Question about Onkyo Tx-sr507 A/V Receiver
I am trying to connect my iPhone to my Onkyosr507. i connected it to the portable input in the front of the receiver but couldnt hear anything. what should i do? any configuration needed?
    President:
  • 1,851 Answers
No configuration needed, it should play normally. Alternative you can use a jack to 2 RCA cable like this
and connect your iPhone at the audio L - R inputs as seen on this picture
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "flags".
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on May 05, 2010
Is there a docking device for connecting iphone with panasonic receiver
There are lots of docks, but they all connect via USB
https://www.google.ca/search?q=iphone+6+plus+dock+connector&rls=com.microsoft:en-CA:IE-ContextMenu&biw=1366&bih=643&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjMh9Hpg97QAhVPVWMKHVosD3kQ_AUIBigB#tbm=isch&q=iphone+6+plus+dock
Your receiver only has s-video.
Total Harmonic Distortion 0.7% (6ohms) (at 20Hz-20kHz)
  • S-Video Inputs/Outputs 5 inputs, 1 output
  • Video Inputs/Outputs 5 inputs, 1 output
  • Video Rec Outputs 1 output (with S-Video)
  • Front Audio Inputs 1 input (S-Video)
  • Digital Inputs/Outputs 4 in (3 optical, 1 coaxial)
  • Audio Inputs/Outputs 6 in, 1 out
  • VIERA Link™ HDAVI Control 3
  • HDMI Input/Output 3 in, 1 out
  • Dimensions (H x W x D) 6 1/4'' x 16 15/16'' x 13 11/32''
  • Weight 11 lbs
    Panasonic SA BX500 AV Control Receiver with High Quality Amplifier Decoder...
  • Dec 05, 2016 | Panasonic Audio Players & Recorders
    How do I connect a mixer to my pioneer receiver
    mixer audio leads go in to receiver (you could use the aux in on receiver),then switch receiver to AUX on the front.
    you need receiver to recognize the mixer....
    Jul 24, 2016 | Pioneer Audio Players & Recorders
    Connect iPhone 5s to30 pin Bluetooth audio receiver
    You can try to hard reset iphone(home button and luock button for ten seconds).
    Jan 08, 2015 | Cell Phones
    I have an old Denon stereo receiver DRA - 565 RD. Do you know how I can connect my iPhone to the receiver to play music from my iPhone?
    You need a 3,5mm male stereo connector to RCA male jacks (see attached image). Plug the 3.5mm jack to your iPhone and the RCA jacks (red & white or red & black) to your Denon Receiver's CD in or Tape 1 or 2 PB (at the rear of the unit). Then select the input where you plugged the RCA to (front of receiver: CD / Tape-2 / Tape-1). Hope this will help. 25303676-z0ul41frrnrex4ege2epffps-1-0.jpg
    Dec 02, 2014 | Denon Audio Players & Recorders
    Denon receiver not working surround output
    If everything is connected correct, the only thing I can think of, is you don't put in a surround signal. If you only feed 2 way stereo, only two speaker will work. Also if you switch to stereo, the other channels will stop working. Check the cables, the settings and the input.
    Jun 15, 2014 | Pioneer VSX-D511 Receiver
    Receiver won't play music from an MP3 device
    Use your computer speaker as the sound device or use a headphones.
    If it sounds good, it could just be your cable that goes to the receiver.
    ( using a Y cable to connect to one of the regular audio inputs.)
    or have one like these:
    3.5MM To Stereo Rca Cables: Electronics
    Sep 25, 2012 | Sony STRDH520
    Just bought a 46" Samsung
    http://www.retrevo.com/support/Denon-AVR-589-Receivers-manual/id/23110dj893/t/2/
    This is a site where you can download a manual. I'm not familiar with Denen however, you should be able to go out of satellite receiver(HDMI) to your receiver input(tv/sat) then to your HDMI input on tv. Your receiver might show video and sound through another port of receivers options, ie; video 1, video 2, etc. Check all putput options for your picture and sound. Hope this helps.
    Mar 04, 2011 | Denon AVR588 Receiver
    The battery on my car ent dead and now my AIWA CDC-MP32 keeps displaying "please unplug auxillary plugs"
    An auxiliary input allows you to select an external source and play it through the cd player's amplifier. It's often used for iPods and MP-3 players. Typically you just need an inexpensive patch cable that connects the headphone output from your portable player to the input on the CD player. After that you can select "AUX" as another source like CD or Tuner, and whatever's playing on the portable unit will be heard through the speakers.
    Auxiliary inputs can be on the front or the rear of the CD player. Front aux inputs are typically 3.5mm stereo plugs, similar to a small headphone jack. Rear aux inputs can be RCA jacks or a 3.5mm jack. If you have a CD player with a rear aux input, a cable needs to be connected at the time of installation. Then the other end can be routed to whatever location in the vehicle you want to keep your portable player while you're using it with the CD player.
    Front aux jacks are more convenient for quick connecting/disconnecting the portable player, but they tend to wear out over time.
    Let us know if you have somethin more to ask else accept the suggestion.
    Thank You for contacting Fixya
    Aug 19, 2010 | Aiwa CDC-MP32 CD Player
    Trying to watch DVD played on portable Insignia player on the TV
    If you hear a noise, when triying to read DVD, I am shure I´ts teh engine malfunktion.
    you must get the mechanisiam or take this to a service.
    I´ts very difficult for lenses to get brocken.
    Jul 01, 2009 | Insignia IS-PDVD10 Portable DVD Player
    I cant hear calls on my iphone
    speaker in ur phone might gone faulty , u need to take to the service centre and mend it , b4 that try resetting
    May 27, 2009 | Apple iPhone Smartphone
    Onkyo Tx-sr507 A/V Receiver Logo
    200 people viewed this question
    Top Onkyo Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Electro Med Services...
    Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
