Question about Scotts Company Scotts& Accugreeen 3000 Drop Spreader 3 Pack
On a scotts drop spreader 35-3, what setting would give me 3.2 pounds rate for fertilizer
  • Anonymous May 05, 2015
    here ya go:
    3 lbs/1k sq ' 4 lbs/1k sq ' 5 lbs/1k sq '
    -------4-------------5-------------6-------
SOURCE: I have a Scott Rotary Fertilizer Spreader. When I
If the wheels turn( that is you can push the spreader easily) but the vertical shaft that spins the broadcasting plate doesn't, seems like the gears connecting the axle to that vertical shaft are worn; but if the wheels just slide along the gropund without turning then it would seem something right under the bin is keeping the verical shaft from turning. But I'm NOT an expert; I'm looking for an answer myself,
Posted on Mar 16, 2009
  • 125 Answers
SOURCE: need to apply lawn fertilizer at a rate of 5 lbs,
http://www.gardentech.com/spreadersettings.asp
this is a link which will help you. Your setting should be on 7-8 using a criss-cross distribution pattern
Posted on Sep 07, 2009
Testimonial: "thanks pal, worked great"
SOURCE: I have a Scotts Accugreen 3000 Drop Spreader. How
I found drop-rate tables at http://www.vigoro.com/ProductCategories/WeedInsectControl/SummerFertilizer/ProductDetails/Spreader+Settings.htm and http://www.bayeradvanced.com/media/productlabel/502840A_label.pdf. I don't know how accurate they are, but they are consistent with one another so I'm using them :)
Posted on Mar 21, 2010
  • 8 Answers
SOURCE: I buy Scotts fertilizer and use an earthway broadcast spreader.
add 10 - Scotts Turfbuilder spread at # 4 on a Scotts spreader should be on setting # 14 on an Earthway spreader.
Posted on May 06, 2010
vincob
  • 718 Answers
SOURCE: I have a Scotts Basic
Start with #3 setting. You will be fine I have same spreader.Good Luck..
Posted on Apr 22, 2011
Testimonial: "Thank you for the help. I had pretty much settled on the 3.25 setting after reading the back of a Scotts Turfbuilder 17 lb. bag of similar ingredients"
I have a new Scotts Classic Drop spreader and an old bag of 16-4-8 fertilizer. 2,130 SF of Zoysia Zeon lawn. According to my guidance I need to spread 6.5 # of the 16-4-8 fertilizer over the entire area....
Does the product you are using list any Scotts AccuGreen spreader settings? If so, you can safely use the spreader settings listed for the Scotts AccuGreen. If your product does not list any spreader settings, please give Scotts a call at 866-465-5160.
Hilary @Scotts
Aug 27, 2011 | Scotts Company Scotts Turf Builder Classic...
I have scott drop spreader and I want how it will setting for fertilizer
Check the fertilizer bag for instructions. It will tell you the number to set it at for a drop spreader and a broadcast spreader.
Aug 14, 2011 | Scotts Company Garden
I just bought a new Scott's "Classic Drop" Spreader. I owned a Scott's drop spreader before and the recommended settings on Scott's fertilizer bags always worked great. On...
I am sorry that neither spreader performed as they should have. This is very concerning to us, and we would like to get more information about the spreaders, if you still have 1 the manufacture date would be most helpful to us. It sounds like you could possibly have an over-application of the product as well. If you could call us at 1-800-543-8873, we would be happy to discuss this with you. Stacey at Scotts.
Jun 06, 2011 | Scotts Company Scotts Turf Builder Classic...
I have an antique scotts metal drop speader # 35-3. Probably at least 30+ years old. The setting bar goes from 2 to 18. Scotts fertilizer products use different setting numbers that correspond to newer...
That model is a little over 45 years old, gotta love those metal spreaders! Many times the new Drop spreader settings will work for the older models as well, you just have to make sure it looks like its dropping at the right rate. That can be a little troublesome, but if you can estimate about 1/4 of the bag and cover the proper area for that amount you should be good to go. You can always give us a call and confirm settings with us first at 1-800-543-8873. Stacey at Scotts
May 29, 2011 | Garden
I have a 35-3 spreader and cannot find the setting rate to apply 3.5# of product to 1000 sq ft
I have a Scotts calibration bar which I used according to their instructions and the unit (a 35-3) still does not perform correctly. Therefor I used a tried-and-true method to make my own calibration.
