Question about Boating
My evinrude 50 hp motor is running rough. one cylinder cuts in and out. already did carbs, reeds, fuel lines and some minor wiring. any suggestions ?
4 Suggested Answers
  • 597 Answers
SOURCE: I have a evinrude 48hp 2 cylinder oler model, that
You're not getting enough fuel. Check if there is a fuel filter than needs changed or if your gasoline is contaminated.
Posted on Sep 23, 2009
  • 86 Answers
SOURCE: adjust the motor idle on a 1974 evinrude 50
Seat the idle mixture screw. Turn counter clockwise 1 1/2 turns. With engine running in gear under a load at idle slowly turn the screw clockwise until the engine bogs down and then turn back out 1/2 a turn. That is your correct mixture.
Posted on Oct 16, 2009
  • 45441 Answers
SOURCE: 1991 EVINRUDE 25 HP 2CYL 2CYCLE IT RUNS ON BOTTOM
get a spark tester that has 2 leads and test spark .
Posted on Apr 26, 2010
1997 3cyl 25HP Evinrude outboard Would changing the carbs to 35HP carbs make this a 35HP motor?
Depends if the bore and stroke are the same, if they are not, adding larger jetted carbs can result in always running rich. The mixture would be incorrect for the amount of air the cylinders take in.
Feb 02, 2017 | Cars & Trucks
1980 evinrude 4 stroke wont start after running and now leaking fuel
Don't believe evinrude made a four stoke,but sounds like your needle and seat is jammed,clean carb
Jul 27, 2014 | Boating
I have a 1988 30 hp.evinrude that starts and runs fine till i reach 3/4 throttle,then it will die.ant suggestions?
Fuel line could be sucking air.check breather not blocked on fuel tank.if fuel bulb sucks flat,means blockage btwn bulb and tank.have you tried priming motor while running at full throttle.could also be dirty carb
Jul 15, 2014 | Boating
How to fix an evinrude 18hp that will idle in forward and reverse but won't go when you get on the throttle
could be 3 things a. high idol circuit in carb b. fuel pump c. reeds In most cases it is a fuel pump issue but have had all three of the cases be the problem. I always start with carb and then while carb is off i pull reed block and check to make sure reeds arent bent or dirty then if still issue the pump.
Mar 21, 2012 | Boating
Johnson 2 cyl 50 hp gearbox removal help!
Look on the side, of the lower end, (dirveshaft housing) for a small cover, with usually two screws holding it on. Then underneath the cover there is a fitting that connects the linkage. Put a mark with a magic marker on the linkage rod to remember where they line up. Put the motor in neuteral, (not running) and loosen the fitting, it should all seperate after that.
Apr 21, 2010 | Boating
Jan 26, 2010 | Light Outboard Motor Boat Bass Fishing...
I bought a 5 HP gamefisher outboard motor. It 's been use once and then it sit for years outside. I change the spark plug,clean the carburator,fuel filter looks good.good compression. gas go all a way to...
If spark plug is dry, fuel is not getting to the cylinders. Next thing to check would be the fuel pump... Gas may be getting to carb, but the pump needs to push it into the cylinders too.
Oct 18, 2009 | Boating
20 hp evinrude boat motor will not start
I usually don't recommend starting fluid but some brands have oil with them. You may have to dry the cylinders by getting them to fire with starting fluid.
You may have something else wet and grounding. Before using starting fluid spend some time with a hair dryer and try drying out the motor. Leave it sit in the sun with the cover off.
You should drain the carbs, drain the fuel line and gas tank.
Aug 01, 2009 | Boating
Boating Logo
148 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
