Question about DBX DriveRack 480 Processing Unit Home Equalizer
DBX PA+ no settings for Yorkville EF500P and LS801P
How do I setup a custom preset with these Yorkville speakers.
DBX is not clear on setting up custom speakers.
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 232 Answers
Yeah that is because Harmon makes JBL speakers and Crown amps..for Yorkville Speakers use the VTC DLMS4080 Speaker processor, it blows the Drive PA away...
Posted on Sep 20, 2014
2 Suggested Answers
welcomejee
  • 10594 Answers
SOURCE: manual for dbx eq system set-up
Check out 12 Series User Manual might help you.
Posted on Oct 09, 2008
I was think of buying 4 yorkville ls801p to add to my collection. What is your opinions of these speakers or should I stay with ev etc 18sp
well from where I sit adding more to what you already have is never a bad thing why I say this is it will allow you to expand and cover a much bigger area so I say yes go for it
Mar 08, 2016 | ETC Music
Good day..The common problem in a closed pa system setup is feedback.It limits the capacity of unit to give a higher intensity of volume..With this I just want to ask if DBX Driverack pa+ will work well...
The DBX driveracks work well with about any PA. The only PAs you might encounter a problem with would be one of the newer line array and digital processing PAs. Let your audio person get creative, the presets for multiple PAs are just a guide. If your sound person is confident and is qualified, let him/her experiment and/or rehearse - you'll be amazed at what that system is capable of.
Mar 10, 2011 | DBX Driverack-Pa Eq/Speaker Control System...
DBX Driverack PX "Wizard" not allowing MONO
set it up as mono=common leads together and l,r,leads together,it will see left and right are in use and should load up
Jul 05, 2010 | DBX Driverack-Pa Eq/Speaker Control System...
Auto eq wont turn off
You have to press the STORE button. Also, this will only save to the preset you're on and has no effect on other presets. So if you're on preset 1 and you disable EQ then press STORE you've only turned it off for that preset. #2, 3, etc. will still be enabled.
After you press STORE will show you something like this:
STORE: ROCK VENUE
Replacing
U1 DJ Setup
PRESS STORE TO ADVANCE
Rotate the DATA whell to select the program to be replaced and press STORE. The existing program (the one that had EQ turned on) will be replaced with the new program (the EQ turned off). If, for example, you do this to preset 1, now every time you dial to 1 you'll have the same, no EQ setting.
Jan 23, 2010 | DBX Driverack-Pa Eq/Speaker Control System...
Can someone help me how to custom set my Amp & speaker in a dbx drive rack system
By far the best way to do this is to have an RTA microphone. Set speakers and amp to custom, then run the wizard to pink the room. Then make sure to set up the gain structure (pg. 41 of the manual available online).
Although it's satisfying to see the name of your speakers and amp listed, if you follow the procedures above you'll end up with the same results -- a properly EQed room and an optimized gain structure.
Oct 26, 2009 | DBX Driverack-Pa Eq/Speaker Control System...
When going through the driverack pa setup wizard, where is the "custom" speaker setting?
You should be able to spin the dial all the way to the end of the list of speakers and there you should see custom.
Jul 15, 2009 | DBX Driverack-Pa Eq/Speaker Control System...
DBX DriveRack 480 Processing Unit Home Equalizer Logo
492 people viewed this question
Top DBX Audio Players & Recorders Experts
Chickenwatt
Level 1 Expert
Themcramers
Level 1 Expert
Tom Chichester
Are you a DBX Audio Player and Recorder Expert? Answer questions, earn points and help others
