Question about Boating
The steering cable guide moves when the wheel is turned what is believed to be creating a 1/4 to 1/2 turn ''dead spot'' in the steering whell (just acquired the boat engine was replaced in 2005, Stern drive, not sure, it is either original 1995 or 2005- 5.7l, Bravo II I/O with hydraulic (power) steering.
  • m_ryan_seapo May 05, 2010
    I will try to clarify-
    First I noticed a 1/4 to 1/2 turn in the steering wheel (dead spot/area) with no movement in the position of the stern drive.
    With the assistance of a second person (turning the wheel) I observed that the steering cable guide tube was moving 1/4 to 1/2 inch back and forth when the steering wheel was moved back and forth in the range of the dead area.
    Maurice
    Top Expert:
  • 80,339 Answers
Not sure what the question is here, very confusing information, are you saying you believe u have to much free play in the steering wheel of the boat? please clarify
Posted on May 05, 2010
  • yadayada
    yadayada May 05, 2010
    then the tube must defective would be my guess without being there.
Truck doesnt want to stop when I have the steering whell canked all the way?
there must be a vacuum leak in your brake master. try pumping the brake pedal several times every time you make a full turn of steering wheel. if this fixes your braking problem, then replace CHECK VALVE hose in your brake master.
Jun 10, 2013 | 2002 Chevrolet Silverado 1500
Power steering problems (stiff steering wheel)
you have to specific in the make , model , year and equipment type
you problem indicates seized bearings in the rubber mounts at the top end of the struts and you are actually trying to twist up the springs
the new rack fixed for a short period of time eliminates the power steering pump
It could be the steering column joints are dry and seizing up as well ( dead spots when turning the wheel indicates joints not turning freely0
Dec 25, 2017 | 2002 Toyota Camry
Steering wheel is locked on my 95 ford f150 xl..it starts and goes into gear but the steering wheel won't move..it is locked
you can break the lock by pulling down on the steering whell very hard. or if your ignitons swith is bad you have to get a new one
Nov 13, 2011 | 1995 Ford F150 Styleside Regular Cab
I got into my car and tried to start it the wheel is locked and i am unable to turn the wheel or start the ignition...what could the problem be?
On mine you have to push the brake to release the steering sounds like it is jammed turn key to on position then put in gear and back to park if it is automatic and try moving steering whell at same time to get it unjammed this is a pretty common thing with the focus
Jul 08, 2011 | 2004 Ford Focus
The key will not come out
Try moveing the steering whell hard both ways while turning the key and pulling at the same time. some times the locking steering wheel puts the ignition switch in a jam.
Feb 24, 2011 | Cadillac Escalade Cars & Trucks
I hear a growling noise in the steering wheel every time I turn a corner, back up and turn the wheel, or turn into a parking space. Most of the time it is when I turn the wheel to the left. All fluids have...
Yes. Hi. the plastic trim around the base of the steering wheel and the steering column have an imperfection in one area that causes them to rub in a certain spot every time, are out of place slightly or are for some other reason making contact and creating a noise. Get right down there and turn the wheel and look for a rub. When you spot it use a sharp razor blade knife to trim it a wee bit. J.
or, you have an issue with the steering shaft somewhere.
Jun 23, 2010 | 2004 Chevrolet Avalanche
When I put the key into the ignition and try to turn it it wont turn. The steering wheel is lock and when I try to move the steering wheel to find the "sweet Spot" to turn the key and start the car the key...
If your are turning the wheel to the "sweet spot" like you said, and you are using the right key, do you have a second key that still won't work? Then ignition lock tumblers are worn. You or dealer has to fix.
Mar 08, 2010 | 2006 Suzuki Forenza
I cannot turn the ignition on
battery dead , starter won't turn or key won't turn? if key will not turn , insert key, pull/turn steering whell one direction and try key. if not turning still pull/turn wheel other way and try key
Dec 31, 2009 | 1988 Ford F 150
Drag link adjustmnet
Your desctiption sounds like your settings are incorrect. I reccomend that an alignment shop adjust for you.
A common mistake on this type of project is steering box centerning. to test, from straight ahead, stop.., turn wheel from dead center to the stop, and measure exactly how many turns. From dead center, it must be the same both ways.
Steering boxes have an exact center setting, and get looser (so to speak) as turned right or left off of that spot. SOOO, if set to one side or the other, steering gets tighter when turning in one direction as compared to the other.
Get an alignment shop to set this up, it is common problem.
Sep 07, 2009 | 2000 Jeep Wrangler
Key won't turn and steering wheel is locked
Have you tried wiggling the steering wheel at the same time as you turn the key? Have you tried pushing on the gear shift lever, to make sure it's all the way in park?
Aug 25, 2009 | 2001 Dodge Stratus
Boating Logo
49 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
