Question about GE JVM1490 Convection/Microwave Oven
How to chane inside light
I'm having a problem figuring out how to change the iside light. There is inside the compartment a hatch on the right side, with one screw holding it in. Is this where the iside light is to be found??
Thanks,
Tom
  • GE Master
  • 8,862 Answers
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
If that's not enough, here is my standard reply on this subject:
Manufacturers used to include access panels in the rear or side so you could easily change the bulb. That exposed the customer to 110V connectors, and that posed a real liability threat, so they stopped using them.
You now must generally remove the outer cover to replace the bulb.
In many over-the-range models, that can mean having to take the oven down from the wall! For safety's sake, that should be a two-person job and it's really helpful if you have your original installation instructions to do this.
You can get them for many GE models here: http://www.geappliances.com/service_and_support/literature/
Many models use one halogen lamp to illuminate the cooktop and another to illuminate the cavity. You must not touch them with your bare skin as the oils will shorten the bulb life.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 30, 2008
How do I change light bulb in the microwave
There is almost always a hatch either inside the oven or sometimes outside, opposite the bulb
Jan 15, 2015 | In Microwave Ovens
Door is not clossing properly control panel not responding
please put some tape on the inside of the unit or put some nail polish on the iside of unit
Sep 18, 2011 | Microwave Ovens
Don't have the manual. How do you get to the light inside the microwave? It has blown. It is not the 2 underneath.
take the casing of the microwave and you should be able to acces the bulb from there on the iside right of the microwave
Dec 26, 2010 | Microwave Ovens
Light bult in a Microwave oven is burned out.
There should be a panel covering the bulb iside the cookspace with a screw holding it on. Remove screw, cover then bulb.
Oct 12, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Chaning light bulb in microwave oven
If there is no door over the bulb that can be removed by a screw or otherwise, then the cover has to be removed. DANGER!!! ALWAYS UN-PLUG BEFORE ATTEMPTING REPAIRS!!
Feb 02, 2008 | Microwave Ovens
Kenmore 62709 Microwave
The 5-digit number above is not a complete model number.
If you can post the full model number I can probably give you a link to the explode view, or you can find it here: http://www3.sears.com (the 3 is correct)
Nov 21, 2007 | Kenmore 62702 Microwave Oven
Where is the light bulb located?
Unscrew the vent at the top of the microwave(2 phillips head screws)
inside to the right you'll see another screw holding a metal panel. Unscrew this and take the panel off and you'll see the bulb, which will unscrew counter-clockwise
Nov 03, 2006 | LG LRMM1430 Microwave Oven
I have an admiral microwave model 8573
That's made by Sharp and many of theirs (and other brands) require you to take the outer cover off to change the bulb. Here's how: Unplug the oven first. That's rule one! Remove all of the screws from the side and back of the outer wrapper / cover of the microwave. There are usually four on the rear edges and two on the bottom of the edges on each side of the cover. The cover then should be slid slightly backward then up from the rear and it will slide off. You may have to pat down on the sides to loosen it first. I use firm and simultaneous open-palmed slaps on both sides near the front, then pull it up and off. It is possible that some voltage will remain on the high voltage capacitor and can be conducted via contact with wires, connectors and components connected to it. If you stay away from all the wiring in the right rear (as you're looking at the front door) it should not be a problem. Unless there is a problem, the voltage should actually not be present. If you and the work area are clean and dry, and you only touch the light bulb while the cover is off, there should be no problem. Change the bulb. It may be held in with a bit of clear tape, too, so take a look at the socket first. When putting it back on, be careful that the inside front edges of the cover catch properly in the slots in the chassis. Good luck and be safe! Make sure it is unplugged!
Oct 09, 2006 | Kenmore 63672 Convection/Microwave Oven
GE JVM1490 Convection/Microwave Oven Logo
105 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
