Question about Apple iPod shuffle Second Gen. Silver (1 GB) MP3 Player (MA564LL/A)
Ipod shuffle 2nd generation
Have tried the 5Rs - when tried to restore I got the error 1418 notice but I also cant sync my songs in iTunes.
  • Apple Master
  • 13,434 Answers
Symptom When restoring or updating an iPod in iTunes 7 or later, you may see a dialog reporting "An unknown error has occurred" followed by the error number 1415, 1417, 1418, or 1428.
Products Affected
  • iTunes 7 or later
  • Any iPod model
Solution
  1. Update iTunes to the latest version and attempt to restore your iPod.
  2. Try connecting your iPod to a different USB port and restore.
  3. Remove any third-party USB devices you have connected to your computer (it is not necessary to remove your keyboard or mouse).
Posted on Mar 26, 2008
  • Ekse Mar 26, 2008
    IPOD RESET UTILITY SUFFLE 2nd GENERATION
    http://support.apple.com/kb/HT1238
  • Ekse Apr 02, 2008
    If my solution fixed your problem, could you give me a Fixya rateing? Becouse Im trying to reach the guru rank and its up to you if I get there or not.
    Thanks alot!
SOURCE:
I get error message file not found
File not found means the songs you are syncing is on a different location in your computer. Try to organize your songs in a folder then drag that folder to iTunes, then sync again..
May 21, 2014 | Apple iPod Nano Video 16GB 5th Gen Silver...
IPod touch not syncing recently . notice on iTunes screen The iPod "Peter 2's iPod cannot be synced . An unknown error occurred (13019) . I've downloaded the latest version of iTunes and...
When you plug the iPod in, you should see the "Restore" option in iTunes. This will wipe the iPod and start over from scratch. DOING THIS WILL ERASE ALL OF THE DATA ON YOUR IPOD!!! If that works, you can then sync again and put all of your songs and apps back on it.
May 05, 2011 | Apple iPod touch
My ipod touch 4th generation says -ipod is disabled connect to itunes- tried that and itunes wouldnt open unless unlocked my ipod and i cant. I tried restoring it and itunes said ipod can not be restored...
"iPod is disabled - Connect to iTunes" . This is because someone(or something?) has tried to crack your password too many times, which causes Iphone/Ipod to automatically disable itself to protect your data.
To restore your iPod, you must connect your iPod to iTunes with your iPod connector table. Make sure it is on and has this message when you connect it to your computer. Once connected, iTunes should detect it as usual.
Once connected, make sure you have all the proper sync settings enabled - for example, applications, music, photos, etc. Change something so that the Sync button in the bottom right appears in the iTunes window. Then sync the data.
When syncing is finished, turn on your iPod / iPhone and you should notice that the message is gone. Type in your password and the disabled message should be gone.
If the message is still there, try holding the sleep and home button at the same time until the iPod turns off, then continue holding the sleep and home button until a screen with the iTunes logo and a picture of the connector cable appears. This will put your iPod in Restore mode. With this option, you must click the Restore button in iTunes, which will delete all your data on the iPod.
Jan 13, 2011 | Apple iPod touch
IPOD NANO SONGS ARENT WORKING!!!
Test the songs that are not playing on the iPod in iTunes and see if the original file is still playable on iTunes if the song still plays re-sync your iPod could be when iTunes copied the song it must have failed or timed out, if that fails re-syncing try restoring you iPod Nano i have had this problem before and I just re-synced and it worked fine!
Aug 26, 2009 | Apple iPod nano
Syncing iPod with iTunes, infamous (-69) problem
just
This error occurs when iTunes tries to send files to your iPod, but a file (or files) is unusable (something is wrong with it).
To figure out which file (or files) is causing the error, update to the latest version of iTunes and then do this:
  1. Control-click (Mac) or right-click (Windows) on your iPod icon in the iTunes Source pane, then choose Sync Songs from the shortcut menu.
  2. Watchthe display at the top of the iTunes window while your iPod is beingupdated. The name of the problematic file should appear in the displayright before the error appears. Then remove the bad file from the listof songs to be synced to your iPod.
  3. Select the iPod in the iTunes Source pane.
  4. Click the Settings tab.
  5. Selectthe "Only sync checked items" checkbox (please note that this checkboxis only available for an iPod configured to update automatically).
