Question about Dual Electronics CECT P168 Cellular Phone
Low power - Dual Electronics CECT P168 Cellular Phone
    President:
  • 1,285 Answers
Battery maybe busted
batteries for cect p168
http://www.sourcingmap.com/advanced_search_result.php/keywords/cect%20p168/searchType/all/searchbar/1
Posted on May 19, 2010
A diesel engin uses diesel fuel generates low power at low speed
Increase the speed for constand power output, or check the load it maybe more than the genset can power.
Apr 03, 2017 | Speed Electrical Supplies
2005 GMC Sierra 2500HD, left side low and high beams out, new bulbs, fuses good. No power at the sockets. Could this be the high/low switch on the column?
It shouldn't be the high/low beam switch, as that switches the high/low beam relays. One high beam relay supplies power for both sides, one for low beam, both sides. If you were to lose switch function or a relay, you would lose the high beams or the low beams, but not for just one side. It would be interesting to probe the fuses with a test light and see if you're getting power to and through them. If you are, the problem would be between the fuse box and the headlight, if your not getting power to the left head light fuses, the problem will be in the fuse box. Good luck!
Nov 12, 2014 | Cars & Trucks
How to set low power in midland LXT300
  • The Hi and Low power are built into the radio and is dependent on the frequency/ channel you are on. Hi power is 1 Watt and Low power is .5 Watt. The radio is GMRS and FRS. The FRS are low power and the GMRS are Hi power.
  • Channels 1-14 are FRS frequencies and Low power.
  • Channels 15-22 are High power and are GMRS frequencies.
  • FRS = Family Radio Service.
  • GMRS = General Mobile Radio Service.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Sep 28, 2011 | Midland LXT303-A 2-Way Radio
2006 RAM1500 left headlight won't work, new bulb, new pigtail and still no power to the low beam wire. Tried testing the headlight switch, but can only find 12v in, must be low voltage output. Am I...
Yes, the control system is low power. In theory, this increases reliability and durability in the switch. The likely problem is the power module low beam driver.
Sep 19, 2011 | 2002 Dodge Grand Caravan
Can low steering fluid cause mechanical problems
Problems associated with low power steering fluid…
Hard Vehicle Steering
A low power steering fluid level can often times cause a vehicle's steering to become hard and labored. Adequate amounts of power steering fluid are necessary to enable a vehicle's power steering system to function and operate at optimum levels. A lack of power steering fluid in a vehicle's power steering system reduces the amount of hydraulic fluid pressure necessary to efficiently operating the various parts of the entire power steering system. Power steering fluid supplies the fluid force needed to operate the power steering gears and to enable power steering gearbox operation. Low power steering fluid levels reduce this hydraulic pressure, which commonly results in hard vehicle steering.
Pump Noise
It is very common for a low power steering fluid level to cause significant power steering pump noise. An adequate amount of power steering fluid is required to ensure the proper function and longevity of a power steering pump unit, which is a belt-driven pump responsible for housing and circulating power steering pump fluid. A low level of power steering fluid results in increased power steering pump friction, heat, and wear, all of which can significantly reduce the operational life of the power steering pump while at the same time cause excessive power steering pump noise.
Fluid Boiling
Many times a low power steering fluid level can result in excessive heating of power steering fluid, a condition that can seriously degrade the fluid and cause it to boil. A low power steering fluid level results in less available fluid to both lubricate and cool a power steering pump unit. A lack of power steering pump lubrication and cooling leads to excessive heat being generated within the power steering pump unit itself, a condition that translates into the available level of power steering fluid becoming super-heated and degraded. When this happens it is common for the power steering fluid to boil and lose all of its lubricating and heat-reducing capabilities.
Gearbox Wear
The power steering gearbox is a set of gears within a vehicle's power steering system designed to facilitate movement of a vehicle's front wheels. The power steering gearbox is connected to the power steering pump by hydraulic fluid lines that deliver a constant supply of power steering fluid to the power steering gearbox. A low power steering fluid level, especially a chronic and severe low power steering fluid level, can lead to increased friction and wear within the power steering gearbox assembly, a condition that can significantly shorten the operational life of the power steering gearbox and negatively affect its operation
Nov 26, 2009 | 2003 Pontiac Grand Am
Saturn vue2003 now power low rpm
yep a stop up fuel filter.will cause low power.also bad gas and if transmission fluid is low.transmission will starting slipping. causing low power.check transmission fluid if it looks black has burnt smell.change transmission fluid and filter.
Nov 21, 2009 | 2002 Saturn VUE
No power for AC compressor
try removing the plug off the low pressure switch on the accumalator plug a paper clip into the plug and turn ac on if it comes on then your low pressure switch is bad or your low on refigerant.
May 28, 2009 | 2000 Chevrolet S-10
Kia optima low beams
First verify that the switch is energizing the relay in both positions by turning the low beams on and then pulling up the relay--does it click? If not, replace the switch. If yes, next check for power on the red wire as it comes out of the column. Switch on, no power--replace the switch. If power, check for power at the head-low fuse in the engine compartment fuse box. No power--find break in wire. If power, check for power on the yellow/red wire as it comes out of the fuse box. No power--repair fuse box. Power--check for power at lamps--same wire. No power--repair yellow/red wire.
Aug 16, 2017 | 2005 Kia Optima
Transistor
The first letter: A = Ge material semiconductors, B = Si material semiconductors, C = GaAs material semiconductors, R = Compound material. The second letter: A = Diode (low power, signal); B = Diode (variable capacitance)); C = Transistor (low power, audio frequency); D = Transistor (power, audio frequency); F = Transistor (low power, high frequency); L = Transistor (power, high frequency); R= control and swithching device); S = Transistor (low power, swithching); T = thyristors; U = Transistor (power, switching); X = Diode (varactor, multiplier); Y = Diode (rectifier); Z = Diode (zener). So the BC547 is a Silicon low power, audio frequency transistor. Hope that helps!
Sep 26, 2007 | Nokia 1100
Dual Electronics CECT P168 Cellular Phone Logo
64 people viewed this question
Top Dual Cell Phones Experts
William Alequin
Computer Repairing
Computer Repairing
Shehu Pro
Shehu Pro
Are you a Dual Cell Phone Expert? Answer questions, earn points and help others
