Question about Okidata Multipurpose Feeder For All Ol400E/600E Series 810E PC Desktop
HOW TO GET METER READING OFF OKI CX2633 - Okidata Multipurpose Feeder For All Ol400E/600E Series 810E PC Desktop
How to fix oki error code 134
This machine will most probably require the main board as sometimes the heads can get knocked and temporarily disconnect. I have had this a few times and replaced many boards (the fuse blows that supplies the heads on the board).
Also, before replacing the board, the values of the faulty board will need to be pulled off with MUWIN and put onto the new board (meter readings and consumable usage).
Dec 08, 2016 | OKI Office Equipment & Supplies
Oki c5550 INCOMPATIBLE YELLOW
Are you using factory or aftermarket toner?
Jan 07, 2014 | Oki Electric Industry Okidata C5550n MFP...
Replace fuser E error
Reset Fuser counter Oki B6200 Action: Power on and wait until the ready to print message appears on the operator panel. Press "Select and the Down arrow button at the same time" The following Menu is displayed"Reset Counter Fuser U4" Press the right arrow button Operator Panel will display "Fuser U4 Use the SEL to Reset" Press the SELECT Button Operator Panel will read "Clearing" Press the Menu key to return to "Ready to Print Mode"
Apr 05, 2010 | OKI B6200 Laser Printer
How to reset drum for the oki B410DN
Most of the OKI printers have a fuse installed in the drum to do the reset. If you google the drum reset kit you can find the drum kits and fuses.
Jan 14, 2010 | Office Equipment & Supplies
Oki c5200 fatal error 121
We had a similar problem with an Oki C7300. It was reading "Fatal Error 121" on the display.
We fixed it by simply unplugging the printer from a surge strip and plugging it into the wall directly. After that, the error went away and has not come back.
Apr 16, 2009 | OKI C5200n Laser Printer
Will not print.
mac laptom does not give oki as an obtion on the print using field they have alot of companies on there but not oki the computer is reading the c5500
Jul 21, 2008 | OKI C5500n Printer
Oki c5500 gives a false paper jam reading
service the rollers (either clean the pickup with clean alcohol or use sandpaper ) sometimes clean the fluff from the printer with dustoff helps as well
Health and Safety get an engineer to do it for you. if you have warranty call them out. check your total page count and diagnostics via printer status page before you call them out.
May 23, 2008 | OKI C5500n Printer
Okidata Multipurpose Feeder For All Ol400E/600E Series 810E PC Desktop Logo
232 people viewed this question
Top OKI Computers & Internet Experts
Richard Ames
Level 1 Expert
Stan Skaggs
Stan Skaggs
Brett Duxbury
Brett Duxbury
Are you an OKI Computer and Internet Expert? Answer questions, earn points and help others
