Question about Hayward 1HP Super Pump II Inground Pool Pump
Hayward 1HP for in-ground pool: When I shut the pump off sometimes DE backflows from the filter through the pump and into the pool and accumulates on the bottom. The pump is about 10 years old and it just started doing this. It happens often, but not every time. Nothing else has changed in the pipe/filter loop. What might the cause (and fix) be?
  • 106 Answers
Usually caused by a small air leak somewhere on the pressure side of the system. A check valve on the line coming out of the pump going to the filter will solve problem.
Posted on May 05, 2010
Sp-1510-z1-xehc above ground DE filter. How much DE
the part number you listed has nothing to do with a DE filter. try again
Jun 23, 2014 | Hayward 1hp Power Flo Matrix Above Ground...
How much diatomaceous earth
you should never put DE in a pump. it goes in a filter system.
Low water return flow
sounds like DE remove grids clean then recharge with DE
Jun 14, 2012 | Hayward EC75 HAYWARD PERFLEX FILTER SYSTEM...
We have aEC-65 hayward pool filter with a 1HP motor why does the pump slow down run at higher pressure ?
I believe that this particular model is a DE pool filter. Is that correct? If you are operating with a media other than DE, let me know. Assuming that you ARE using DE:
1. You DE could be coated to the maximum with pool dirt algae, etc. To correc this problem, you need to bump the filter.
2. You could have an overcharge of DE. To remedy,
Bump-Drain-Recharge.
3. Restriction in return line caused by small
eyeball fitting. To correct, change to a larger sized fitting.
4. You could have a partial closed valve on a return line. You will just need to open the valve.
5. Make sure that your pump strainer basket and pool skimmer basket are not clogged.
6. Make sure that your pump impeller valves are not clogged.
May 25, 2010 | Hayward EC75 HAYWARD PERFLEX FILTER SYSTEM...
I have a brand new hayward filter for an in ground pool. The system uses D.E. The problem I'm having is after it's running for approx 30 minutes it looses all pressure. I've tried back washing it...
you might change out the D.E. media. you can also run it without any media to see if it looses the pressure after 30 min. mor than likely it is just time to change.
May 24, 2009 | Hayward Pool Products 55 Sq Ft Easy Clear...
Hayward 1HP Super Pump II Inground Pool Pump Logo
145 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
