Question about Technics SL-MC7 110-Disc CD Changer
My 110 disk player gives me a message of "no disk" even though
The entire unit is full. It goes on to the next cd where I get the same
message.
Thank you for your help.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Please check that the CDs are not scratched. Now run a lens cleaning CD. If that does not work then you have to open the unit and clean the lens with a Q-tip dipped in alcohol. This is only recommended when the unit is not under warranty and you have some expertise in the field. Please check whether the CD turns before moving to the next CD, CD moves freely and lifts into position. If still the issue is not resolved then the lens is required to be replaced. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on May 05, 2010
When inserting a cd into the cd player, i get an error 00. What does this mean?
This is a code that pops up when your lens is not reading the CD properly. So first were you trying a burned CD? If not then I would suggest giving a good cleaning to your CD player. Run a disk through the entire process two full times. This will clean the lens. Sometimes the lens goes bad so if you use a regular CD and clean it and still are having a 00 code then you may need a new CD player. Sometimes kids feed stuff in there that shouldn't be in there too. Food, crumbs, change from a cup holder.
Regards, Tony
Apr 14, 2011 | Car Audio & Video
Trying to write to blank disk first time (Memorex CD-RW). Get message: Record failed: wrong format for re-write Spectroniq SDR-205 DVD Recorder
Some DVD recorders cannot write CD-RW - only DVD-RW (+ and -) as well as DVD-R (+ and -) (this depends on the brand/model). This unit probably does not support CD recording. Try using DVD-RW instead for this machine - see if it records that (do not finalise even if unit prompts you to with an on-screen message prior to ejecting disc).
There are DVD players and recorders which can play CD-RW (mp3, jpegs etc.) but I don't know of any which record this format (a PC CD/DVD-ROM drive can do this though).
Mar 09, 2011 | Televison & Video
Hello My SL-MC7 gives a error message No Disk even the tray is full with disks. The disks are taken out to the player and put back again without being played Kind regards Rene
Well the first thing to try is a cd lense cleaner. You may have a build up of prticles and oil on the lense causing it not to read. Secondly, make sure you try a "Shop Purchased" cd to make sure it's not haveing problems reading "cdrs" (home made cds).
If after both of these methods you still have the same problem, it's down to the laser. Could be a series of things from tracking, focussing or the laser has died altogether. Unles your experienced with electronics in a big ay and have test meters and an oscilloscope, you need to decide how much you want to keep this CD player as a new one could be cheaper than a repair.
Jan 06, 2011 | Technics SL-MC7 110-Disc CD Changer
My dvd player keep on loading but it end up no
from direct experience, the problem is that the disk does not start spinning by itself - it will if you have the top off and give it a spin to start it ... I don't know what the ultimate solution is though.
Jul 04, 2010 | Pioneer DV-400V DVD Player
UCD 110 - Doesn't recognise every CD and will only play some CDs. I've tried cleaning the player with a CD Cleaning disc but to no effect.
I've had the same problem with a denon ucd 70,had the laser replaced and still the problem remained.Finally it appeared that a little wheel which moves the laser over the disk was broken and therefore the entire system finally couldn't read any cd anymore It started with some cd's however.
Still looking for a replacement wheel and fear that I have to buy a full new laser unit
Sep 24, 2009 | Denon Audio Players & Recorders
Location of the GPS CD player on a GMC Envoy.
That is where it goes. The Radio head unit needs to be sent out for repair. That is the message that it will give when not working/reading the disk. Mine does the same thing.
May 31, 2017 | 2004 GMC Envoy
BR1180CD does not regognize cd's.
Have You Tried Cleaning The Lens?
www.Myspace.com/CrossRoadsToNowhere2007
Dec 27, 2008 | Boss Micro BR Digital Recorder
DVD will not load
Firs try to clean the lens with CD/DVD cleaning disk (it might be $1-5 depending on store)
Also check if DVD disk not upside down.
Also chek the DVD disk for scratches
Good Luck
Dec 25, 2008 | Daewoo DVG-9200N DVD Player
Technics SL-MC7 110-Disc CD Changer Logo
66 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
