Question about Exercise & Fitness
Lifestrider 3325 will not turn on.
Just moved my Lifestrider 3325 from the garage to a room inside the house and it will not turn on. It was working well in the garage. Tried the reset button and found it almost flat against the bottom so I gently pried it up with a skrewdriver still no luck any help?
    President:
  • 832 Answers
Keep unit unplug check your outlet if power is good then plug unit in make sure your safety is engaged if that does not work, open motor shroud and under that shroud their should be a paper with a wiring diagram and with a Ohm meter check where you have a open circuit.
Posted on May 06, 2010
Garage Door: How to fix single car garage door that is in raised position, on tracks but will not move using the power opener or manually?
Gary released the lift could be the rails that the rollers ride on are bent or damaged what you can try is disconnect the 4 panels and try moving top panel inside the rails slots movement to the back and force and see how it works if ok then hook up the next and try it and next try it and next try it this way you can see if one of the panels or the rail is not correct lined up until you have all 4 panels connected again or check with your house insurance and see if they will cover you installing a new garage door system.
Feb 21, 2015 | Building Materials
Bush tdv6w
Mine was the same. Now the weather has warmed up not bleeping but now not getting hot, therefore not drying? Any ideas?
Nov 23, 2013 | Dryers
How to align head lights
on what kind of car repost please..
Feb 15, 2013 | Cars & Trucks
Can a refrigerator be placed in a garage that houses the electric furnace?
Hi, all fridge freezers work on ambient room temperatures, ie room temperature. Also it will depend on the classification of your fridge freezer. On a normal classification fr/free 70 degrees should be a constant maximum. On a sub normal classification room temp should not exceed 50 degrees. on a sub tropical room temp can be pretty much as warm as you like. On the rating plate inside your fridge freezer two small letters exist (N) normal. (SN) sub normal. (ST) sub tropical. Most fridges will work for a while in the wrong temp but will work too hard and pack up
Mar 31, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Frigidaire refrigerator with a broken freezer
He is correct. The temp in the refrig controls how often and for how long the refrig runs. Lets say the temp in your garage is 34 degrees, and you have your refrig set to 36 degrees: The refrig will never run, the fresh foods section will cool to 34, and the freezer will warm to 34. Even if the temp is 45 in the garage and you set the fresh foods to be 33, the refrig will not need to run long enough and often enough to keep the freezer temp cold enough. You will most likely need to have the ambient room temp at least 55 degrees to get satisfactory refrigerator performance. Insulating the refrig will not help. (by the way, outdoor beverage vending machines use an internal heater in cold weather to prevent liquid beverages inside from freezing,..... so using that info, you could put a low wattage heater in your refrig to make your refrig run enough to make the freezer section work. The %&#* with that, just move it into the house!)
Feb 06, 2010 | Frigidaire FRT17B3A Top Freezer...
My refrigerator in the garage shuts off when it is very cold outside. What can I do to prevent that?
Refrigerators are designed to work inside, at room temperatures.
The temperature of the freon is getting so low (and the pressures so low) that the freon is not turning into a gas before getting back to the compressor. Therefore you have liquid freon in the compressor (a very bad situation). When the liquid gets sucked into the compressor's compression chamber, you can damage the compressor; even kill it eventually.
I'm not aware of any way to solve your problem except heat your garage or move the refrigerator indoors. I definitely wouldn't run it at cold ambient temperatures!
If this helps you, please select YES to one of the first two ratings questions. Thank you, and Good Luck.
Oct 13, 2009 | Refrigerators
Hp deskjet 3325 light flashing have turned device
no problems
:just go ahead and take out the power cable when the printer is still on
:nw press and hold the power button fr 30 seconds
;while holding the power button,plug back the power cable
:nw u will be able to work well
Jun 28, 2009 | HP DeskJet 3325 InkJet Printer
Remotes make all fans work in other rooms, annoying
there has to be like a channel as like a garage door opener check in the remote behind the batteries
May 09, 2009 | Heating & Cooling
Dp lifestrider 3325 treadmill
Dp went out of business many years ago. S & R Workout Warehouse bought all their parts. They are in Tyler Texas at 903 581 6568. I just talked to them yesterday. Central time 8-4:30
Jan 08, 2009 | Exercise & Fitness
Exercise & Fitness Logo
188 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
