Question about Nikon N75 35mm SLR Camera
My F75 won;t work at all
The mirror has frozen in the up position to I can't see through the lens; the screen initially would not turn OFF, then flickered, now it won't turn ON.  It doesn't seem to be a battery problem.  Help, anyone?
    Scholar:
  • 85 Answers
1.Most SLRs have the same problem.The paste which used to fix the reflection mirror with the metallic plate is usually rubber based, So there is a chance to the mirror to slide from its original position to down due to gravity.And particularly when you focus close ups the lens extends backward and the lens struck the mirror Positioning the mirror to its original position will solve your problem.
2.May be your camera batteries weak check it for its operating voltage.
Posted on Mar 26, 2008
What does remove obstruction mean
Is mirror in locked up position? In manual mode? Especially if the lens is irised down to a high f-stop.
Aug 24, 2014 | Fuji FinePix Cameras
WHAT IS THE PROBLEM WITH SHARP AR-5620 SL WITH ERROR CODE L1
Mirror base feed trouble
The mirror home position (MHPS)
does not turn off though the feed
operation is completed during
mirror initial operation after turning
on the power.
does not turn off during shading
operation.
does not turn on when the mirror
base is returned for the specified
time after copy feed is started and
SPF scanning position shift is
performed.
Jun 17, 2014 | Sharp AR-5316 Advanced Digital Imager...
Linkage problem,
Make sure lens is set on AF and not M. Clean body and lens contacts with a Q-tip dipped in alcohol. Try multiple lenses to make sure it is not a problem with just one lens. Put the lens on M and turn the front and make sure it turns freely and is not stuck by impact/spillage etc. Push down on the release button and make sure you have two distinct 'pops' (release switch may be broken). Gently lift up mirror and make sure that the AF sub mirror also comes up properly. Impact can break the little plastic guide pin for the sub mirror so that it is not in the right position and the AF will not work. Also make sure that the spring that makes the sub mirror come up is in position (they come off). Can be on either the right or left side of the mirror depending upon the model.
These are the steps I would take if you brought your camera into the shop I work at.
Apr 28, 2013 | Canon Rebel Cameras
I advise a high school yearbook and we shoot a d100. Today it's too dark to see through the viewfinder (yes the lens cap is removed), and i ger the r06 error. I've reset the camera, removed and...
First, the "r06" message is NOT an error code. It indicates the number of shots remaining in the internal memory buffer, before the camera must prevent additional shutter actuations so that it may transfer those images already in the buffer to the memory card. This "r" number will decrease with each shot taken in rapid succession until it reaches 0. The shutter release will no longer work until the buffer is transferred to the memory card, then shooting may continue again.
As far as not being able to even see through the viewfinder, it sounds like something may be obstructing the light from reaching the meter and viewfinder. The problem is most likely the position of mirror inside the camera body. With the lens off the body, the mirror should be plainly visible at about a 45 degree angle to the opening. A side view drawing of this is below. The solid red line is the mirror in the normal position. The red dashed line is the up position of the mirror when the shutter is released.
When the mirror is in the "normal" position, the light from the lens is projected on a screen so that the image is visible in the viewfinder for composing and can be metered. When in the "up" position (when the shutter release is fully depressed), the light from the lens is projected on the camera's sensor for as long as set by the manual settings or program; based on ISO, aperture, etc. At the end of this time, the mirror returns to the "normal" position.
If your D100's mirror is not in the lowered 45 degree angle position, the image seen in the viewfinder is inside the camera - not that which the lens would project. Hence, the dark viewfinder, long exposure times and - I'm guessing - severely overexposed pictures because way too much light is striking the sensor because the meter is only seeing darkness.
If the mirror is ok, with the lens removed from the body, look for the aperture lever as shown in the yellow circle in the picture below:
By default, the aperture is at minimum. The camera moves the lever from this position to full open (and anywhere between) as needed. You should gently move the lever to the other end of its travel to open the aperture to maximum. Point the lens away from a light source but preferably at a light colored background. Look through the lens. There should be no obstructions and be clear. Next, look at a dark colored background to find the same results. If you want, you can even allow sunlight to shine through the lens onto a sheet of paper (like a magnifying glass). The result should be a bright circle with no obstructions. Obstructions in the lens will prevent the meter in the camera from getting accurate information about the scene and if significant enough, prevent viewing through the viewfinder.
You may wish to have the camera & lens professionally cleaned and serviced to repair a mirror or lens issue.
If this was helpful, please rate it as such. Good luck!
Oct 04, 2011 | Nikon D100 Digital Camera
Can't see through viewfinder (it's all black) and cannot trip shutter or advance film. batteries are new and intact.
Remove the lens and look inside it. Do you see the mirror? If not, your mirror is stuck in the up position. Its flat up against the focusing screen. If the mirror is down, the problem is in the lens, or you still have the lens cap in place.
Check your manual under troubleshooting.
Try setting the shutter speed dial to the M90 position.
Also be sure the batteries are inserted correctly!!!!
If no change yet, you can try to put the mirror back down yourself. With the lens removed, set the camera on its back. You can use your fingers, but I suggest a toothpick cuz they won't leave fingerprints on the mirror and the toothpick should break before you exert enough pressure to really break something. So just try to return the mirror to the 45 degree angle within the mirror box. Be careful not to damage anything in there, like the shutter or the arms that raise and lower the mirror. Depending on where you live, there may be some corrosion or rust on the mirror linkage. It should move easily. If you feel any roughness when you move the miror, that may be the reason it did not return on its own. Then turn it on, off again. At some point, you may want to have this camera cleaned, lubricated and Adjusted(CLA) - after all, its over 25 yrs old.
If all that did not work, you'll need to send it in. Here are some good choices for repair places...
Garry Airapetov in Niles, ILL
Camera Repairs in Avon, IN.
BTW here's a website with several pages about FG...http://www.mir.com.my/rb/photography/hardwares/classics/emfgfg20/fg/index.htm
copy and paste it into your browser.
Oct 10, 2009 | Nikon FG 35mm SLR Camera
Image through nikon f80 dark and cloudy
I'm unfamiliar with the F80 but on models like the f65 and f75 the viewfinder screen has an lcd overlay and when the battery is exhausted or removed the viewfinder goes dark and blurry.
Looking at a picture of the f80 it looks like it's just an update on my f75 so it strongly suggests that you just need to insert a fresh battery. The lcd does draw power from the battery even with the camera turned off.
I hope that you found my answer useful, once you've tried another battery to confirm what I've suggested I'd appreciate it if you return the favour by rating my answer.
Jul 20, 2009 | Nikon F801S 35mm Film Camera
Err message on Nikon 75 after taking a picture
Here's a link to the N75 / F75 user guide. The troubleshooting section / lens compatibility area might point to the problem. If the viewfinder is dark, the mirror is likely stuck in the UP position. This is usually due to a lens compatibilty issue, or the fact that the lens is not set to its smallest aperture (ie 22). The camera needs that to control the full range of aperture openings
Dec 07, 2008 | Nikon N75 35mm SLR Camera
Lens error
i had this problem i turn my camera on the lens came out i turned them then my camera stop sayind lens error but now my pic is not clear
Jan 06, 2008 | Nikon COOLPIX L4 Digital Camera
Nikon N75 35mm SLR Camera Logo
114 people viewed this question
Top Nikon Photography Experts
pontelemon
pontelemon
michael galang
Are you a Nikon Photography Expert? Answer questions, earn points and help others
