Question about HP Pavilion dv6000z Notebook
HP dv6604nr 15.4in Laptop powers on beeps three times...
Then there is no screen function. What might be the problem?
    Guru:
  • 1,481 Answers
If you cant see anyting on the screen after power on...then i am sorry the motherbaord is out...
all black and blank screen just call for change of MB
Posted on May 05, 2010
Testimonial: "Great! very helpful, thank you."
Does not open the windows and any time pressing the power it makes sort of noise (three time warning sound) - and you have to keep on and off the power for many times until screen display
This sounds like your computer is failing the POST (power on self test). Three beeps usually is a signal that your memory is having a problem. I would suggest swapping out your memory chips. var fctb_tool=null; function FCTB_Init_f3908b02230b4b68b50650d620fa2342(t) { fctb_tool=t; start(fctb_tool); } var fctb_tool=null; function FCTB_Init_1f95b96e4b914361be5de3675c63eec0(t) { fctb_tool=t; start(fctb_tool); }
Jan 26, 2011 | HP Pavilion dv6000z Notebook
My laptop does not boot to windows xp and instead beep three times. The power light flashes with every beep
The three beeps is a warning that the Power on self test reports a failure of hardware. it could be video, memory, Hard Drive, etc. If you can get into the diagnostics, you can tell more. If nothing works, It may be the motherboard.
Dec 29, 2009 | HP Pavilion dv1000 Notebook
Problem for HP HP Pavilion dv2000 15.4" Notebook Laptop PC The power is OK but I get 1 long beep and 2 short beeps when switching on, the screen remains blank and no activity on the laptop
Disconnect all devices from the power supply EXCEPT the motherboard
Remove any extra cards including video etc.(plug monitor into the onboard)
If you hear any beeps these can indictate where the fault is.
either of these sites below will help you further with that
Beep codes Pc
More beep codes
Power up the pc and see if the fans are working.
If not then double check the power connections to the board.
If you still have no fans it is time to suspect the power supply as the probable cause.
If the fans worked then you should have gotten a display which told you there was an error and offering you a chance to go into the BIOS. ignore it and shut down the PC.
Now connect one drive only and boot again.
Repeat that until you identify the component that is giving you a problem.
Once you find the problem then remove or disconnect and carry on with the rest to see if another component might also cause a problem
If there is only one problem device then you may want to investigate that device further, Unless you don't mind replacing it
Hope this gives you the information you need
Bob
Moderator
It would be very decent of you to consider the quality of our experts answers and judge them accordingly as you pass through FixYa.
Thank you
Dec 13, 2009 | HP Pavilion dv6000z Notebook
First on with three beep with no display while now just on and of
you have a number of different codes.Is it 3 short beeps?or is one longer then the other?
If its 3 short ones,then try these.
the cpu could not be compatible,or needs to be replaced.
the memory chips could be bad.
Its hard to track down the problem without more information.I need to know if its an ami bios or something else.And I need to know about the beeps themselves.
Aug 28, 2009 | Computers & Internet
System not booting
Try power cycling the laptop by taking the battery out and pressing the power button 10 times. On the 10th time, hold it down for 10 seconds. Put the battery back in and attempt to boot the laptop.
If that doesn't work, listen for a cooling fan when you attempt to boot the laptop. If you don't hear the fan, it's likely that the motherboard is malfunctioning somewhere.
Do you hear any beep codes when you try to turn it on? Here is a list of beep codes for reference:
No Beeps: Short, No power, Bad CPU/MB, Loose Peripherals
One Beep: Everything is normal and Computer POSTed fine
Two Beeps: POST/CMOS Error
One Long Beep, One Short Beep: Motherboard Problem
One Long Beep, Two Short Beeps: Video Problem
One Long Beep, Three Short Beeps: Video Problem
Three Long Beeps: Keyboard Error
Repeated Long Beeps: Memory Error
Continuous Hi-Lo Beeps: CPU Overheating
Hope this helps! Good luck!
Aug 10, 2009 | HP Compaq nc6000 Notebook
On power up my HP pavillion beeps three times, the screen will not power up
There is references to beep code in manual.
I think 3 beeps refers to a faulty video card.
Jul 27, 2009 | Computers & Internet
Laptop won't boot up.
it looks like your rams are broke down. can you write your notebook model /mark down ?
May 27, 2009 | Computers & Internet
Downgrade from vista to xp. Hardware drivers missing
You need to download the equivalent XP drivers for your HP Pavillion.
Here you go:
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&dlc=en&cc=us&lang=en&product=3548343
Hope this helps.
Mar 17, 2009 | HP Pavilion dv6604nr PC Notebook
Laptop is not booting and beep three time
i have this problem... my laptop still doesent work but to switch it on just rap it in towels or clothes or even put under ur pillow and leave it there for half an hour keep on doing this and it will switch on thanks
May 04, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
HP Pavilion dv6000z Notebook Logo
81 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
