Question about Samsung SCX-4725FN All-In-One Laser Printer
My scx-4725FN makes a grinding sound when I turn it on. It sounds like the gears are grinding. It will not feed paper and reports paper jam. I also smell heat from the machine. Periodically it reports that it is overheating. I have solved that problem by unplugging the machine and plugging it back in. This machine has had very little use. Only recently went through the first toner cartridge that came with the machine. I can't find an easy way to access the gear area of the machine.
I have the same problem... just added toner for the first time. Have you fixed it yet?
Posted on Aug 23, 2010
Keep getting out of paper error and paper wont feed makes loud grinding noise
A screw or something else is in the printer not allowing the gear to move freely.
Apr 22, 2015 | HP C6280 Photosmart All-in-One Printer...
Copier will not copy feed paper oeven try-justs makes agrinding noise
Dear
Pl. do test as per following.
1- empty paper tray.
2- pull the toner cart. and close the door.
3- power ON the printer. Listen the sound of initial motor run,
(If smooth not grinding noise, check the toner cart OPC drum for jam. If yes check the fusser drive gear and fusser gear and assembly)
If all are ok.
4- Check the paper pick up roller shaft, (sometimes it takes a bunch of paper and jammed if you forcible pull the bunch in reverse direction the shaft may gets bend cause the grinding noise during paper pickup. in that case you have to replace the paper pickup shaft.
Thanks.
Mar 10, 2015 | Samsung SCX 4521F All-In-One Laser Printer
My scx-4725fn printer doesn't print. and gives the error message what should i do?
what is the error message that it gives you ? the most common on these printers is the paper feed error the machine will not pick up paper. the feed tire is right below the toner system and the feed tire gets dirty and wont feed paper. if this is the case the feed tire needs to be cleaned. you should take it to a dealer for this cleaning because it is hard to get to the whole tire with out knowing what to do.
Feb 02, 2015 | Samsung SCX-4725FN All-In-One Laser...
HP 1315v Printer Makes grinding noise and won't feed paper anymore
It sounds as though a sheet of paper or an envelope bunched up and has jammed inside. Until that is removed from the feed roller, you will continue to hear the 'grinding' sound, and won't be able to print anything. Remove the cover from the backside of the machine, then locate and remove the obstruction. If you don't have any such obstruction then you have a mechanical defect which is not user repairable.
Oct 20, 2014 | HP PSC 1315 All-In-One InkJet Printer
The envelopes continue to get jammed and won't feed properly something with the rollers?
it happens when the paper feed rubber rollers get extra smoothened.just ope up the printer and scratch the rollers a bit with wall scratch glass paper. it will again grip the paper properly after that.its a common issue and gets solved easily.thanks.
Jul 08, 2009 | Samsung SCX-4725FN All-In-One Laser...
SCX 4725FN - pulling in two sheets at a time, and jamming
Try fanning the paper. In conditions of low humidity, the paper will tend to stick together. Also make sure the feed roller is clean. Use a cloth with some alcohol on it and clean the surface of the feed roller.
Mar 17, 2009 | Samsung SCX-4725FN All-In-One Laser...
Paper jam error, check everything but still showing paper jam
turn off the printer
Unplug it
open the paper jam door and gently push the paper roller forward until it clicks.
close the door
wait a few minutes
plug the printer back in
turn it on and see what happens.
I hope this helps.
Aug 18, 2008 | Samsung SCX-4725FN All-In-One Laser...
Shredder that sounds but doesn't feed
sounds like you probally have a stripped or broken drive gear. Contact manufacturer for parts availability.
Sep 15, 2007 | Royal VF1000MX Shredder
Samsung SCX-4725FN All-In-One Laser Printer Logo
321 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
