Question about GPS
2004 acura tl navigation system screen is stuck with a green banner reading "please check disc." The disc looks fine, no major scratches, what should I do to get the system to properly read the disc?
  • kjobin May 05, 2010
    No that didn't work - I don't even think the navi system played the disc since I couldn't hear anything. Somehow the system needs to be reset or its just flat out fried. Any ideas other than just disconnecting the battery?
  • 3,083 Answers
There is possibly some lint or dust on the inside disk contacts in the unit. In high humid areas, there can be a slight amount of oxidation, and either will give you problems. Use compressed air, and blow out the disk compartment. Use some alcohol and a soft cloth to clean the contacts of the disk. If you can get to the contacts inside the unit with a qtip, try to clean them gently if you can. Otherwise, there is an electrical contact spray cleaner that is available at Radio Shack that you can use. If those things don't fix your problem, it's probably going to be a cracked trace on a circuit board inside the unit (from vibration), and that would require service, but since they don't troubleshoot to that level, they will just replace a whole board, and the cost can be prohibitave to having it fixed. Make sure you get an estimate first, then you can figure out which way is best to go. Hope this helps, and good luck.
Posted on May 05, 2010
    President:
  • 4,070 Answers
Hi! It's easy. Try to run a cd cleaning kit into the unit. The cd usually has a tiny brush on one end, this is used to clean the optic lens and it will surely help on reading discs. If no luck, I believe that you will need to have the lens calibrated. Lets just hope that option 1 works. Hope this helps and have a good one!
Navigation turns on says loading but then goes black
IF NONE OF THE ABOVE SOLUTIONS DOESNT HELP THEN CHECK THE CD UNIT IN THE BACK THEY TEND TO GO BAD GIVING THE SAME BLACK SCREEN RESULT.
May 01, 2014 | 2006 Acura TL
Navigation
try more disc's (new , not used, discs from a real store.)
many kinds, maybe yours is wrong format.
Jan 15, 2014 | 2005 Acura RL
I have a 2004 Acura RL, navigation screen reads "check nav disc". How do I fix?
Your Navigation disc usually is in the CD player. Most require the First Disc to be the Navigation disc. Now if this disc was removed or if someone changed the position of #1 disc and inserted something else, then that is why you have your message.
It is also possible that removing the Battery from the car may cause it to lose the programming in the Navigation. It may simply need the Navigation disc to be reread.
Mar 16, 2013 | Cars & Trucks
My 2004 acura tl nav screen says "dvd disc read error". The dealer does not have an explanation but said to disconnect the battery for 'a few minutes" then reconnect. after doin so the is a...
It just happened to me also on same vehicle . Remove the disc reader from the trunk and mail to Alpine . They repair the reader .lIt is alot cheaper than the dealer . I am waiting for estimate , but have heard it is less than 200 to fix . the dealer will charge a thousand .
Dec 30, 2010 | GPS
Need to reset the code my Acura MDX navigation
check the side of the glove box. my TL has it on the outside side panel as you look from the driver side. my honda prelude had the code there as well. hope this helps
Apr 28, 2010 | 2004 Acura MDX
Disc read error on my 2005 acura TL gps
Was the door open when you got the message (easy to do)?
Did you close the door properly?
Did you replace the disc shiny side down?
Aug 26, 2009 | 1999 Acura TL
04 Acura TSX Navigation System trouble
most of the time the disc is bad but when the disc goes bad its the navi unit that causes that to go bad so if you replace just disc will need another one soon after recommend replacing unit or ship to repair facilty for repairs
Apr 23, 2009 | 2004 Acura TSX
Navigation Code
True.  It is in the trunk under the plastic carpet.  You need to remove the bolts from the navi dvd and flip it over.  Write down the serial number and go back to the dealer.  Show registration of car and have car with you.  On 2005 and up cars with navi the tech can go to a secret tech screen and get the serial number.
Jun 22, 2008 | 2004 Acura TL
GPS Logo
142 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
