Question about Buffalo Technology AirStation Nfiniti WLI-PCI-G300N (WLIPCIG300N) Pre-802.11n Wireless Adapter
Usb probs??? I just got a barebones from tigerdirect. it has windows 7 64bit installed. when it goes on standby and then i wake it up it will not recognize my wireless adapter (buffalo nfiniti 2.0). I have to take off the adapter and put it back on every time. Help
    Scholar:
  • 145 Answers
Hi gkell00
From Device Manager right click on your wireless adapter and select 'Properties'. Click the 'Power Management' tab and uncheck 'Allow the computer to turn off this device to save power'.
If this doesn't help then first try Rolling back the wireless adapter driver. If still no joy make sure Windows 7 has all the latest updates installed and you have the latest driver for your wireless adapter.
Does this help?
Posted on May 05, 2010
CODE 43 WHEN CONNECTED
This is usually because the disc control board in the External drive has failed, Try it in a different portable case.
Sep 14, 2012 | Toshiba HDDR500E04XL 500 GB USB Hard Drive
USB not found
Open CPU cabinet and and install USB card window 98 operating is require USB driver and other operating system is automatic detect driver ....don't west time this is best way and second option format your he'd and re-install oprating system .....best of luck
Mar 01, 2011 | ASUS T2-R Deluxe P4 Mini Barebone System...
The motherboard is an A785GM-AD3 Black. I just built this system and I can't get a display or post out of it. I noticed that a red standby light is solid the entire time power is to it. Please help me. I...
1. Check power cables (It goes standby mode when there is not enough power supply)
2. Check CPU seating and CPU Power socket
in some cases CPU socket(on the MB) may be damaged
3. check the RAM (if one of the RAM malfunctioning)
4. Clear the CMOS/BIOS battery (b4 disconnect main Power supply)
5. CPU Power FAN / Heatsink. If not proper, 4sec system go standby down.
6. Do u correctly connected 12vATX to CPU
I hope This will solve your problem. If not may be need to replace your board.
Sep 17, 2010 | EliteGroup ECS A785GMAD3(V10) Socket AM3...
PC won't stay on standby. It goes on standby but come out of it on it's own.
Standby is designed to come out of standby automatically if a mouse or key is pressed, also Wake on LAN may be effecting standy settings ( of course windows 7 has a standby setting for just about everything)
Jul 13, 2010 | E-Machines eMachines Desktop PC
Put new keyboard on and when i go into standby mode now the computer will not power down, it will say its going into standby and go off, but the power supply stays on, it used to power down,and everything...
IME, standby leaves the power button flashing because the board is still powered to keep memory alive, so it shouldn't have appeared off before. It would however be quiet because the voltage required is normally not enough to warrant use of cooling fans... or that area of the board is not powered.
Try starting in safe mode as Administrator, uninstalling all keyboard drivers, rebooting to CMOS/BIOS/Startup and looking through the areas, changing nothing but:
  1. On-board Devices - Enable onboard USB keyboard (if it is a USB keyboard)
  2. Power Settings - Wake on Keyboard (shut off wake on mouse if present and you have an optical [laser] mouse, as it is too sensitive and might not allow you to completely go into standby)
And taking notes on what you changed JIC.
Remember, don't change anything in this area unless you know it is correct. If you accidentally change something, it is best to exit out without saving and start again with a reboot. Then when you're sure, F10 to save and exit, select Yes [Y and then Enter] and boot to normal windows.
Then when you reboot, drivers should install or you should be prompted for the driver disc
Very possible standby is not enabling completely or "Windows is hanging" on standby. Check Windows Updates for that or reenact the problem, note the time and check event viewer for errors. Event viewer is accessed by Administrative Tools or by typing eventvwr in the Run dialog box. Red Xs will be errors. Click on System or Application in the left column and search the right column for a red X (You'll see a lot of them most likely). Match the time the error occurred and then find the Event column on the toolbar, which will show the Product ID. Product ID is the ID of the component/program. Search google for the description you see when you double click (or right click > select properties) the Event in the right hand column.
HTH
Apr 23, 2010 | Gateway 2520915 Keyboard
Hi I have an MSI 865GM2 Motherboard and Logitech wireless mouse and keyboard. I want them to be able to wake the computer from Standby or hibernate, but cant get it to work. There is no power management...
Yes, you need to go into the BIOS at boot time. Look for a set of "Wake on" settings (LAN,Modem, Keyboard etc). Probably under either Chipset or Integrated peripherals.
Nov 30, 2009 | MSI 865GM2-LS Motherboard
USB port does not recognise USB hard disk
Hi, you probably need to partition and format the drive, this can be done by removing it from the USB case and connecting it directly to the IDE or Sata connector, but first try using the disc managment system if running windows XP its located in the control panel within the administrative tools button, here is a helpful link that goes into detail about how to do this. link if not using XP google disc managment for your OS and partition and format the drive so windows can detect it.
Thanks
Eric
Aug 02, 2009 | ASUS Pundit-PH3 (PUNDITPH3) Barebone
My mac laptop doesn't wake up from standby/sleep
Check out these possible solutions:
http://www.christopher-chan.com/blog/index.php?/archives/588-Macbook-Pro-wake-from-sleep-problem.html
Jul 10, 2009 | Apple MacBook Pro 17 Notebook
My Compaq EVO goes into Standby / Hibernate, but then immediately re-boots. Any ideas ?
I had a computer do this to me and i found out that my USB camera would try to wake it up from hibernation and the system would simply reboot. You may want to check your USB accessories to see if any of them may be the culprit.
Mar 26, 2009 | Compaq Computers & Internet
Not waking from stand by on windows xp sp3
dont keep doing it, at some point your laptop wont ever comeback to life. so just use shutdown and hibernation
Mar 25, 2009 | HP Compaq nx7300 Notebook
Buffalo Technology AirStation  Nfiniti  WLI-PCI-G300N (WLIPCIG300N) Pre-802.11n Wireless Adapter Logo
67 people viewed this question
Top Buffalo Technology Computers & Internet Experts
Prashant M
Prashant M
Ali Reza
Level 1 Expert
Are you a Buffalo Technology Computer and Internet Expert? Answer questions, earn points and help others
