Question about Singer 3116 Simple
Stich setting what is the basic stich length setting for this machine
    Genius:
  • 1,116 Answers
It is usually 2.5 or mid-way between 2 and 3. Set it longer - closer to 3 when stitching thick fabrics.
Make a sample of the stitches by sewing on a folded scrap of plain cotton or muslin and mark the settings used for future reference.
Do the same for the zig-zag settings and this will save a lot of time and guessing.
Posted on May 07, 2010
How do you set the length of the bobbin stich
The bobbin works with your top stitch ..when you set the length of the stitch then it goes the same as the top
Mar 06, 2015 | Bernina Sewing Machines
How to change stich to long stich for gathering?
http://www.singerco.com/uploads/download/3e3e5558857ed68836712ac8545abb48178772a5.pdf is the manual for your machine; look at p. 27. You want stitch 00, and then increase the stitch length with the up/down buttons on the control panel.
p. 24 of the pdf covers adjusting the top tension of the machine; you'll have an easier time of gathering if you reduce the top tension about 1-2 number setting.
May 29, 2014 | Singer 5400 Sew Mate 60-Stitch Sewing...
I have forgotten how to work my Decorative stitches on my Bernina 930
select the 1-20? stich pattern on top of the unit, then select the pattern you want, select widest stich and turn the length adjuster to the length that best suits that stich, (it could be from almost zero to full length depending on the pattern)
Feb 07, 2013 | Sewing Machines
I have a euro-pro sewing machine that i got second hand, came with no manual so i dont know whot to set it to basic stich it has all these knobs and i have no idea how to run it normally
Hello
The stitch dial for the length is located all the way on the right side of the machine and is factory set at the setting "3," which is a 3mm or 1/8 inch length. Turn the dial up or down to adjust the length. For example, the setting "4" is 4mm (5/32 inch) and "2" is 2mm (5/64 inch).
The width of the serged seam is dependent on the needle or by adjusting the knob for the width. With the left needle only sewing, the width is set to 7/32 inch, and with the right needle only sewing, it is set to 9/64 inches. Additionally, by pushing in the width adjustment knob behind the front cover, the stitching can be adjusted manually from 1/8 inch to 17/64 inch wide.
Jul 23, 2011 | Euro-Pro Deluxe 6130 Mechanical Sewing...
Hi, I have a Juki ddl 552 that does not have te stich setting nob. I am wondring how can I change my stich seting? please help.
Here is a threading diagram for this industrial machine
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Juki_Sewing_machine_threading/Juki_552_553_555_227_Threading_Diagram.htm
You can also buy a manual here
http://www.sewusa.com/Sewing_Machine_Manuals/Juki_Manuals/Juki_Industrial_Sewing_Machine_Manuals/227-552-553-555_Instruction_Manual.htm for this model.
I would have thought there would be some sort of screw or adjustment to control stitch length but I can't find an image for your model.
However this image might help, http://www.johnharbsew.com/images/threading/JUKI-DNU-241-TD.jpg, my Singer 20U, has a dial like this with numbers on that you adjust for length, is there something similar on the Juki?
Apr 19, 2011 | Juki MO-644D Mechanical Sewing Machine
The 6 built-in stitches (such as blind stitch, darning stitch, etc.) are not working, they only just do the basic zig zag stitch. Also the cams for decorative stitching do not work either. These are all...
I have the same model, have you turned the first knob on left, the stitch selector, to the stitch you want? Then turn the middle knob, the stitch width to "4". Use the colour guide marks shown in the little picture on left of the knobs so you are dialing up the right settings. So for the zig zag, elastic blind hem, scallop, overcasting and multi-stretch stiches, 1-6 on the diagram you'll be setting the left knob to 1, 2, 3, 4, 5 and 6 respectively and the stitch width and length knobs to "green", you can vary the length and width to suit what you want.
Then for the cams, you need to set everything zero, turn stitch selector to 7, the cam setting. then turn the width to orange again (3-4) and the stitch lenth selector to the orange setting, right around the knob. This engages the "Elnagraph" the device under the flap on top of the machine to read the discs. Basically the green stitches the needle is swinging from side to side while the feed dogs move the fabric forward, making your zig zags, blind hems etc.
But when you engage the Elna graph, the machine matches stiches by moving the fabric "forward and backwards at certain times, while the needle does its thing from side to side. This is what makes elastic or stretchy type stitches because you are putting "stretch" into the seam by sewing forwards and backwards.
Please note: always turn your stitch width and length back to Zero BEFORE you make any changes to the left knob and select a new stitch as this saves on wear and tear to the moving parts in these wonderful machines.
I do hope this assists you and I haven't just told you stuff you already knew!
Feb 15, 2011 | Elna Sewing Machines
Hole width
After putting on the buttonhole foot, you lower the foot, put in the size button you want into the button hole foot. Lower the button hole lever all the way (so machine does not blip) Then the machine automatically sets the length and width of the button hole...you can adjust the length and width manually by pushing the button on the top right hand part of the machine above the LED screen the top one is stich length the other is stich width....if you put the levers to the left it will be the smallest stich length or width...if to the right it will be the largest stich length or width the machine allows. But, really the machine automatically does this for you...so I don't see the need to do it.....but you can....BBill01
Jul 22, 2008 | Juki HZL-E80 Computerized Sewing Machine
Satin stich scallops
stitch no. 29 "F "foot 7.0 width 0.4 length tension 2-3
Jan 28, 2008 | Elna Heirloom Edition 6005
Singer 3116 Simple Logo
93 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
