Question about Toshiba TDP-S20U Multimedia Projector
Bulb light projects red
At first there was no blue at all, now the entire screen is red. The light coming from the bulb appears red. Not sufficient time on the bulb to normally warrant replacement.
  • Chuzzle Mar 28, 2008
    Thanks for your comment....I'll see about getting it repaired. At least I didn't buy the bulb and then find out it wasn't the trouble.
Infact a color wheel issue. your mainboard is likely ok. these units use a spinning wheel with colored lenses to reproduce color. yours is bad.
Posted on Jun 27, 2008
  • 563 Answers
Hi there
I guarantee you 100% that this not a bulb problem but rather a Mainboard failure.
This can unfortunately only be resolved by having it repaired or replaced.
And it is expensive incase you were wondering.
Posted on Mar 27, 2008
6ya staff
SOURCE:
Panasonic DLP TV has huge yellow blotch covering most of the screen
SET uses a optical light engine--lamp which is quite hot shines into the engine---blue is first to get the light and heat and is usually first area in the lens and baffles to get damaged(loss of blue leaves red and green which equal a yellow screen.
You have a damaged light engine.
Apr 23, 2012 | Panasonic PT-43LCX64 43" HDTV
My screen has little dots appearing sometimes red sometimes blues behind the picture i just replaced the lamp bulb as i thought it would cure the problem
the projection tube needs to be adjust for color alignment, each tube (red, green, blue) must be aligned so you there would be no color smear appear on screen. if it is aligned try to set up the color balance, hue etc.
Feb 06, 2011 | Samsung Televison & Video
I have a toshiba 65hm167 no red color on the screen
Your TV is a DLP one lamp does it all, not like the old projection TVs with the Red, Green & Blue CRTs. Your TV may have a bad light engine or lose cable connections.
Good luck
N Sabre
Nov 08, 2009 | Toshiba 65HM167 65" Projection Television
Blue dots appearing on screen n bulb blew twice
IT NEEDS A LIGHT ENGINE. COST A LOT TO REPAIR.
Oct 06, 2009 | Televison & Video
Blue and red shadows on the TV picture
open up the TV then clean up the silver screen and the 3 light bulbs inside its probably just dirty.
Oct 05, 2009 | Philips Magnavox 51MP392H Rear Projection...
Color problem in the middle of the screen. When
You have a bad light engine. This is only repairable by a technician as you have a Hitachi LCD rear projection television.
Sep 10, 2009 | Hitachi Televison & Video
T.V.powers up I get light blue screen then shuts down mits.wd-625
not bulb component is damaged in power supply serction shutting down to protect other components
Sep 09, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Toshiba TDP-S20U Multimedia Projector Logo
374 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
digivisionm
Level 1 Expert
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
