Question about Brother SX-4000 Typewriter
I had to replace the tyoing ribbon but I can't seem to get the correction tape to work after reinstalling it. The visuals are not clear enough in the User's Guide to see where I might be wrong in the placement or the ribbon.
  • Brother Master
  • 3,594 Answers
Go to brother.com, click on support tou will find a manual there.
DickyO
Posted on May 12, 2010
Keyboard ribbon connector on the motherboard
Cut a piece of sturdy clear plastic packaging material (like memory packaging, etc.) or extra ribbon cable - cut it the width of your ribbon cable and long enough to handle.
Insert your ribbon cable into the socket and then insert the clear plastic or extra ribbon cable you cut to size into the socket above the ribbon cable.
This usually will hold the ribbon cable in the socket snuggly with enough pressure not to move and make a good contact for proper operation.
If you want cut and add a small piece of high temperature electrical tape to the socket, insert and cable. I do not recommend scotch tape as it becomes googey at high tempersture.
Feb 11, 2012 | Toshiba Computers & Internet
I changed the correction tape on our IBM wheelwriter 3 and it doesn't seem to be lifting the error. Any advise? The correction tape is not old and I had already tried moving it a couple of inches but it...
You may have a very old correction tape or ribbon, a non correctable ribbon or it isn't properly installed
Go to LEXMARK.COM for a downloadable manual.
DickyO
Mar 31, 2010 | Lexmark Wheelwriter 3 Typewriter
The correction tape is not working properly. Wheelwriter 1000
If everything was working befor the ribbon & L/O change Either the L/o is not properly attached to the ribbon or the ribbon and or L/O are old. Make some corrections then remove and look at the L/o, if the letters are near the center of the L/O the problem is the ribbon or L/o is old, if the print is on the top of the tape it is not properly attached to the ribbon or not coming out or the cassette properly.
If you have a fresh set or another T/W that works swap the ribbons and look at how they are attached.
For a picture ngo to lexmark.com and click your way to publications you will find a downloadable manual there.
DickyO
Jan 23, 2010 | Lexmark Wheelwriter 1000 Typewriter
Need visual instructions to change ribbon
Move the blue lever on the R. side of the ribbon to the rear and lift the ribbon out unsnap the correction tape from the bottom, reattach the correction tape to the new ribbon. Insert the the two small tabs on the rear of the ribbon into the slots in the ribbon deck and snap ribbon into place. For apicture go to lexmark.com, click your way to publications and you will find a manual.
DickyO
Oct 19, 2009 | Lexmark Wheelwriter 15 Series II...
IBM Correcting Selectric II; correction ribbon frozen in front of typing ribbon.
Move the grey lever on the R. side of the carrier to the R. and remove correction tape, try the machine, if it seems to work OK install a new correction tape.
DickyO
May 28, 2009 | IBM Wheelwriter 30 Typewriter
Correction ribbon balls up after a short time.
Be sure that you have a dry L/O tape Gen. Ribb. # t355 or equivwlent if you are using a tacky ribbon it will give you fits.
DickyO
Jan 19, 2009 | Smith Corona Office Equipment & Supplies
Liftoff tape doesn't work properly
It could be the ribbon is not seated properly try removing it and reinstalling, or did you remove the tab from the ribbon cartridge top either orange or red coler and did yo wind the lift off tape into the takeup spool show the leader is no longer exposed?
Aug 20, 2008 | Office Equipment & Supplies
Correction Tape
The correction tape which should be a yellow spool and the correction ribbon cartridge should be a yellow also, sometimes orange, first. The correction tape has to in front of the black correction ribbon. in othe words this is the order. Platen, paper, correction tape, correctable film ribbon, printwheel. Also make sure correction tape is dull side toward paper. Shinny side should face operator...
Aug 12, 2008 | Brother ML-100 Typewriter
Correction Tape
Two possibilities, one the correction tape is twisted and the wrong side is .facing the paper. The shinny side should be facing you, the dull side facing the paper. Second possibility you must make sure the ribbon is compatible with the correction tape. There are 2 types of ribbons. A correctable one (orange or yellow knob) and a multi strike (blue or purple knob on ribbon cartridge). The lift off correction tape (orange or yellow spools) only works with the correctable ribbon and the cover up correction tape (blue) works with the multistrike ribbon.
Jul 17, 2008 | Brother ML-100 Typewriter
Correction tape not working on this model
This T/W has 2 tapes a black ribbon and a lift off tape the L/O tape has to be a tack free type General Ribbon T355 or equivelent. It installs below the ribbon on the left and feeds to the right.
Dec 14, 2007 | Nakajima AX-150 Typewriter
Brother SX-4000 Typewriter Logo
51 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
