Question about Sewing Machines
What is the foot pressure suppose to be set at
    Genius:
  • 1,116 Answers
Up/light/loose for light weight fabrics and down/lower/tigher for heavier weight fabrics is the best I can describe the settings.
If there is a knob that you turn; right is tight and left is loose.
Posted on May 07, 2010
It seems the problem is the excess pressure of the foot when down.. it must somehow be related to thread tension.. can I change foot pressure?
Depends on the make/model of your machine. Most machines do have a pressure adjustment for the presser foot. Sometimes it is explained in the owner's manual.
Newer machines have a dial somewhere. Older machines will have a screw at the very top of the presser foot bar (sometimes under the top cover). Turning the screw right will increase the pressure, left will release it. Other machines have a plunger type projection on the top left of the machine. Pushing the plunger down will increase the presser foot pressure. To release the plunger, press down on the ring that encircles the plunger.
http://makeitsew.biz/presser-foot-pressure
http://www.sewdaily.com/how-to-sew/sewing-machine-basics/the-best-kept-secret-on-your-sewing-machine
Sewing Machine Pressure Settings for Machine Quilting
Dec 29, 2016 | Sewing Machines
Can you adjust the needle assembly up higher for thicker garments like thicker coats etc. on Kenmore sewing mach. model 158-13360
On some machines, you can lighten the amount of pressure the presser foot applies to the fabric. (Some machines do not have this capability.) But, you don't want to adjust the height of the presser foot.
If the fabric is pushing in front of the presser foot as you are sewing, you might want to try using a walking foot, a teflon foot, or a roller foot.
Kenmore 158 13360 Sewing Machine If this is like your machine, the pressure adjustment is the upright pin at the top left side of the machine. The inner pin pushes down (in various degrees), the further it is pushed down, the more pressure the presser foot applies. To release the inner pin, press down on the outer ring of the pin. It will snap back up where you can again push the inner pin down in degrees. BTW, it is a good idea to always release this pressure pin when you store the machine. If not, what happens is, over time the spring that applies the pressure becomes compressed and no longer applies pressure like it should.
Dec 20, 2016 | Kenmore Sewing Machines
How do I Lower the pressure foot for sewing after changing from embroidery on my brother pc- 8500?
Would a manual help?
Brother PC 8500 User Manual
Are the feed dogs in the raised position? Is it a regular stitch presser foot or a darning foot? A darning foot is shorter in height so the fabric can be maneuvered without use of the feed dogs. Just some ideas. Could also be an embroidery setting that has not been deactivated.
Oct 03, 2016 | Brother PC-8500 Pacesetter Embroidery &...
Does the quantum 9240 have a presser foot pressure setting
check your instruction manual for the pressure settings, if you dont' have a manual, here is a link for a free manual
http://www.singerco.com/uploads/download/561045875f56535643a5807fee45805734ea3274.pdf
Feb 20, 2016 | Sewing Machines
Why will the feed dogs on my singer stylist 834 only move if the pressure foot is up?
Sounds more like a settings issue than a repair.
Check here -
http://www.youtube.com/watch?v=d3khJG7L_Tw
Jul 31, 2014 | Singer Sewing Machines
I can't start to sew on my 830. The foot control is recognized(the start/stop button light goes off when I press the foot control), but does not make the presser foot come down. It worked 15 minutes ago...
If you lower the pressure foot before you press the foot control does it sew then? If so, then some how in your setting menu you auto pressure foot setting has gotten turned off.
Apr 23, 2011 | Bernina Artista 180
I need a replacement pressure foot release lever for a Simplicity BH600 blind hemmer.
Supposedly, Simplicity is made for Tacony. I would start there to ask about parts.
Is this a presser foot lifter?
I do not recall ever seeing a pressure foot lifter.
Mar 04, 2010 | Simplicity Sewing Machines
The top spool of thread jams tight when I pull the
It sounds like the tension setting is too tight. The tension mechanism consists of two metal disks; the thread runs between these disks. When the pressure foot is down, the disks come together, trapping the thread between them. When the pressure foot is up, the disks separate and the thread can flow freely. (BTW, this is why you adjust the tension with the pressure foot down.)
Take a look at your tension setting and try loosening it. That should resolve the problem.
Let me know if this helps, ok?
Robbie
Jan 27, 2010 | Janome Sewing Machines
Problem with the foot and feeder
You can also check the pressure foot regulator (near were the light is open the cover as if you were threading neelde and it is in there its mealat and has numbers 0-3 on it. 1 is for heavy fabrics, 2 for med, 3 is for light and 0 is for darning or fre motion sewing. the standard setting is 2. try both this and the feed daos, one of them should work.
michelle NH
Mar 23, 2008 | Simplicity Denim Star SW210
Sewing Machines Logo
41 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