1) get a large tarpaulin, the bigger the better. Lay it on a flat surface, as level as possible. Measure the tarp to determine the area.
2) Pick a setting. I would suggest starting with "5". Load up your spreader and go back and forth over the tarp as though it were your grass.
3) Dump what you have collected on the tarp into a container and weigh it.
4) Perform high school arithmetic operations to determine the pounds per square foot delivered and adjust accordingly. Obviously, different products will perform differently and this will have to be done for each different product.
5) Down at these low numbers it doesn't take much change in setting to make a big change in the delivery rate. The Scotts representative also noted that the speed at which you walk can affect the rate. As you walk more slowly the spreader will deliver more product.
Mar 01, 2011 | Scotts Company Scotts& Accugreeen 3000...
As the cyclone brand spreader is "gone" from use, what are the equivalent settings to currently match spreading rates as listed on fertilizer bags for spreaders currently in use.
CYCLONE ROTARY
2.0
EARTHWAY ROTARY
6.0
EV-N-SPREAD
6.0
K-GRO ROTARY
.75
ORTHO ROTARY
.75
PRECISION ROTARY SB50
1.50
RED DEVIL ROTARY
1.50
REPUBLIC EZ ROATRY
.75
SCOTTS SPEEDYGREEN 1000,2000,3000
2.12
SCOTTS BASIC BROADCAST
2.12
SCOTTS EDGEGUARD BROADCAST
2.12
SEARS ROTARY
.75
TRUE TEMPER ROTARY
1.5
VIGORO ROTARY
1.50
SCOTTS STANDARD ROTARY
2.12
CRAFTSMAN
6.0
SCOTT’S EASY GREEN
25
SCOTT’S HANDYGREEN
__________________________________________
Drop Spreaders:
K-GRO DROP
2.25
ORTHO DROP
2.25
REPUBLIC EZ DROP
2.25
SCOTTS ACCUGREEN 1000
3.0
SCOTTS ACCUGREEN 2000
3.0
SCOTTS ACCUGREEN 3000
3.0
SCOTTS DROP PF1, PF2, PF3, PF4
3.0
SEARS DROP 2.25
Apr 29, 2010 | Scotts Company Scott'S& Lawn Pro Spreader...
Mar 28, 2010 | Earthway "Earthway" Medium Duty Commercial...
How do I calibrate Scotts Accugreen 2000 for pounds of Fertilizer per Sqft. What do setting equal?
To adjust calibration, do the following:
1) Adjust the micrometer setting to 6.
2) Turn the spreader over.
3) Squeeze the trigger against the handle.
4) The front edge of the shutoff bar should be aligned with the calibration line engraved on the bottom of the hopper.
5) To adjust alignment, use a small wrench to turn the black calibration screw at the lower end of the control wire leading from the micrometer insert.
Note: If the hopper is missing a calibration line - with the setting at 6 they should be able to pass a 9/64" drill bit through the opening just to the right of center. (First opening to the right of the spring.)
Nov 08, 2009 | Scotts Company Scotts& Accugreeen 2000...
Need to apply lawn fertilizer at a rate of 5 lbs, per 1000 sqare feet, what setting do i need on my scott's speedygreen 3000 broadcast spreader.
Sep 07, 2009 | Scotts Company Scotts& Accugreeen 2000...
Model 300 runs out of fertilizer
Since I didn't have a manul, I downloaded one from Scott's and used that to calibrate the spreader which was out of calibration.
Apr 08, 2009 | Scotts Company Scotts& Accugreeen 2000...
Scotts Company Scotts& Accugreeen 3000 Drop Spreader  3 Pack Logo
1,363 people viewed this question
Top Scotts Company Garden Experts
john h
Nick Olsen
jhnolson
Are you a Scotts Company Garden Expert? Answer questions, earn points and help others
