Question about Rainbow E series Canister Wet/Dry Vacuum
Rainbow SE (1991)
1. Impeller assembly: There are 3 aluminum impeller disk assemblies. In what order are they assembled on the shaft? In what order are the spacers installed?
2. Who sells a power switch for this unit? The switch incorporates 6 wires out the back side.
  • 25 Answers
Little fan first, then hour glasss spacer washer side down then larger fan, with spacer sticking throug then small fan. then normal spacer. assambley starting from top part down, your local vacuum cleaner shop should have switches or contact rainbow, but will be cheaper to go local store
Posted on Mar 26, 2008
SOURCE:
How do I get to the impeller on my Hoover steam vac dual v to get to the rotating brushes to fix their rotating
First, there is no impeller that turns the brush. It is controlled by a turbine assembly. There is the brush with the middle stem (know as the brush block) and the turbine turns the brushes.
Turbines cost $39.00
Brush Block Assembly cost $34.00
Called our store on Monday to order. 937 291 3560
www.daycinvac.com
Sep 27, 2014 | Vacuums
Why does my 1521 overheats and turn off
Its probably full of dust and lint, and most likely has something wrapped around the motor shaft. Take it apart and inspect in and around the moving parts of the motor, impeller, shaft etc Best way if you are not too handy and poor memory. Either make a video of disassemble or detailed diagrams as you take it apart. It will make your life a lot easier when you re-assemble it!
Aug 30, 2014 | Electrolux Diamond Jubilee 1521 Vacuum...
Looking for a Kirby G4 impeller?
Hi There. Here's the Impeller Blad, or Fan assembly for your Kirby G4. Hope this helped you.
Please leave feedback or rate the repair helpful if this answered your question, thanks!
Kirby Impeller Blad Assembly
Thanks so much,
Chris Jones
GoVacuum.com
Dec 29, 2010 | Kirby G4 Bagged Upright Vacuum
It won't pick up the water
sounds partially clogged, remove bottom plate and the rear exhaust assembly, make sure all passages are clear for anything stuck to it, check around impeller for same, hope it's not just full
Jan 31, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Replace Kirby legend II fan (impeller blade)
In order to replace the fan you will buy a 2 or three piece lexan fan kit containing the fan a spacer and shaft.
You must remove the carpet head and then looking from the back of the machine you will find a series of philips screws on the outer edge of the fan housing facing towards the front, several of which may be partly covered by the motor housing. You will remove the forward facing screws to allow the housing to separate and reveal the fan.
If you are lucky there will be a sideways hole through the impeller shaft allowing you to slip a nail through to help twist the saft to unscrew it while holding the fan .
The shaft will turn off revealing a threaded motor shaft with spacers which the broken fan will slide off revealing a second spacer at the back . Be sure to replace these spacers in the same order when re-assembling the unit. Secure the shaft hand tight. Post back to advise if you need further help
Oct 07, 2009 | Kirby G4 Bagged Upright Vacuum
Weak suction on rainbow se vacuum
Check for clogs in the nozzle air passages (remove bottom plate)
Check for clogs in the wand
Check for clogs in the hose (trow in a pebble or a penny and see if it comes out the other end)
Make sure separator is clean.
Remove exhaust cap (sometimes there is a sponge in the cap that gets disty and does not let the air pass through).Have in mind that it will not pick up well if the suction and the belt is good but brush roll bristles are worn and too short.
Good Luck,
Rocky
Dec 21, 2008 | Rainbow 75th Anniversary Canister Vacuum
Rainbow Vacuum Cleaner starts slow smells hot
Sounds like the motor is going bad and will eventually not start. I am in the process of changing the motor in mine too and they are not cheap. just search around for a motor
Aug 31, 2007 | Rainbow E series Canister Wet/Dry Vacuum
Open Questions:
See all Rainbow E series Canister Wet/Dry Vacuum Questions
Rainbow E series Canister Wet/Dry Vacuum Logo
250 people viewed this question
Top Rainbow Vacuums Experts
Chris Nomland
Chris Nomland
JoeVacs
Are you a Rainbow Vacuum Expert? Answer questions, earn points and help others
