Question about Maytag Neptune MAH5500B Front Load Washer
No power to control board
Power source is good to control board however, it remains blacked out.  no led light, nothing. Light comes on at the door when opened.  wondering if that may be my only problem, wife stated that she smelled an burning odor when doing a load, before it died(when it died).
  • 109 Answers
Yes, i'm afraid you have a burnt resistor on the control board, ( you can't just replace the resistor) you must replace the board. sorry not cheap.
Posted on Mar 30, 2008
SOURCE:
My SAMSUNG LE26C450E1W have a black screen, test power... I think OK but : /
Hi Nicolas,
You disconnect the main board and the screen lights up means the main board is defective. Try replacing it if you can get one.
Good Luck.
Oct 13, 2017 | Samsung Televison & Video
How can I repair my LGSMART TV?
hi sounds like failed led or leds in the panel, thanks
shaun
Mar 02, 2017 | Televison & Video
Power light turns blue, source light appears bright, then fades. Picture flashes on, then disappears, screen remains black.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Apr 14, 2016 | Sceptre X42GV-Naga 42 in. LCD Television
Bauhn ATV50FHD3 no picture has sound no lights at back. I heard tv going on and off several times went to tv picture black only sound hubby testing his remote control power switch has he killed my tv
Nov 26, 2015 | Televison & Video
I have samsung plasma tv hpp5071x/xaa when i push the power button with remote control, i can hear cliking sound and looks like turn on and see red led light at the bottom right corner and also saww flash...
Hey If you have tried Using remote and side pannels Have you tried another TV to see if its the Cable? Also The clicking sound is normal its the TV's Power-source starting. The fan light I am not sure of but if it happens every-time it should be normal. If the screen gets warm Instantly (Hotish) Then you TV is dead D:
Mar 14, 2014 | Samsung PN42A450 Plasma TV
Protech 62-24084-02 troubleshooting
62-24084-02 LED CODES
POWER LED - GREEN
ON - Normal
OFF - No power to board
OK LED - GREEN
One Blink - One hour retry delay
Two Blinks - Pressure switch failure (remains open)
Three Blinks - Limit switch fault
Four Blinks - Pressure switch failure (remains closed)
Five Blinks - Twinning fault
FLAME LED - YELLOW
ON - Good flame
Rapid Blink - Flame present with gas valve de-energizing
Slow Blink - Marginal flame
Jan 01, 2014 | Protech Rheem/62-24084-82-1PK - Integrated...
My dishwasher will not turn on nothing comes up
Take the door apart and look at the back side of the electronic board. There should be a red LED lit (near center of board) if there is power to the board. If power to the board and no light; replace board. If no power (and of course no light) check door switches and also check that the wires are not imbedded in the insulating mastic inside the door. On older models, there is only black mastic insulation, and it can soften, allowing wires to become imbedded in it, which can start disolving the insulation on the wires, causing shorts or breaks in wires. Seperate wires from mastic, use a little fiberglass insulation so they won't get back in it, and fix any bad wires. (newer models use a gray insulating blanket, older models do not)
Nov 11, 2009 | LG 24 in. LDF 7811 Stainless Steel...
Power will not come on to control panel. Door light comes on and the locked light comes on
Check and make sure you have proper voltage at the plug, reset yoru breaker.
Also are the led indicators dim (lights) on the interface board. Watch your terminology as there is a control board but it has no lights on it. Id hate to see you order a control board when you need an interface board. Well if the leds are dim then remove top and reseat all ribbon cables 4 each on the interface board and the control board. then turn it back on and see if it works. If not replace interface board then the control board in that order.
Oct 27, 2009 | Whirlpool GEW9250 Electric Dryer
Vizio P50HDM No Picture/No Sound
this is most likely the sustainer board(s) problem. Replacing the sustainer boards should correct this problem for you. you can get the parts at vancebaldwin.com
May 29, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
replace the sustainer boards should correct this problem. New sustainer boards may cause red and green pixilation. If this happen, replace control board and TV is as good as new.
Apr 05, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Maytag Neptune MAH5500B Front Load Washer Logo
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
