ea98642566cc6
Jul 20, 2009 | Epson ELPLP10S Projector Lamp for...
My toshiba tlp 261 won't project the image
hi try using the function key to toggle the display output form the laptop.every laptop when connected to an external display like projector works in the multiple diplay mode.in this mode the laptop vga output can be seen in 3 modes------ only laptop screen, only external deipaly(projector) & both laptop & projector.check this & this should work fine
any further help contact shyam +919867355202
Feb 07, 2009 | Toshiba TLP 261 Multimedia Projector
Computer used to work with projector, and now doesn't?
Have you tried pressing Fn F5? On my system (HP), by computer monitor goes dark when I connect the projector. Pressing (Function) FN F5 toggles the video between Computer Monitor, Projector, or Both.
Check the function settings for your computer. On my Compaq laptop at home, the video function is F4, so there may be different settings for your computer.
Jan 10, 2009 | Office Equipment & Supplies
Cut off part of projected image
Hi-
Try changing the cables and try setting the resolution to 800x600 on the computer.
hope this helps
Aug 25, 2008 | Epson EMP-S3 Multimedia Projector
Toshiba laptop satellite model cuts off screen display when connected to Sharp model XR-10X projector
Try to check your keyboard if there is an Fn command then press on hold together with F6/F7 or some keyboard only identify with an icon that similar to project or computer screen icon.
Please rate me solve if you like my solution.
Best regards,
Philip
Nov 17, 2007 | Toshiba Satellite A105 Notebook
Why is my projection dark and muddy compared to the brightness on my computer screen?
John here, customer advocate at Dell headquarters. If you can nvigate to the On Screen Display Menu, you should see an "all images" section on the main menu. There you will find brightness, contrast, color temp, white intensity, and gamma controls. You should be able to make adjustments from that menu to sharpen and brighten the image.
May 03, 2007 | Dell 1100MP DLP Projector Multimedia...
91 people viewed this question
k24674
jasbo
jasbo
