Question about Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kenmore elite HE 3 frontloader, we replaced the door lock and we are still getting F dL. I tried to unplug to reset but cant get the door open to get clothes out and repair wont be here for 5 days. Any suggestions?
  • 15,935 Answers
1. Unplug washer.
2. Remove the outer portion of the door bellow. This is the gray rubber boot around the door. Feel around the edge of the door bellow where it attaches to the front of the washer. You will find a wire retaining hoop in the seam between the rubber and the front case. Follow this wire hoop to the bottom of the door bellow and you will find a tension spring. Carefully, stretch this spring apart and remove the wire hoop.
3. Pull the rubber bellow from the door facing on the front of the washer being careful not to rip or tear it. Once removed, fold the rubber backwards inside the drum so you can access behind the front panel. DO NOT remove the rubber bellow from the wash tub.
4. The door latch assembly is located behind the front panel of the washer on the right hand side. Locate and remove the three screws on the washer front that hold the door latch assembly in place. The whole assembly should come free from the washer front and be held by a plastic mounting bracket and several wire connectors.
5. Carefully remove the latch assembly from the plastic mounting bracket BEFORE attempting to unplug any wires. It makes it much easier to access if you do.
6. Unplug the wire connectors using care not to break any of the wires. You may want to write them down, but I believe they will only plug into their respective slots.
7. Remove the old door latch and install the new one in the reverse order of the steps I just presented to you. Plug the wires back in first, then place the whole assembly back into the plastic mounting bracket, and then reattach to the front of the washer.
8. Now, when you get the reinstalling the rubber door boot, you may want to get the assistance of a second pair of hands as it can be difficult sometimes to manipulate the wire retainer back into place. Carefully reattach the rubber bellow to the door facing on the front of the washer first.
9. Starting at the top of the door bellow at the 12 o'clock position begin inserting the wire hoop back into the groove. Work your way around with both hands to the 4 and 8 o'clock positions. (This is where you could use those second pair of hands). While holding a slight downward tension on the wire hoop to keep it in place, pull the tension spring apart enough to snap the remaining part of the hoop into place at the bottom. Once you've completed these steps make sure the door closes and latches properly. NEVER slam a door with an electronic latch. They can break easily.
Now plug the washer back in and test operate. NOTE: You can run diagnostics on these washers by referring to the tech sheet provided by the manufacturer. The tech sheet is located behind the lower panel under the door, or along the interior cabinet walls. Included, are instructions on how to run diagnostics and troubleshooting tips associated with the list of fault codes. It is recommended that this tech sheet remain inside the washer to prevent it from being lost.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!$!$
Posted on Sep 28, 2010
Hello, I have a Kenmore Elite Oasis washer model
On this washer, the dl code indicates a failed lid lock mechanism. Pressing pause/cancel should reset the controls.
You may have to unplug the unit for 20-30 minutes, then restore the power.
If that doesn't work, the only other solution would be to replace the door lock assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!!!!!!!!!!!!!!
Jun 16, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Have a kenmore elite 3 washer...stopped with 8 mins left in cycle...try to restart but getting F DL code...cannot open washer door
A Door Lock Error occurs if the door cannot be locked. It will try to lock it six times before displaying the error code.
Possible Causes / Procedure
• Door lock mechanism is broken or removed from door.
• Door switch/lock unit failure.
1. Unplug washer or disconnect power.
2. Check door switch/lock unit.
3. Check the wire harness connections to the door switch/lock unit and Central Control Unit (CCU).
Replace the door lock mech if the wiring is ok
Oct 11, 2009 | Kenmore Washing Machines
On my Kenmore frontload washing machine, we are getting a DL error?
Sep 13, 2009 | Kenmore Elite 45986 Front Load Washer
I have a Kenmore Elite Washer model 48051. I am
i think the dl code is clogged water pump,tip it back and you can remove the water pump cover and check it-mike
Jul 17, 2009 | Kenmore Washing Machines
F dL code message
Hi, this is a failed door lock alert. the FdL code represents this malfunction in the door lock mechanism. the unit will not operate if the door lock cant engage the latch. replace the door lock mechanism asap. this will fix the issue.
Jun 05, 2009 | Kenmore Elite 45986 Front Load Washer
My kenmore elite oasis washer has the code dl on it the lid wont lock and we cant fix it
Jun 05, 2009 | Kenmore Oasis HE 27082 Top Load Washer
I am getting a dl w/an f error
"dL" indicates Door Lock Failure: dL flashes if the following conditions occur:
-> Door lid is not closed completely due to interference.
-> Wash media buildup is preventing the lock bolt from extending.
-> Machine/motor control detects open door lid switch when attempting to lock.
-> Machine/motor control cannot determine if door lock is in a locked state.
Check for lock interference with lid or lock bezel
Jan 19, 2009 | Kenmore Elite 45986 Front Load Washer
DL flashes over and over
unplug machine for 2 minutes this will reset the computer if problem continues look behind bottom front cover and there is a tech sheet that will tell you what the f code is the DL code is bad door lock assembly. it could be the main control (mother board throwing you these codes) Ive seen this happen before
Dec 14, 2007 | Kenmore Elite 45986 Front Load Washer
Washer won't start; has alternating "dl" and "f" errors....can't reset
This is a Door Lock Error. The service manual lists the following causes: Door Lock Mechanism is broken or removed from door. Door Switch Unit Lock Failure-Unplug washer and check door switch, wiring connections, and the connection to the CCU (Central Control Unit (You have to remove the lid of the washer for this). To get at the switch, you have to remove the lower front panel. These are torx, I believe 3 screws. By turning yourself on your head, you can visually inspect the lock, and manually lock/unlock to check for bind (pulling/pushing a black plastic handle about two inches long with a teardrop shaped handle on the end.
Oct 28, 2006 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
Sal DeAngelo
fordexpert
Ed Mac
