Question about Durabrand DWT1304 13" TV
Intermittant sound Some days we always have sound. Other days, when the sound stops, we can get it back by turning the TV off and then on, after a minute or two, using the remote. If this doesn't work, we try using the sound controls on the TV's face. At other times, nothing works but to leave the set off and hope we'll have sound for our night-time viewing. After a few hrs of rest, it always works fine. Our son just hooked up a Magnavox DVD player for us and we could see the film running right away but no sound. We re-checked his hook-up using M's DVD Instruction Manual and it looks fine to us. Now, since none of our old actions to get sound have worked, we wonder if it's just another of those time-out times or has the DVD hook-up affected the TV. I'm in my early 80s and not too familiar with most of the electronic jargon so be forewarned. Thanks much!
Is this tv digital compatable for when everything goes digital in febuary 2009.
Posted on Aug 08, 2008
SOURCE:
Purchased LG's LHB335 home theatre 5 days ago to enhance my LG 42LBX TV. Problem with home theatre sound as the audio cuts out for a couple of minutes every 15-20 minute intervals. Problem is intermittant...
i bought mine in january 2011 and just started having the same problem. i have to turn the head unit off and back on again to get sound back. any fixes for this yet?
Dec 06, 2010 | LG LHB335 Theater System
Philips 42 inch lcd tv picture coil(?) intermittant hf noise. no noise on a blue screen. back to tv and noise comes back.
sounds like radio interefence from unsheilded speakers etc turn everything off apart from set see if that helps.if it does turn each unit back on till you find source of noise i had a home cinema sytem that did this had to move unit away from set.
Feb 17, 2010 | Televison & Video
1996 Ply. Voyager. Wipers not always intermittant.
it sounds like the control board on the wiper motor has gone bad you'll have to replace the the motor
Oct 15, 2009 | 1996 Plymouth Grand Voyager
A 42 or 46'' Samsung picture shuts off but still has sound
Remove all video inputs including hdmi if problem goes away. Determine what input is suspect and call smasung for a firmware upgrade. HDMI casued intermittant behavior with this series, but was sometimes seen on component video.
Jun 29, 2009 | Samsung DLP HL-P5663W 56" TV
Phillips 29" TV
Sounds like it has an intermittant connection somewhere which is very common now a days due to the lead-free solder all the makers went to. Resolder everything that looks suspicious, especially the bigger components. It could also be a failure of the flyback transformer though which often times fail like this.
Hope Ya Fix It.
Feb 13, 2008 | Philips 27PT6441 27" TV
Loud whirring. Not the fan.
The fan noise is normal on this set. The lamps are cooled via this method. Your users manual explains this issue..and it is the fan as you can see it slows down after the tv is switched off..
Oct 20, 2007 | Samsung HLR5067WX 50" Rear Projection HDTV
Philips 28PW6515-05 flat screen TV
You have a bad connection on the CRT board thats mounted on the end of the picture tube it sounds like, or the socket on that board that plugs into the TV set is intermittant or has a bad solder connection on it. Good Luck
Mar 27, 2007 | Philips 28PW6506 28" TV
While watching tv, the tv all sudden goes snowy, no sound, and have to turn it off and back on to make it work again
Connect up another set right next to that set thats going out to make sure the cable or that line is not bad. It soukds as though you may have an intermittant tuner assembly inside the TV set. Its also a possablity that there could be a bad solder connectiuon in or around the tuner assembley. Not really a job for the user, as this set has hot and cold chassis, and can give a mean shock if you do not have the know how to work on these monsters. good Luck PS Please do not forget to rate this thread.
Dec 08, 2006 | RCA Scenium D40W20 40" Rear Projection...
Red lines across screen
it sounds like a b+ cap going bad and is intermittant that feeds the the video drivers on the crt pcb or the crt is shorting. I have seen intermittant shorts in crt before.
Mar 27, 2006 | Toshiba 32AF41 32" TV
Durabrand DWT1304 13" TV Logo
57 people viewed this question
Top Durabrand Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
