Question about Garden
I have a john deere 110 garden tractor that is not charging. the gauge shows it discharging but, not charging. i have checked the rectifier on my other 110 and it is ok. what can i check next and how?
  • camarokd May 06, 2010
    thanks for the help
    Guru:
  • 415 Answers
Check for a loose ground wire. Also Test the Alternator. The battery can be tested anywhere batteries are sold. :-)
Posted on May 06, 2010
    Genius:
  • 1,354 Answers
I HVE NO IDIA
Posted on May 05, 2010
Why would my John deere sx85 only click when I turn the key
flat battery , bad terminals , loose terminals , rusty ground wire on frame , faulty starter relay , faulty starter solenoid
May 13, 2016 | John Deere Garden
What is the correct tyre pressure for
NICE TRACTOR!
Tires
Front Dimensions15x6-6 turf
Air Pressure 110-138 kPa (16-20 psi)
Rear Dimensions26 x 12-12 turf
Air Pressure 96.5-110 kPa (14-16 psi)
Here is a link to the manual - very useful!:
http://manuals.deere.com/cceomview/omtcu29065_j0/Output/Index.html?tM=
Jan 03, 2015 | John Deere Garden
Gas leaking from bottom valve and getting in oil on a John Deere 110 17.5
sounds like the needle valve in the carb is not seating also check the oil gas over flows from the carb into the oil change it a couple times
Apr 24, 2012 | John Deere Garden
No spark to the plug Kohler 8hp lawnmower engine
Check ingition switch, check battery voltage 12-12 1/2 volts,check in run position same voltage, check in start position same voltage
We've check switch first. If not problem we've check the points for proper voltage and opening and closing.
Jan 17, 2012 | John Deere Garden
The battery charge light is always on. how to fix this problem and will it hurt to run like this
It means the alternator isn't charging the battery. The problem could be in the alternator, the rectifier/regulator, or as simple as a wire that is disconnected. Take a look for simple things like a loose connector in those areas. It won't hurt the tractor to use it like this, but after a few startups and runs your battery will be discharged and you won't be able to start. You would have to put the battery on a charger from time to time until the charging system is fixed.
Jun 10, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Fuel gauge inop on a 2000 john deere 5310 tractor
Either the fuel gauge has given up the ghost or the sending unit is not properly grounded, in which case the fuel gauge would not work. Hope this Helps, Don
Oct 20, 2009 | John Deere 420,1020,2010,2020,2510,2520...
John Deere LX188 lawn tractor battery discharge light remaining o
Check the brown wire feeding your voltage regulator,its between batt and steering wheel behind left side of frame.LX100 series machines had a problem with brown wire not fully contacting terminal in regulator.You will know you had bad contact if plastic is discolored.
Sep 23, 2009 | Garden
Discharge indicator light stays on.
I would start with a new voltage regulator which is located under the battery tray.
Jun 16, 2009 | John Deere Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
