Question about Whirlpool WTW6400SW Cabrio Washer
Cuts off on F1. have to rest several times - Whirlpool WTW6400SW Cabrio Washer
  • 15,935 Answers
Keypad/User Interface Failure
A fault code of "F" then "1" flashes when there is a primary control failure.
You will need to replace the machine/motor control assembly.
Page 14 and 16, in the manual link below will help you with this.
F then 2 flashes when in:
Diagnostics Test mode if a stuck key is detected.
Standby mode if there is a user interface mismatch.
DISPLAY (Saved Code) EXPLANATION AND RECOMMENDED PROCEDURE
Console and Indicators
This test is performed when any of the following situations occurs during the Console and Indicators Diagnostic Test:
None of the indicators light up No beep sound is heard Some buttons do not light indicators None of the indicators light up:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P11 connector is inserted all the way into the machine/motor control.
2. Visually check that the user interface assembly is properly inserted in the console assembly
3. If both visual checks pass, replace the user interface assembly.
4. Plug in washer or reconnect power.
5. Activate the Console and Indicators Diagnostic Test mode to verify repair.
6. If indicators still do not light, the machine/ motor control has failed: Unplug washer or disconnect power. Replace the machine/motor control assembly.
Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
No beep sound is heard:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P5 connector is inserted all the way into the machine/motor control. If visual check passes, replace the user interface assembly.
2. Plug in washer or reconnect power.
3. Activate the Console and Indicators Diagnostic Test mode to verify repair.
4. If replacing the user interface assembly failed: Unplug washer or disconnect power. Replace the machine/motor control assembly. Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
Some buttons do not light indicators:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the console electronics and housing assembly is properly inserted
into the front console. If visual check passes, replace the user interface assembly.
To Access/replace the CCU:
#1
Unplug the Whirlpool Cabrio power cord from the wall outlet. Turn off the water supply to the washing machine. Pull the washer away from the wall so that you can access the screws behind the control console. Remove the hex head screws securing the control console to the washer with a nut driver. The screws are on the lower rear edge of the control console.
#2
Lift the control console up, and rotate the console forward so that the face of the console is resting on the top of the washer. Locate the interface board cable connector to the right of the plastic tube on the back of the console. Pull the end of the connector straight out of the control console. The primary machine control is the box that the plastic tube connects.
#3
Place small pieces of masking tape around the nine wires connecting to the primary machine console. Label the wire locations onto the masking tape with a pencil. Grasp each wire at the connector with your fingers, and pull the wires away from the primary control. Pull the plastic tube out of the primary control.
#4
Locate the nut toward the bottom of the primary control. Remove the nut with a nut driver. Lift the front of the primary control slightly, and slide it down to disengage the retaining clips. Pull the primary control out of the control console. Insert the new primary control into the control console. Slide the primary control up to engage the lower clips. Secure the primary control to the console with the single hex head screw.
#5
Push each of the wire connectors into their respective positions on the primary control until they lock into place. Push the plastic tube hose over the port on the right side of the primary control. Remove the small pieces of masking tape from the wires.
#6
Position the control console back upright on the top of the washer. Secure the control console to the washer with the three hex head retaining screws. Slide the washer back against the wall. Turn on the water supply and plug the washer into the wall outlet.
TECH SHEET LINK: http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208567037.pdf
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.#$%
Posted on Sep 21, 2010
After an hour of self cleaning, it beeped several times. Now, why does F1 show on the clock?
The F1 code is specific to each make of oven. I suggest that you search "error codes" your oven.
Jun 28, 2015 | Ovens
After booting always to F1
The F1 key is often a notice that something is not right in the part of the computer that runs before the operating system (i.e. Windows). What is wrong is usually displayed in the rest of the message. It might be that your "floppy" drive is not working (you may not even have one), or that the "date and time" are not set, or that the chip that sets up your system before Windows starts has been reset to incorrect settings for your configuration.
On most systems there is a key you need to push, usually the DEL key, as the system first starts. (It may also be the F10, F2 or F1) Push that key several times...about 1 time a second...as you start the system. This should take you to the BIOS screen (BIOS being the name of the chip that runs everything before Windows takes over). In there you can look at the date and time...if they are not current, or close to current, your BIOS chip has a problem. If they are current, if you restart and carefully read the message that came up with the F1 key you will know where to look in the BIOS to fix the setting.
If the date and time are not correct you need to have the CMOS battery replaced. This is not the main laptop battery, but the little watch battery used to keep the date and time (and other settings needed) when you have shut the system off and/or disconnected the larger laptop battery.
If it's this problem...the time and date wrong...you will probably want to take it into a shop and have them change the battery. The little CMOS battery is only a few dollars (under $10) and the labor should be reasonable if that's all that is needed.
Dec 17, 2014 | Microsoft Windows 7 Ultimate. Windows 7...
Maytag Bravos error code f1
F1 is a very bad error unfortunately. Try unplugging the unit 60 seconds to see if it will reset the control board. If not, then you will need a new relay control board which is about $200, because F1 means that the board has detected an internal short inside the control board itself.
Apr 24, 2012 | Maytag Bravos MTW6600T Top Load Washer
Internet would not work and then whole system froze. Powered off my holding start up button. Now everytime I try to cut it on it is stuck on black compaq screen. Have tried pressing esc, f1 and f8,...
Not too much.It seems you had a corrupt HD do to a virus or other issues.depends on your OS you can try to get some "boot files" in order to try to boot back your PC. After that if you cant do it you will need to re-install your OS.
Oct 12, 2010 | HP Compaq Presario SR1215CL (82916052980)...
F1 e1 error code...oven has previously cut off
F1-E1 - EEPROM Checksum Error - Disconnect power for at least 30 seconds and then reconnect.
Allow at least a minute after power has been restored and if error code reappears, replace control board (clock).
Oct 09, 2009 | KitchenAid KGSA906P Gas Kitchen Range
Machine stops several times shows F1 code
this is a main control board failure and needs to be replaced
Sep 16, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
1801-microcode patch error
Hi according to HP memo see the following answer hope it help:
DESCRIPTION After installing a different system board or processor in systems described in the "Scope," the systems may halt during POST and display an 1801 Microcode Patch Error with a prompt to press the F1 key to continue.
NOTE Pressing the F1 key will allow the system to continue. However, processor performance may not be optimized and the error will repeat each time the system is restarted. HP recommends that the microcode be updated to ensure optimum compatibility and performance.
Sep 09, 2009 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
F1 error
A lot of times it is the exup servo motor needing adjustment. It will cause the Fi read out to eliminate.
May 26, 2009 | 2006 Suzuki GSX-R 750
How to solve a F1 problem in an IBM motherboard
F1 for IBM is telling you there is no operating system.
press F1 to install.
change the internal battery, you may need to rest the BIOS, generally it will find all the devices.
Jan 08, 2009 | Computers & Internet
F1 error code
The F1 error code indicates a primary control failure or pressure signal out of range. Once the pressure hose & air dome have passed testing, the control board will need replaced. Good Luck And Please Rate FixYa!
Dec 20, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool WTW6400SW Cabrio Washer Logo
56 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
