Question about Canon PowerShot SD790 IS/ IXUS 90 IS Digital Camera
I want to download the pictures from my SD 790 IS to my pc, I have all the connections right, turn on my conon, but it does not work. What can I do?
    President:
  • 1,902 Answers
Have you updated your driver? Installed the CD that came with the camera?
Posted on May 05, 2010
How do I download pictures from a SD card to my computer?
With the SD card plugged into the computer, go to "My Computer" if XP, "Computer" if Windows Vista or 7, or "This PC" if Windows 8.
You should see the SD Card listed as a drive with a letter like D: or E:, double click it, then look for your pictures on the SD Card, hint - they may be under a folder called DCIM.
Once you find your pictures, highlight them and right click, choose copy, then click "Pictures" on the left side in the folder tree, and right click the space to the right where your pictures are located. Click paste.
That should put your pictures into your "My Pictures" folder.
Dec 22, 2014 | Lenovo IdeaPad Computers & Internet
I wont to download 790 sw pictures to pc and require downdoad program to do it
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Dec 02, 2010 | Olympus Mju 790 SW Digital Camera
I have an Olympus 790. When I tried to use it last week, it wouldn't turn on. I also have a new Olympus 770 that I have never used. Today I turned it on and it worked fine. Then I took the memory chip...
Either the software in both cameras need be updated. EIther by online software update program or the manufacture will do it for $50 a camera.
Otherwise, some SD cards to have conflicts with some camer'a software for some reason. Sometimes using the wrong sd card in a camera will result in memory flash and causing the camera to be in need of software update. Once updated you should be good and should work with all sd cards from now on.
Oct 10, 2009 | Olympus Stylus 770 SW Digital Camera
Blank screen in ON mode at random occassions
Remove the card and the battery...press all the buttons...leave the camera alone for 20 minutes...insert the card and then the battery...turn it on. If the screen comes on, go into the menu and scroll to "reset" and follow the on-screen instructions.
Oct 02, 2009 | Canon PowerShot SD790 IS/ IXUS 90 IS...
Trying to take black and white pictures
It may not work if its on auto. Tou can also convert pictures to BW from windows preview it vista. Go to "fix" on the top menu then Color then turn the saturation to the far left. Make copy first if you wish to keep the original.
Aug 30, 2009 | Canon PowerShot SD790 IS/ IXUS 90 IS...
Critical error 678 on mobilepro 790
error code is 678 means Ur com port not correct configure so before u connect anything u must to configure correct.
Mar 02, 2009 | NEC MobilePro 790 Pocket PC
CANNOT DOWNLOAD PICTURES TO MY PC FROM MY CAMERA
there might be a problem with your cord/cable (a cord/cable that will enable you to connect your cam to PC).pls try to connect the cable firmly if still does not work pls try to get your memory card from your cam and put it in a card reader. That way you may be able to download pics from your cam to your PC.
NOTE: some card readers may need an adapter to be fitted in an SD size card for example i have an micro SD memory card i will need an adapter to fit the micro SD to SD.like this picture
ef0e117.jpg youll be needing this to insert it in a card reader
this is an example of an ordinary card reader
this is an example of a universal card reader
a4bb106.jpg use these following devices and you will be able to download pics from your cam to PC.
i hope i was able to help you! good luck!
Nov 01, 2008 | Cameras
Canon Not recongized by Computer
Try to change the USB connection type in the camera menu. There are several types like Mass storage, Pict. bridge, and the one you need is most likely PTP. Anyway, try all of those and maybe it will work. That is the most common problem when connecting cameras to Vista based systems.
Sep 14, 2008 | Canon PowerShot SD1000 Digital Camera
Canon PowerShot SD790 IS/ IXUS 90 IS Digital Camera Logo
149 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