  6. Selectthe appropriate item under Library in the sidebar and find the bad filein the list. (For example, if the file in question was a song you wouldselect Music in the iTunes Source pane. If it were a video you wouldselect Movies or TV Shows in the sidebar.)
  7. Deselect the checkbox next to the file name.
  8. Repeatsteps 1 and 2 to update your iPod. If you have multiple problematicfiles in your iTunes library, you may need to repeat the other steps toremove them too.
To prevent future issues, you should delete the unusable files from your iTunes library, then restore them from a backup or reimport them from a CD.
If you're not able to isolate to any single file or if another iPodworks with the same songs, then disconnect any other devices connectedto USB or FireWire and try again. If the issue continues, then then tryresetting your iPod. If the issue continues, then restore your iPod.
Jul 15, 2009 | Apple iPod MA446LL/A MP3 Player
How can i transfer songs from WindowsMediaPlayer to ipodShuffle?
delete then re download itunes(it will not delete any songs) then sync as u normally do
Jun 26, 2009 | Apple iPod shuffle Second Gen. Silver (1...
Ipod will not restore
according to the apple website here is some help with the solution.
this is taken straight from apple.
Symptoms When restoring or updating an iPod in iTunes 7 or later, you may see a dialog reporting "An unknown error has occurred" followed by the error number 1415, 1417, 1418, 1428, 1429, 1430, 1436 or 1439.
Products Affected iPod, iPod mini, iPod shuffle, iPod nano, iTunes 7 for Windows, iTunes 7 for Mac, iTunes 8 for Mac, iTunes 8 for Windows
Resolution If you are experiencing these errors, begin by updating to the latest version of iTunes. When you have the current version of iTunes, try the following:
  • Disconnect and reconnect your iPod and then attempt to restore.
  • Restart your computer and then attempt to restore your iPod.
  • Disable or Enable Disk Use on your iPod and then attempt to restore.
  • Try connecting your iPod to a different USB port and then attempt to restore.
  • Remove any third-party USB devices you have connected to your computer (it is not necessary to remove your keyboard or mouse).
  • If you use Windows, re-register .dll files as described in article iTunes displays -50 error message when syncing iPod on Windows XP
  • For Windows users, update or reinstall your Windows USB drivers.
May 22, 2009 | Apple iPod MA446LL/A MP3 Player
Have one nano 4gb red the problem is that i have erased all songs and when connected to pc says error1439
Hey here is an apple article about your error 1439....
  • Last Modified: October 01, 2008
  • Article: TS1372
  • Old Article: 304508
SymptomsWhen restoring or updating an iPod in iTunes 7 or later, you may see a dialog reporting "An unknown error has occurred" followed by the error number 1415, 1417, 1418, 1428, 1429, 1430, 1436 or 1439.
Products Affected
iTunes 7 for Mac, iTunes 7 for Windows, iPod nano, iPod shuffle, iPod mini, iPod, iTunes 8 for Windows, iTunes 8 for Mac
ResolutionIf you are experiencing these errors, begin by updating to the latest version of iTunes. When you have the current version of iTunes, try the following:
I hope this helps your issue. :) CHEERS
Apr 23, 2009 | Apple iPod nano
Ipod classic 80 GB wouldnt allow me to load music.. now it wont appear in itunes either
My classic won't sync at all. When I plug it into a USB port a screen comes up on my ipod saying "connected" then within seconds it's replaced by another screen that says "ejecting"
It works fine on my son's PC and my wifes Mac. Just not on mine. I have disabled the firewall. Tried all the various USB ports. I know cable is fine cause it works on other computers. I have latest in ITunes and have service pak 2 with XP. So needless to say I have tried everything I can think of to resolve this. HELP!!!!
Nov 02, 2007 | Audio Players & Recorders
HELP!!
ipodcopy is a software that claims to restore deleted songs from ipods u might want to give it a try
Aug 07, 2007 | Apple iPod MA446LL/A MP3 Player
Apple iPod  shuffle Second Gen. Silver (1 GB) MP3 Player (MA564LL/A) Logo
176 people viewed this question
Top Apple Audio Players & Recorders Experts
Ekse
Sean Cole
Sean Cole
Jeffrey Groves
Jeffrey Groves
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
