Question about Kitchen Ranges
Magic Chef gas stove... oven does not work... It uses the ceramic unit to ignite which glows but gas does not come... Both the broiler and top burners work
  • edaba May 07, 2010
    Thank you Heatman101
    The ignitor gets very hot (the bottom pan is hot to touch) Oven ignitor is hard wire not clip like broiler. I have another piece I can cut the clip off and put in that I know works.
    If I take out the safety valve/switch is there anything special I need for threads/fittings??
    I would prefer DIY.
  • Kitchen Ranges Master
  • 43,501 Answers
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Posted on May 06, 2010
Magic chef self ignitor top,, how do u get the oven to work.. is it self ignite too. i turn on oven ger a glow in the oven,, dont know the model ,,older stove. good shape. bought house with gas stove...
If the glow bar is glowing and the oven doesn't come on in about 30 - 45 seconds.... it probably is the glow bar that needs to be replaced. BUT it could be the oven valve. Usually it is the glow bar.
The glow bar is wired in series with the oven valve and even if it is glowing it may not be sending the correct voltage through to the oven valve. To change the glowbar... unplug the appliance, unscrew 2 screws holding the metal bracket to the burner and remove the ignitor. You can cut the 2 white wires going to the ignitor and use ceramic wire nuts with the new ignitor.
Tom
Aug 10, 2010 | Magic Chef 31000 Gas Kitchen Range
Magic Chef oven stops working
the ovan could be a thermostat 3" 2 6'' long probe my first gess or the ignitor top you need more help with could be a lot of things hope this helps a lititel
Feb 13, 2010 | Magic Chef CGR3742 Gas Kitchen Range
How do you light the oven? We turn the dial and
I take it the range is electric ignition because you say the top burners have a clicking(igniter) noise. If the top burners are electric ignition then the oven is also. The oven probably uses a hot surface igniter and that is why you do not hear any clicking. Turn the oven on and open the broiler compartment. You should see a bright glow from the hot surface igniter. If you do not see any glow there may be a grounding issue or the igniter could be bad. If you do see a glow but the burner does not come on in a few minutes then give the gas valve a tap with a wrench and see if the burner comes on. Shut it off and then back on several times. If the burner continues to light after this you may have fixed the problem. If it does not come on gas valve could be sticking or igniter is weak.
Sep 10, 2009 | Magic Chef 31000 Gas Kitchen Range
Magic chef oven/stove top range not staying hot
Hi, It very well could be the ignitor. Sometimes they work at first and then will not open the gas valve later in cycle. You can set the oven to heat and watch the ignitor. If it glows and the gas will not ignite in 30 to 45 seconds, the igniter is getting weak. I jope this helps.
Please let me know if I can assit you further.
Vic
Jun 20, 2009 | GE JGRP17 Gas Single Oven
Magic Chef oven & broiler do not work
you know i am thinking more towards a bad temp probe.
May 28, 2009 | Magic Chef 31000 Gas Kitchen Range
Magic chef oven igniter will not glow.
the gas vavle..check for contiunity..just follow oven ignitor wire down ..onthejob
Jan 15, 2009 | Magic Chef 31000 Gas Kitchen Range
Oven, Broiler will not ingnite
ok try this turn the bottom oven on count to thirty then smack the safty valve with the plastic end of a screwdriver its the square box with two wires on it that the burner tube goes to underneath if it lights replace it
May 26, 2008 | Magic Chef 31100 Gas Kitchen Range
Oven won't light
Hey im sorry to hear that...
I fix many ovens., however not really familiar to yours...
However instead of searching for thermostat, try looking for either thermo-couple, falme flaiure device or falme safety device these are the three main termonologies used....
Hope this helps......
Im sorry cant provide you with a full on solution ... but my guess is that your is probably a thermocouple......
Jan 03, 2008 | Magic Chef CGS3760 Gas Kitchen Range
Magic Chef Gas Range
Does this oven glows before igniting the gas in the oven? if it does this unit uses a glow bar ignitor in the oven and spark module for the top burners.If it you dont see the spark( or hear the ticking sound the there will be no ignition. Do you smell gas even if there was no ignition happening? If there's gas that eliminate your gas regulator. If it's only one burner with spark but gas won't come on then your gas valve is deffective. But if there's gas and no spark ten it could be poor grounding, wiring, connection or switch or even spark module problem. You to need call your local Appliance service provider on this one. I do not recommend anyone fixing gas related problem if they are not a qualified servicer.
Jul 29, 2007 | Magic Chef CGR1110 Gas Kitchen Range
Kitchen Ranges Logo
160 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
