Question about Coby CX-TV1 5 in. Portable Television
What do ineed to watch this tv now that we have digital services
Will i need a converter box? The seniors wants to know .
  • 736 Answers
Yes you do. Not only do you need a convertor box but an antenna to connect to the convertor box. The convertor box will have to be plugged in and depending on the antenna it might have to be plugged in. This tv does allow and external antenna to be connected to it. This is where you will attach the convertor box with whatever adaptor you may need. The tv will need to remain on channel 3 at all times.
Posted on May 05, 2010
Can I connect two tv to one television converter box to watch local channels
If neither TV has a digital TV tuner, you will only be able to watch one channel on both TVs with one converter box. You will also need some sort of RF repeater if you want the person in the second room to change the station without moving the box. You will need a splitter/amplifier connected to the converter box TV out. (I'll assume you are using the coax out.) If you will only watch one TV at a time, then use an A/B switch on the converter box TV out.
If one of the TVs has a digital tuner, put the splitter/amplifier between the antenna and the converter box and the TV with the digital tuner.
Note: amplifier/splitters and switches do fail. If you get a "no signal" message, take out the splitter and connect the converter box directly to the antenna or one of the TVs depending on your set up.
I hope this helps.
(I use an A/B switch between the antenna and the TV and converter box for feeding an old VCR/DVD recorder.)
Mar 08, 2013 | Televison & Video
Can you please advise which external tv tuner will work for SONY trinitron kv-xf21m80 model? My SONY crt tv tuner is not catching most VHF B/G channels. i sought the services of an authorised service...
If you have a cable box and can set your TV to channel 3 then you should be able to watch cable. If you want to watch over the air broadcasts then you need a digital converter box which you can buy at Best Buy for around 40 dollars. You use the converter box as the tuner and set your TV on channel 3.
http://www.bestbuy.com/site/Coby+-+ATSC+Standard-Definition+Converter+Box/9663904.p?id=1218140711965&skuId=9663904&st=digital%20converter%20box&cp=2&lp=5
Dec 24, 2012 | Televison & Video
I have a problem, I purchased a Digital TV and it doesn't work
You can get a replacment from the maker of the digital converter. You will need to mail in the old unit but they will send out a replacement
Nov 12, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have an old TV, which is now connected to the digital-analog converter box. How do I add a DVD player to this (it's so a not very mobile senior citizen can watch movies). Thanks very much!
You need an RF convertor (available most electronis stores -Walmart) Check instructions of RF converter purchased
Guideline:
The video audio cables (R,W,Y) should be connected to the matching colors on the RF converter and the RF cable (standard cable)should be connected from the RF conv. where it say "to TV" to the TV and the TV should be set to either Ch3 o Ch4 (you can usually choose on the RF conv.) the cable from the cable provider should be connected to where it says "in from antenna or cable in on the RF conv.
Oct 19, 2009 | Apex Digital AD-1165
So you are telling me I need a digital converter for this TV to g
Who was not watching the months of public service announcements? You need a Digital-to-Analog (ATSC-to-NTSC) converter box to receive over-the-air (OTA) signals in most parts of the country. You do not need one for most cable and satellite box outputs--they are NTSC or HDMI. Some low-power, typically religious, stations are still analog. Note OTA may be high definition (HD) or standard resolution (SD) but will be digital.
To get HD on your HD set you must have OTA (HD TV tuner, not converter), cable (QAM TV receiver), satellite (HDMI or 5-wire RCA),or Blu-Ray with HDMI or RCA.
-Ken
Aug 18, 2009 | Hitachi 46F510 46" Projection HDTV
Are my Orion tv's purchased in 2002 digital ready
Your TV does not have a digital tuner. You'll need a converter box for digital broadcast reception. Remember that if you're on a cable system or using a satellite receiver, your TV doesn't need to have digital tuning. It's only if you want to watch off-the-air broadcasts that you'll need the converter.
May 12, 2009 | Orion STV2763 27" TV
36A50 Digital ready?
Hi duce1500,
Unfortunately, the 36A50 is not HDTV-ready. That means you will need a converter box. Here is a link to the model's specs, which includes this information:
http://www.amazon.com/Toshiba-36A50-36-TV/dp/tech-data/B00004YMBV/ref=de_a_smtd
I should mention, however, that if it's connected to cable (or certain satellite services), you won't need a converter to watch the TV - you'll receive the digital signal (although you won't have the 1080-pixel HD resolution - the 36A50 only has 850 lines of resolution).
I hope this helps. Please let me know if I can be of any further assistance.
H2H
Dec 13, 2008 | Toshiba 36A50 36" TV
Need to know if my tv is digital or analog?
most new tv's are digital capable...
but here is the trick the convertor box are only for those who don't have cable or satellite service if you use only an antenna to get channels then yes you will need a converter box for each tv that uses only the antenna to get channels if you have satellite or cable service then they don't need a converter box even if they have basic cable they won't need the box there channels are already digital converting now there are a few events that was in anlog but there are being converted as best as possible but you may notice the difference in the pictures betwwen analog (usaully old time movies or show even commercials) Digital (most everything now that are new stuff are digital and even in hd now)...
Nov 12, 2008 | Televison & Video
Digital
Nope. Not a digital Television. I'm guessing it's an older one. Most TV's sold nowdays are Digital TV ready.
Jan 02, 2008 | RCA F32665 32" TV
Coby CX-TV1 5 in. Portable Television Logo
200 people viewed this question
Top Coby Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
