Question about Lexmark T522 Laser Printer
There is a black line on my prints at the edge of the paper
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • Lexmark Expert
  • 217 Answers
This is mostly caused by a defective cartridge or a worn fuserunit.
Posted on May 07, 2010
My printer has started printing a black line down the edge of the paper?
Remove the laser print cartridge, shake it lightly, and place it back into your printer. That should solve the problem.
Mar 15, 2013 | Kyocera FS-1030D Laser Printer
Printing thin black lines the length of my color pages, HP laserjet 3800
one question......
do the lines go off the edge of the paper?
if so either the black drum unit or the belt has gone bad.
if the lines stop before the edge of the paper it could be on the print job itself.
go through the menu and look for demo pages or the configuration pages to print and examine them.
Jan 11, 2011 | HP LaserJet 3800 Printer
Broad dark line on right edge of copied papers
If you have the black line on copies and scans but printing from P.C is fine, then your scanner is broken.
Contact your printer manufacturer for a replacement or repair.
May 12, 2010 | Office Equipment & Supplies
Black line 1cm in from margin when printing
this is a catridge problem so pls replace your printer catridge.
Aug 22, 2009 | Brother MFC-9420CN All-In-One Laser...
Epson Stylus Pro 4800 Never Before Seen Banding Problem
Clean the nozzles, align the print heads, turn it off for about an hour. You may need to do this twice, but it works for me.
May 26, 2009 | Epson Stylus Pro 4800 InkJet Printer
Dark edges
It depends... never use a Reman cart in these machines... only use sharp...especially if the machine is under warranty.
Does this happen when,
Using the Doc Feeder
When making copies from the Glass
Or when you print from a computer (assuming you print from a PC)
If you print something and this happens then it is inside the machine
Probably toner or developer dumping...
Take a few pieces of large white paper and cover the entire glass surface... make a copy is the line there? If so see the answer above... if not then close the top and make a copy with no paper on the glass... is that black line there.. If so then your top needs adjustment...
One more test
If you make a copy using the doc feeder, this black line only occurs when making copies with the doc feed, clean the **** glass, and try again...
Oct 25, 2008 | Sharp AL 1215 Black and White Copier
HP LaserJet 4000tn Printing a Black Line
Change the toner cartridge, refilling will not solve the problem.
May 29, 2008 | HP LaserJet 4000tn Printer
Black Lines
Do the black lines only show up when useing the adf???? Or do they show up on both the adf and the copyboard glass??? If it is only when using the adf...... The fix is easy.... you have to clean the smaller piece of glass that is to the left of the copyboard glass with windex or rubbing alchola. If it is with both you may need a new drum and blade or a new ufr... Good Luck
May 20, 2008 | Sharp AR-BC260 Color Copier
Epson 9800 Prints black dotted vertical line
This is a workaround - I too need a definitive answer. Symptom: black dotted vertical line 1/2 to 3/4" from leftmost image edge. I have begun adding single vertical line to my prints .25" from the left edge of the paper to force the "dots" off my print - this seems to have the desired affect, but it does not answer the cause or provide a true remedy (it will save many of your prints while we wait for complete solution). dkh
Apr 18, 2008 | Epson Stylus Pro 9800 InkJet Printer
Landscape print gives dots or lines in the upper margin
unplog your printer.clean your printhead of the printer by a tissue paper.
Feb 03, 2008 | HP PSC 1510 All-In-One InkJet Printer
Lexmark T522 Laser Printer Logo
59 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
