Question about Craftsman 21 Hp 42" Deck, Ys 4500 Lawn Tractor
Where do you hook up the pto cable for the mower deck?
  • 69 Answers
SOURCE: I can not get my mower deck to turn when I pull
Your switch could be bad, or the voltage needed to turn on the PTO may not be up to par, or you may have a safety switch that won't let you start the PTO. I'd start with the safety switches.
Posted on May 11, 2009
  • 148 Answers
SOURCE: need a manual for a LT1000 craftsman 19 1/2 HP 42 inch mower deck
You can download a free copy at www.managemyhome.com or you can go to www.searspartsdirect.com and buy a copy along with look at the diagram that you need.
Posted on Jul 23, 2009
  • 133 Answers
SOURCE: PTO Issue
It sounds like you got the cable to tight. The brake cable applys the brake to the pulley to help stop the blades when PTO is disengaged. With it being tight it might be applying the brake and that is the reason your blades are not running at full speed. If you keep using it that way it will wear out your brake and possibly damage a pulley. I suggest you loosen the brake cable or replace it with a new one.
Posted on Sep 01, 2009
  • 61 Answers
SOURCE: I have a scotts (made
sounds like safety switch
Posted on Sep 06, 2009
mickey813
  • 472 Answers
SOURCE: John Deere L120. Engine dies when PTO switch is pulled.
sounds like the seat switch is bad
Posted on Mar 02, 2010
How do I reattach the deck to my riding lawn mower
do you have a pto lever that tightens the belt? if so theres a bracket on top and in the back that holds the cabble but first you must attach the spring to the pulley that's on a arm that releases and tightens the belt, there is a hole on the arm closer to the pulley itself hook that up and pull with a little strength and put the end of the plastic of the cable in that bracket and with a carter key holds it in position and then try your lever then make sure nothing is rubbing or under a strain, hope this give you some idea of what to do
May 16, 2015 | Garden
I have a MTD yardman 1999,2000 ride mower that won't start because it says the pto is engaged when it's not actually engaged if you could comment an image of the same 42 inch deck?
Check your PTO switch operation which is at the engagement handle.
As for hooking the cable spring to deck idler pulley and brake assembly it goes in the hole closest to the idler pulley on the G deck which different then the F deck which uses the same idler arm assembly as the part is design to fit both decks.
Also make sure your using an OEM spec as a will fit will not work properly. You also must the spindle pulleys belt retainer covers in place so the belt will stay on.
May 10, 2015 | Mtd Garden
Can I get a picture of a 46" deck layout for a black mtd yard machine so I can c how the deck engagement cable go
Only seen one or two H decks here.
if it is this cable
then it connects to the RH brake assembly and the PTO engagement plate. There is also a spring that connects at the same point on the engagement plate to the right hand frame.
Apr 18, 2015 | Mtd Garden
Clutch cable routing for a craftsman 971289010 lawnmower
The PTO cable will come out the chassis straight down from the engagement lever on the right side of the dash panel. Will be fastened to the frame on the right side in front of the rear wheel with a zip tie. Loop over the brake rod and attach to the deck on a tab at the rear center of the deck. A hair pin will secure it there. The inner cable continues from there under the belt and the spring hooks into the engagement bracket. There may be two hole for the spring to hook into. They are marked 38 or 42.
Sep 02, 2014 | Craftsman Garden
Sears troubleshooting
It is likely that the pto engagement cable has broke and needs to be replaced. Lower the deck all the way down. With the engine off, kneel on the right side of the mower. look under the mower and find the end of the cable on the deck. It will be near the center rear of the deck and will have a spring on the end of the cable. Once the cable is located reach up and operate the pto lever and watch the cable. The end of the cable should move with the lever, pulling the idler pulley back and tightening the belt. If this movement does not happen replace the cable.
Jul 21, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I have a 2011 cub cadet ltx1040 with 42 inch mower deck. replaced belt, pto cable and spindle brake pads. Belt is still loose when pto engaged and cannot find any adjustment to tighten belt. All parts...
If all the parts are correct then you need to check the belt routing diagram. Sometimes you can find it on the mower deck and in the owners manual. Look carefully at the spring locations on the deck to be sure there correct. George
Aug 31, 2013 | Garden
Were does the cable hook on the deck that engages the blades
you have to give more info
If its a manual engage the lever tightens up the belt by sliding a pully against the belt
If its an electric pto it has an engadge button and that powers up the eltric pto wich inturn runs the belt
Jul 26, 2011 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
PTO Issue
Aug 31, 2009 | Garden
Craftsman 21 Hp 42" Deck, Ys 4500 Lawn Tractor Logo
316 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
