Canon PC-850 Did you ever get your PC-850 E001 problem fixed? I have the same problem on my PC-850. Any tips? Thanks!
  • 1,326 Answers
A E001 code is a fixing error code. It has to do with the heating lamp or the thermister or the thermal fuse or it could be all 3. Dose the fixing lamp turn ON. If no it is the fixing lamp or thermal fuse. If it turns ON and warms up and then codes out then it is the thermister. It could also be the whole fixing unit is bad.
Posted on Mar 28, 2008
The copier's lamp does come on for a split second and then I hear a click sound on the rear corner of the copier (near the power cord area) and then it goes off.
Ir 3300 000001-0002 error
Title : E001 Error Code That is Not Resetable Error : paper jam
When the machine powers up the E001 error code is displayed but cannot be reset. (Note: The reset procedure for an E001 code is COPIER>FUNCTION>CLEAR>ERR)
Workaround :
In this case, the Main Power Supply PCB Assembly was replaced. The machine was powered up and the E001 code was able to be reset. The part number for the Main Power Supply Assembly is FM2-0260-000.
Remember, if the fixing unit circuitry has an open or a short, the code may not reset. Be sure to confirm the fixing unit wiring and try resetting the code before replacing the Main Power Supply Assembly. Canon USA, Inc. Systems & Technical Support Division1-800-528-2830
Aug 13, 2013 | Canon Office Equipment & Supplies
Canom imagerunner 2520 error e000001
the e001 is error for the temperature rise detection in fixing unit. There are more sub codes that I need to know for precise troubleshooting. i.e. E001-000 or E001-001 or E001-002
But if there is no fault in components, you can try to reset it in service mode.
Procedure:
additional function, then press 2 and 8 then go in clear by pressing scrolling, then go in engine, then choose ERRCLR and then turn off and on the copier.
If these doesn't helps you need to replace fixing film unit.
Aug 29, 2011 | Canon 0000A011BA Copier
I have an System ERROR E001 following Error E808 on my canon 2016j copier and waht shal i do me out guys
E001 0000 Abnormally high temperature (detected by main thermistor)
The main thermistor detected an
abnormally high temperature (240 deg
C) during temperature control.
- Check the connector of the fixing film unit.
- Replace the fixing film unit.
- Replace the DC controller PCB.
E001 0001 Abnormally high temperature (detected by sub thermistor)
The sub thermistor detected an
abnormally high temperature (295 deg
E808 0000 Fixing drive circuit failure
- The heater does not turn on.
- A fixing drive motor failure was
detected.
- Replace the fixing drive motor.
- Replace the power supply PCB.
Feb 19, 2011 | Canon iR 2016i Black and White Copier
I have canon ir6570.its shows e001-001,e001-0010 repeatly
try to clesr the err. from service mode ( * 2,8 * ) function - clear- err- press ok
if not ok
you have a problem in the fixing unit
Apr 01, 2010 | Canon IMAGERUNNER 6570 Copier
E001 switch off the machine and on again
E001 is a fixing assy fault you have to clear the error in service mode after correcting the fault of course. I would try clearing the error code in service mode 1st. press *28* function tab clear tab error ok then restart copier
Sep 09, 2009 | Canon imageRUNNER 400S Copier
My canon NP6012 flashes E001. Copier flashes and
check also the thermal fuse or switch ,no ac supply is coming to fixing heater
Jul 10, 2009 | Canon Office Equipment & Supplies
Canon PC-850 E002 Error Code
After some searching, it appears that this error is common on all Canon Copiers. It means that "Fusing unit not heating up" This is most likely due to a bad fusing unit, or a component the fusing unit. Recommend replacing Fusing Unit.
Mar 19, 2008 | Office Equipment & Supplies
190 people viewed this question
jasbo
jasbo
