Question about Nokia 7310 Cellular Phone
I am getting an error message on my printer "remove and check cartridge on right" along with a blinking orange exclamation point. The cartridge on right is black ink and the cartridge is full. I have tried resetting the printer via online instructions without success. Is the simple solution to buy a new cartridge and replace the old cartridge?
  • lberrell May 05, 2010
    The first expert replied that the head may be blocked and a comment about the colors. It is the black ink cartridge only whci has been refilled twice. Again, should just purchase a new cartridge?
  • lberrell May 06, 2010
    I took your advice and purchased/installed a nw cartridge! Thanks for yor help!
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. You've not mentioned the make and model # of the printer. However, from the description provided by you, it seems that the cartridge is at fault and required to be replaced with a new one. It is always recommended to use the new cartridges provided by the manufacturer to avoid any damage to the printer. But before you proceed to buy a new one, unplug the printer from the power socket and mains, clean the print head and plug it back after more than 20 minutes. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on May 05, 2010
  • 712 Answers
If the cartridge is full it may be that the ink is clogged in the print head. In that case, get your print head cleared and try again. You must try a few times to get the color intensity maximum. You can remove the clog by dipping the print head in slightly warm water. Try this put.
My printer dell 1710 has bee blinking "!" and
Please take a good look at the front of your printer and make sure that the only thing blinking is the exclamation point. If it is then it means that the cover to your printer is not closed all the way. Try opening and closing the printer to cancel this error.
If there is a picture of a sun, an ink droplet or anything else along with the blinking exclamation point then the error can mean different things.
Oct 14, 2011 | Dell 1710 Laser Printer
I have a Lexmark X2690 that came with my PC (HP Pavilion Labtop) in July 2008. I hardly use it, but, when I do, I am always unable to print, most likely due to one or more of the following errors that I...
The light indicates either a paper jam or a problem with your cartridges (probably due to low ink or faulty). To identify and fix this issue, please follow the steps below:
  1. Remove the sheets of paper from the feeder.
  2. Grab a flashlight and look inside the feeder for any debris or foreign objects.
  3. If feeder is clear, place the printer back on the table, open the printer cover and remove the cartridges.
  4. Check the cartridge area for any obstructions/debris in the cartridge carrier's path or the paper path.
  5. If cartridge area is clear, close the cover.
  6. Unplug and re-plug the printer into the power outlet to reset it.
  7. When the printer turns on, reinsert one cartridge first.
  8. Close the printer cover and check for any errors.
  9. If no error appears, reinsert the other cartridge. Close the printer cover.
  10. Replace whichever cartridge is causing the error to appear with a new cartridge.
  11. If there's no indication of any problem, try to print a document again.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 08, 2011 | Lexmark X2690 All-In-One InkJet Printer
The orange light is blinking. Above the light is a triange with an exclamation point in it. I have tried deleting and reloading the printer and that doesnt work.
Do you have a new toner cartridge loaded? The red/orange light will blink when toner is low, even if everything else is working fine. Try printing out a test sheet and see what that tells you about your toner level. (Test sheep prints by holding the orange button down a second or two and releasing.)
Since I'm mainly printing drafts for my own use, I've just let the light blink while I eke out whatever I can from the remaining toner (occassionally removing the cartridge and shaking it -- being careful of clothes and surroundings -- to re-distribute the toner on the inside.
Oct 17, 2010 | Samsung ML-2510 Laser Printer
ERROR signal - Remove and check cartridge on right - checking
YOUR PRINTER/SCANNER MIGTH BE UVER USED AND HAS TO REPLACE SOME PARTS
ROLLERS, GEARS, OR PUT SOME GREASE TO AVOID TOO MUCH FRICTION
Mar 18, 2010 | HP OfficeJet 7410 All-In-One InkJet...
Canon pixma ip 3000 error message printer is offline
If the orange lamp blinking only it's the print head is not installed, or it is not properly installed.Open the cover remove the print cartridges then remove the print head and put back it on.If not help the print head is defective and need replace.
If the orange lamp blinking with green alternately it's ASF (cam) sensor error.The problem is in sheet feed unit.
Oct 15, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Cartridge error -
FRIEND THIS PRINTER IS IN RIGHT SIDE next to LEVERS OF BLUE CARTRIDGE TWO SMALL LAMPS ARE sensors, if they are dirty TONER WILL MAKE OF THIS MESSAGE.
Jul 17, 2009 | OKI C5200n Laser Printer
My Dell AIO printer keeps blinking right ink cartridge incorrect.Exclamation light keeps blinking too.
Try going to the Dell site and searching for that printer model. Then see if you need to have both ink cartridges populated and filled with ink, to make it work.
You might also clean the contacts on the ink cartridges, to make sure the printer knows you have both cartridges in the printer, even though they're not both filled with ink.
It just might require both to be filled, before it will print for you.
See what Dell says.
Good luck.
-a.
May 22, 2009 | Dell 962 Photo All-In-One InkJet Printer
I get a message error that ink cartridge is not well installed
Remove all the cartridges then back again installed..if the orange light is always blinking.long press the cancel botton til the green light is steady..ok..
Jan 03, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Cartridge error
Please first check whether there is paper jam in the printer roller or else please check the cartridges is fixed properly
Sep 24, 2008 | HP Officejet 4355 All-In-One InkJet...
Printer stuck on error message "Remove and check cartridge."
Remove and check what? With the machine off see if you can slide the printhead left to right freely. Make sure nothing is interfering with it. Also check and make sure there is not a paper jam any where.
Jun 22, 2007 | HP OfficeJet 6210 All-In-One InkJet...
Nokia 7310 Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
