Question about Toshiba TDP-T91AU Multimedia Projector
Toshiba TDP T 91A
I have 3 out of 30 projectors TDP T 91A that very quickly switch to overheating and shut down. These machines started this about the same time. Wouldn't you know a few days out of wannenty. The cost of repair is 800. Part 23587743 PCB Assy main is the part quted to me.
Any suggestion..
  • 563 Answers
Hi there
I would suggest you investigate it yourself first before dishing out that sort of amounts.
Check if the fans are running.
Most of the times the overheating of a Projector is as a result of a faulty fan.
Posted on Mar 27, 2008
SOURCE:
Toshiba xp2 projector overheating
Better late than never for any other XP2 owners out there. I've gone through 1 lamp so far with very good results. The key to overheating is cleaning the fan out, i.e. it sucks in a lot of dust particles over time which accumulate on the fan blade and in the vents blocking good airflow. Take a good strong vacuum hose to every vent, then again right when you turn it on. This will get the fan up to speed quickly and assist with removing more dust internally. Eventually, you'll need to open the projector up and clean internally (carefully), but doing the above maintenance will prolong its life and extend the lamp too!
Feb 22, 2012 | Toshiba TDP XP2 DLP Projector
Tip
Toshiba TDP-P9 Lamp time reset
I had sleepless nights with my customers TDP-P9 projector where I changed the lamp.
The lamp timer resetting gave me headache but now I finally solved the right combo:
1: Unplug the power cord
2: Hold down 'On/standby' 'Input' and 'up arrow'
3: While keeping the buttons pressed, insert the power cord and wait for the projectors led's to flash briefly and then power button to keep illuminated and then starting to blink.
4: Release the buttons and power on, it should now have 0 hours in the timer.
on Apr 06, 2011 | Toshiba TDP-P9 DLP Projector
THE LAMP LIFE IS LESS THAN 250 HOURS. IT IS NOWHERE NEAR 1500 HOURS
if you get no light, clean out the projector of dust with canned air. overheating from excessive dust blows lamp quickly. now replace the lamp. if still no light, replace the ballast.
Sep 30, 2009 | Toshiba TDP-MT800 Multimedia Projector
Problem with power point
These devices get hot when they work. they need cooling. if the cooling system get dirty and fan cant turn clearly then it stops itself for protection.  it need to be cleaned.
hope it works
May 28, 2009 | Toshiba TDP-T90 Multimedia Projector
No Power to My Toshiba TDP-S8
Console and mainboard not communicating. avalontc.com
Jun 05, 2008 | Toshiba TDP-S8 Multimedia Projector
Toshiba projector tdp-s8
please start your computer first and then the projector- use function key with f4 or f6 or f7 or f5-and select computer from input of the projector.
Dec 29, 2007 | Toshiba TDP-S8U Multimedia Projector
Overheating
Set the lamp to economy mode, make sure it is being used in a cool room with easy air flow thru the projector. If the problem persists, there are two fans inside and a thermistor that takes the temp reading, there is small adjustment POT on the board to increase the operating temp if needed.
Dec 19, 2007 | Toshiba TDP-S20U Multimedia Projector
Toshiba TDP S8 projector shuts down suddenly
The reason why the projector is shutting off is so the lamp doesn't explode. It's more of a safety feature on the projector, you can reset the lamp and it might work for another 500hours. If the picture is still pretty bright I can get you the reset procedure, but be warn that when the lamp does eventually blow it could shatter the glass inside, so be careful, it shouldn't hurt the unit.
Dec 09, 2007 | Toshiba TDP-S8 Multimedia Projector
Toshiba TDP-P5 projector
Possibky is overheating... I would put a fan on it and see if the time-to-fail changes,
Oct 03, 2007 | Toshiba TDP P5 Multimedia Projector
Open Questions:
See all Toshiba TDP-T91AU Multimedia Projector Questions
Toshiba TDP-T91AU Multimedia Projector Logo
186 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
digivisionm
Level 1 Expert
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
